Hot Rods Clutch woes
Discussion in 'The Hokey Ass Message Board' started by jefscoupe, Sep 25, 2025.
  1. Do you know if there's anyone in driving distance that is a rebuilder you could take it to and have an over-the-counter conversation with as well as a bench done pressure test done?
    jefscoupe likes this.
  2. Doublepumper
    Doublepumper
    from WA-OR, USA
  3. jaracer
    jaracer
    It look like there is an undercut area to where the flywheel bolts are. Does the clutch disc metal part fit in that undercut? It's hard to tell from this picture if the flywheel side of the clutch disc is completely flat. Could the metal part be touching the flywheel?
    Do you have a clutch and brake shop anywhere near you? A buddy had problems with a new clutch slipping on acceleration and not always releasing fully. Like you, we had things apart and together and couldn't figure out the problem. He took it to a local clutch and brake shop to ask if there was any way they could test it. The technician came out from the back and picked up the clutch, took a good look and said the pressure plate isn't ***embled right. He took it in the back for about 15 minutes, came out and said it will be good now. It has been for the last 10 or so years and maybe 20K miles.
    Tim_with_a_T and jefscoupe like this.
  4. jefscoupe
    jefscoupe
    I could have posted a bigger size but I was concerned about using up bandwidth. Is that still an issue?
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    No not an issue, by all means post some good pics of the parts , maybe someone will notice something
  6. jefscoupe
    jefscoupe
    The one I used for years, I'm not sure is still in business. I need to check. It's been a while since I did a clutch.
    I did a quick search and they are still in business, but have moved to another location...I had driven by the old place sometime back and it looked empty. Glad to know they are still around.
    Of course, they are closed on Saturdays.
  7. jefscoupe
    jefscoupe
    It's hard to see in the pic but yes it is recessed for the bolts. The disc fits flat against the friction surface of the flywheel only. IMG_0111.jpg
  8. gary macdonald
    gary macdonald
    IMG_7065.jpeg Please check between the fingers of the diaphragm pressure plate for interference.
    If its bolted down and compressed, is it possible that the fingers are touching each other .
    I’ve had this only one time in my life , a bb chevy 427 fuel injected direct drive altered . Drove us bat crazy .
    I hope you understand what I’m trying to describe.
    Gary
    winduptoy, wandi harry and jefscoupe like this.
  9. jefscoupe
    jefscoupe
    Appears to be OK. The mark on the disc was to check if the center hub was spinning. It is not.
    Thanks for the suggestion. I'll take any and all at this point.
  10. CTaulbert
    CTaulbert
    from Detroit
    Is that a 26 spline disc? If it is, go to your local parts store and buy a clutch kit for a ‘88-92 Camaro. That should get you a GM 10.4/10.5 clutch kit in 26 spline.
    I’ve done a couple flatheads with that McLeod aluminum flywheel and the parts store clutch kits with success.
    Stu, jefscoupe, winduptoy and 2 others like this.
  11. When you do finally get to the bottom of this, we're all going to learn something. At this point I would say it's a PP issue, but I doubt you got 2 in a row with the same issue.
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    he did say that the clutch came from Speedway. They are not exactly known for quality ......
  13. Mr48chev
    It may be optical illusions but why does the steel surface on the flywheel look lower than the aluminum around it and why does the surfact of the clutch disk look worn to the rivet heads? Screenshot (1112).png
    GuyW and jefscoupe like this.
  14. ClayMart
    ClayMart
    I can't really see how it would make any difference. But would a low-cone diaphram pressure plate possibly make things act any better? How high are the fingers on the stock long-style PP by comparison?
  15. Baumi
    Baumi
    Sorry for being late to the party and not having read all the posts.
    But if the clutch still slipped on you without the TO being installed, is the a chance the collar of theTKO bearing retainer is just a tad too long and touches the springs enough to just slightly disengage the clutch?
  16. Happydaze
    Happydaze
    You might want to firm up on that dimension.
    I've got a Ram clutch supplied for a tko 600 onto a chevy. P/n 98761 which I didn't use because the flywheel bolt spacing didn't fit and I didn't want to redrill. No matter,
    My quuivalent dimension is 0.170". That about 18 thou less than your minimum dimension. I'd say that's quite a lot when we're talking about lack of grip onto the plate and, if anything, yours should have greater clamping, which clearly isn't the case!
    There has to be interference or something going on. Hanging up on dowel pins? Bolts bottoming out in blind holes?
    Chris
  17. ClutchDumpinDan
    ClutchDumpinDan
    Wow. I’ve dealt with some bizarre clutch issues and see most of those ideas/problems already covered here.
    With everything already mentioned, having been checked. I’d follow Baumi advice above. I’ve had the bearing retainer collar be too long before and it will press on the clutch fingers and release them.
