Projects 1932 5w Coupe project continue
Discussion in 'Traditional Hot Rods' started by AULIZ, May 28, 2016.
  1. AULIZ
    AULIZ
    Thank You Glenn.
    I haven´t been very efficient now a days... something every day. Today, Saturday, I try to heat and turn br*** bracket. You guess what happen... it broken. I have soldering fux and welding additive, so I weld it. I hope its OK. Looks ok and material was not "boil" so I think its OK. Br*** brackets have been long long time in my junk drawer, now I found good place to use those.
    I use those small lights (Grimes landing lights from year 1943) like front turn signal.
    Also removed 3 head stud, installed old Weiand generator bracket. First I used Chevy SB Arp head bolts, but changed those old studs with nuts. Studs and nuts combination looks better than hiteck Arp bolts.
    When intake manifold arrive from USA, I change generator place. Now I use Cl***ic V-belt B-53 (53"). That is little to short, so I need to order from our company warehouse 53.5" or 54" belt. Note that weiand bracket text.
    "Los Angeles 65". If I remember right, they had short post numbers there still 40´s, 50´s ?
    Nice weather outside. They have Finnish Championship serie final Rally here in Seinajki city. After 1-2hours they have last stage in speedway (MC) track area. Maybe I take 2hours Saturday walking and go there to see rally.
    Aulis
    Nb. We booked flights to see AMRA final drag race in Rockingham NC. Normally I have visit in NHRA races, but this time we spend few days there to see if our friend (who we are sponsor) Samu Kemppainen is this year Nitro V-twin serie winner. Maybe there is few other finnish racer on track too. We have only short visit. I, my friend Kari and his wife Satu. They have SPTR Asennus Oy ( https://sptr.fi/en/ ) -company. They sponsor many finnish racers. I have try to help few racing teams too.
    rod-coupe1625.jpg rod-coupe1626.jpg rod-coupe1627.jpg rod-coupe1628.jpg rod-coupe1629.jpg
    AHotRod, Stogy, Outback and 8 others like this.
  2. AULIZ
    AULIZ
    Two days more before I start long vacations... Tuesday i close my coffee place, wednesday I take my vacations in dayjob.... We have here 4+1week year vacation in Finland (Sweden, Norway, Denmark same system) with 1.5 x salary. I havent spend my vacations last 12years.... I informed our company owner and MD that I start to spend my vacations. They told me that "You have loosed those, because You havent take those vacations in due time".
    I informed them, OK I dismiss from work and spend my vacations in my own time..... Im next May 60y, not so interested work anymore.... Yes, they called many times and accepted that I can take vacation months now....
    Today I installed Aircraft wire holders, made simple turnsignal switch bracket and connected front turnsignals.
    Leaves are falling and autumn is comming... Last hot rod rides are now.
    Yes, I bought new "hot rod". 2010 gator TE. Now I have electric toothbrush and electic vehicle.... where this life is going to?....
    rod-coupe1630.jpg rod-coupe1631.jpg rod-coupe1632.jpg rod-coupe1633.jpg rod-coupe1634.jpg rod-coupe1635.jpg rod-coupe1636.jpg
    Aulis
  3. Deutscher
    Deutscher
    from Germany
    I wish you a wonderful holiday.
    Best regards, Harald
    Stogy likes this.
  4. AULIZ
    AULIZ
    Thank You!
    2nd day without any need to work.... Feels good. Slowly morning,....
    Today arrived 2 x 2bbl Intake from USA (China stuff). Very good quality. Im not sure if I remove that satin black paint. I need to grind, sand and blow with sand those risers. Now those are too much CNC outlook. I need to make enough long stud bolts ... Yesterday i made wirings. Front headlights, parklights, turnsignals are OK. This time generator wirings, next brake switch and taillights.
    Yes, I was once again stupid when installed weiand generator bracket... This intake works fine when generator is on its original place. God bless, to work myself is free... :)
    Aulis
    rod-coupe1637.jpg rod-coupe1638.jpg rod-coupe1639.jpg rod-coupe1640.jpg rod-coupe1641.jpg rod-coupe1642.jpg
    AHotRod, hook00pad, Stogy and 9 others like this.
  5. HotRodMicky
    HotRodMicky
    Hi, the intake looks cool!
    Where did you get it from?
    Regards
    Micky
    Stogy likes this.
  6. AULIZ
    AULIZ
    Micky, I bought from ebay. "Real china ****".... This time quality looks good, very good.
    One of those companies who sell there china carbs, intakes etc. This is located in Ontario CA.
    I have ordered from one which is located in Rialto CA and another in Riveside CA.
