Technical Has anyone used spraymax--black-1k-epoxy primer
Discussion in 'The Hokey Ass Message Board' started by JD Miller, Sep 19, 2024.
  1. JD Miller
    JD Miller
  2. JD Miller
    JD Miller
    btt mo looky
    65 lookies so far
  3. Bandit Billy
    Bandit Billy
    That can says e coat, but I have used their epoxy primer. Most recently, on the 41 PU I painted last year. When I was blocking the hood, I got bare metal on a louver or two and on a couple of edges. I could have mixed up and shot more DTM primer but this stuff worked just fine and applied my sealer and base over it without any issues. As long as it is catalyzed (has the red ****on on the bottom).
    Oneball likes this.
  4. rusty valley
    rusty valley
    Please explain, there is product and catalyst in the same can, but it has another ****on to release both products?
    Bandit Billy likes this.
  5. Oneball
    Oneball
    As Billy said youre talking about two different products there, epoxy which is a 2 pack and e-coat subs***ute which is 1 pack.
    The epoxy in a can are 2 pack and have the catalyser separated internally from the base you then mix them by pressing a ****on and away you go.
    Your pic though is of a can of e-coat subs***ute which is a type of 1 pack primer not an epoxy. E-coat is the black protective paint you often get on replacement body panels. In the factory it is an electrically deposited paint. The product you show just emulates that finish.
    Bandit Billy and Just Gary like this.
  6. -Brent-
    -Brent-
    I have used it here and there over the years. I picked up a can of gray, locally, a few days back and it was $30! I remember when it was expensive at like $18 a can.
    Like Billy says, it's good for small projects. If it's something that requires less than a can, I'll try to find something else I can shoot with it so I'm not wasting.
    seb fontana and Bandit Billy like this.
  7. Bandit Billy
    Bandit Billy
    The can looks normal until you turn it upside down, there is a red ****on in the cap that you remove, place it on the stem on the bottom of the can and slam it on your workbench to puncture the bag of hardener inside. Shake vigorously, similar to shaking a dirty martini. I always sing the happy birthday song in my head for the perfect pour. Wear a respirator! That is now catalyzed and will destroy the cilia in your lungs.
    Correct, once activated the can has a shelf life of about an hour or two. There is no saving it.
    Just Gary, rusty valley and alanp561 like this.
  8. Fortunateson
    Fortunateson
    Yes, the “e” stands for electrically deposited not for “epoxy”.
  9. bill gruendeman
    bill gruendeman
    At 18$ a can it’s not cheap and if pop the ****on and mix the two parts is it one time use, short pot life? If I have a small burn though, I mix up 1 or 2 oz of epoxy and use a q tip and dab it in and sand as needed. It better and maybe cheaper.
    alanp561 likes this.
  10. Dino 64
    Dino 64
    from Virginia
    I’ve used the 2K epoxy with excellent results. They also make a 2K hot rod flat black which is also an excellent product IMG_5743.jpeg IMG_0368.jpeg
  11. Bandit Billy
    Bandit Billy
    That sure doesn't look like a rattle can job. Excellent!
  12. Dino 64
    Dino 64
    from Virginia
    Thanks ! It’s good stuff, I’m a ****py painter too !
    As mentioned, use a good quality respirator with this product. 3M organic vapor cartridges a must if you like your lungs :):rolleyes:
    Just Gary likes this.
  13. Hutkikz
    Hutkikz
    After mixing If you put the can in a refrigerator it will last a day or so. This works for most catalyzed paints as it slows the chemical reactions.
  14. Devin
    Devin
    from Napa, CA
    I’ve popped the can of their clear coat in the freezer and had a modi*** of sucess re using at a later time. Your mileage may vary.
  15. Fortunateson
    Fortunateson
    I can’t recall the name at the moment but there is a new product out of the Netherlands I believe that is somewhat similar. Their claim to fame it that the two parts are not totally mixed but mixed as you paint....
    I’m laid up in bed trying to recover from a couple of “small” strokes so getting around is a ****** but I’ll try to get the product name and info from a couple of moles I have working in the net!
  16. K13
    K13
    You are probably talking about Car-Rep.
    www.car-rep.com
  17. Fortunateson
    Fortunateson
    Yeah just found it! I’ve talked to reps and I got a couple of samples but haven’t tried it yet...
    What do you know about the product?
    And they’re out of Finland apparently.
  18. Budget36
    Budget36
    How about you just take care of yourself.
    Heal well, sorry to hear of the misfortunes.
    57Fury440, alanp561 and Fortunateson like this.
  19. lostone
    lostone
    from kansas
    I would use that under the floor boards of my car. It'd be easier laying on a creeper spraying that than trying to do it with my big hvlp spray gun dragging a hose with it !
  20. Fortunateson
    Fortunateson
    Thank you. I’m trying but it is REALLY boring! I just want to work on my projects....!
    alanp561 and Budget36 like this.
  21. old_chevy
    old_chevy
    from USA
    Hi Bandit Billy, On bare metal what grit do you use to prep the panel before 2k SprayMax epoxy primer? I read the data sheet and could not find the instruction. Also how has been the durability and quality of the 2k SprayMax epoxy primer?
  22. Bandit Billy
    Bandit Billy
    180 is kinda my go to when needing tooth on metal for mechanical adhesion. On that hood I was sanding with a finer grit, 400? prepping it for paint. I shot the primer over the 400. Not something I would recommend but roughing it further wasn't an option on those louvers.
  23. earlymopar
    earlymopar
    The Eastwood 2K that I've used has a "pot life" of 48-72 hours. Great product in both their primer and top coats although they are limited in top coat color choices.