    Easiest way to check is with a borescope with it all ***embled. If you don’t have one available, you can put some clay in there and bolt it together, then dis***emble. Although most times you can tell when putting the transmission on the bellhousing. As in, it won’t mate up flush by hand and requires the bolts to pull it in.
    Just to be triple sure, make sure there is no gap between the pressure plate and flywheel when torqued down. I see full thread bolts in one pic and I’m ***uming those are for pressure plate, so that won’t be the issue. Had a car that would slip under heavy load. Someone had installed the wrong bolts in pressure plate. They’d bottom out on the shoulder part of bolt when torqued. Left just enough gap between flywheel and pressure plate to not let it clamp 100%
    Looking forward to seeing what the solution is!
    427 sleeper, jefscoupe and alanp561 like this.
  18. Kevin Ardinger
    Kevin Ardinger
    Since it looks like everything is out, how about you bolt that flywheel to the floor or to a big piece of plywood or something to hold it stationary. Install the clutch as you would in the car and see if you can turn the disc.
  19. jefscoupe
    jefscoupe
    Just the pic. It's flush.
  20. jefscoupe
    jefscoupe
    This particular transmission doesn't have a T/O bearing collar. The collar is built into the T/O bearing.
    Weird, yeah but that's how it's made.
    Baumi likes this.
  21. jefscoupe
    jefscoupe
    If I had an input shaft laying around. The plastic alignment tool won't do it.
  22. jefscoupe
    jefscoupe
    Thanks to all who responded. I got a lot of good info and now have a direction to move next.
    I'm taking the flywheel, p/p and disc to a clutch shop here in Memphis that has been in business for decades and see if they can spot the issue and get it sorted out. That'll have to wait until Monday.
    I'll let y'all know what I find out.
    EDIT:
    The place I thought was still open turned out to be permanently closed.
    But...there is another place I'm going to try.
  23. jefscoupe
    jefscoupe
    Well dammit, the other place is closed too.
    But I got a couple names to try.
  24. jefscoupe
    jefscoupe
    Well, I finally found a place in town to take my clutch set-up to.
    They told me this morning that the pressure plate doesn't have enough "draw", as they call it.
    They will take it apart and shim the ring to make it right.
    He asked if I wanted to send it back to where I bought it and get them to make it right but I figured I'd just get another one just like this one, so go ahead and fix it.
    Plus, they'd have it done by tomorrow.
    It would take, who knows how long to send that one back, then receive the new one just to (likely) have the same problem.
    I should know something in the next couple days.
    Fingers crossed.
    Tim_with_a_T, GuyW, winduptoy and 9 others like this.
  25. Motorwrxs
    Motorwrxs
    I was looking for this thread yesterday to see if you had fixed the problem yet…sounds like you are getting close. Keep us posted and good luck.
    winduptoy likes this.
  26. wandi harry
    wandi harry
    I am following along, way to many threads here where people post up issues and never bother to follow up with what eventuated so thanks for keeping the curious a****st us informed.
    What do the clutch people mean when they say "draw"
  27. ekimneirbo
    ekimneirbo
    from Brooks Ky
    I haven't read all the posts...........As long as there is clearance between the TO bearing and clutch fingers it would seem that the clutch must clamp unless there is interference "somewhere". Is there any possibility that that the bearing support for the Tremec might be preventing the clutch from completely grabbing ? Maybe a little too long or something or the throw out bearing touching it,s face and not moving far enough? Only take a little interference to keep the clutch slightly released.
    Anyway thats my best guess............:)
    Baumi likes this.
  28. Moriarity
    Moriarity
    SUPER MODERATOR
    read post 84, 2 above yours
    Pist-n-Broke likes this.
  29. ekimneirbo
    ekimneirbo
    from Brooks Ky
    I read about a page and a half then skipped down because I was getting ready to go somewhere. When I was first fooling with the hydraulic clutch stuff I made a fixture to mount the components and an engine so that I could see them function before installing them. Then made a Redneck gage that I could slide in place to check the clearance. Never considered that the clutch itself might not be ***embled properly. I know from somewhere in the distant past that I've seen the front bearing housing cause interference, but don't remember the exact details. Anyway, I'm glad he was able to solve the problem. Perhaps a few pics showing what they changed for future reference.
    Here are some pics of the "Engine Rotator" and Hyd Clutch Checker.
    Heres the homemade gages.
    The thing about this is that anyone who has an old/extra bellhousing sitting around can easily modify it like this one and be able to get a better view when setting the gap and could actually test the clutch in the car. Then put the real bellhousing in place instead of fighting to get it set right.
  30. kurt varga
    kurt varga
    why not put a stock 8ba fly setup on it and be done.