    Yesterday bought UNC and UNF bolts. I cut both, lathe ends tig weld together... I need 5" long studs for carbs installation. I have ready studs, but 4" lenght is not enough
    Aulis
    Stogy and Outback like this.
  7. AULIZ
    AULIZ
    Yesterday I worked all day, but didnt get nothing ready... Mostly I made footprints.
    OK I made 3m long booster cables. I hate those china ****, I bought RECO (Denmark) ends+ 2 x 3m 35m2 cable.
    Also changed another 12V generator. Black one was work OK , when I polarized it, but never give volts out.
    I need to open it, maybe one coal is stack etc etc.
    This cromed is 21A model (1-2cm shorter than 50´s blc one) which I have converted to 12V long time ago.
    Now it charge 14.4V when approx. 2000-3000rpm .
    I like those old generators + voltage regulators. Easy to use, enough for old cars, good outlook and easy to tune up.
    Note old Voltage gauge. Works fine.
    Many times those digital gauges etc are "confuse" when You have DC system. They are made for AC
    I bought from Ebay those nice velocity stack. I like that outlook. Those are only 65mm ID , so I stretch few minutes, now another is fit perfectly. Little too big, but I like use tape between carb and cleaner/velocity stack.
    Aulis
    Hot Rodder from Helsinki send me that picture shot Tallinn (Estonia). I didnt know that Im in beauty business.....
    Aulis first name is not so many here and my last name (Hämeenkorpi) under 100people... Beauty business or Flowers are OK for me when I turn 60 next year... ;-)
    rod-coupe1641.jpg rod-coupe1642.jpg rod-coupe1643.jpg rod-coupe1644.jpg rod-coupe1645.jpg rod-coupe1646.jpg rod-coupe1647.jpg
  8. AULIZ
    AULIZ
    Few things done. I cut and welded together 5/16 UNC and 5/16 UNF bolts. I made 120mm long studs for carbs and risers.
    Same time I have check parts next project 304cid flathead. Still need some parts. Just drop order to Speedwaymotors. Heads, cam gear, distributor gear, one 1.6" valve, big bore gaskets, oil pump pick up.....
    I want to use 8BA style timingcover + Cirello (426cid mopar) magneto. I need to piece magneto and made it fit to flathead. I want to use 2 row waterpumps. I need to use those 49-53 mercury "long neck" pumps (see pic) and change narrowed v-belt pulleys to 2 row model. Then I have enough free space between belts and engine. Distributor/magneto needs that free space.
    Tomorrow I sandplast intake, risers. Fit all and port runners to fit engine runners.
    Aulis
    rod-coupe1648.jpg rod-coupe1649.jpg rod-coupe1650.jpg rod-coupe1652.jpg rod-coupe1653.jpg rod-coupe1654.jpg rod-coupe1655.jpg rod-coupe1656.jpg rod-coupe1657.jpg rod-coupe1658.jpg rod-coupe1659.jpg rod-coupe1660.jpg rod-coupe1661.jpg rod-coupe1663.jpg rod-coupe1664b.jpg
  9. AULIZ
    AULIZ
    Only few hours worked today in garage. I start to fix intake manifold outside and port inside.
    First I enlarged gasket runner holes same size than in cylinder block holes.
    After that transferred dimensions to intakemanifold.
    Today arrived stuff from Gotham Autoparts. Very good quality, packed perfectly etc !!!
    Now a days most of shippers doesn´t care how to pack and ship. This company got 100points.
    Aulis
    rod-coupe1665.jpg rod-coupe1666.jpg rod-coupe1667.jpg rod-coupe1668.jpg rod-coupe1669.jpg rod-coupe1670.jpg
    Aulis
    AHotRod, Uncle Ronn, ALLDONE and 6 others like this.
  10. Nice work.
    Stogy likes this.
  11. AULIZ
    AULIZ
    Thank You.
    I ordered (Monday) few parts from Speedway motors. I found all what I need from one distributor. Now they informed that they have cancel my order because Im located so near Russia and they are not sure if my parts are used in Russian metal industry or in their war industry. What a ****! I send them email, and asked them take their head out of "so******tic bubble" or "from that place where sun is not shine". I wonder how stupid people is working there
    Aulis
    Deutscher, patsurf and Stogy like this.
  12. Deutscher
    Deutscher
    from Germany
    I already had this discussion with Speedway Motors when my order was canceled.
    All the others ship from the US to Europe, but this shop doesn't,
    but they send you advertising via email. Regards, Harald
    Stogy likes this.
  13. patsurf
    patsurf
    :rolleyes:o_O
  14. AULIZ
    AULIZ
    Yes, Mr.Roadster company is sell very much **** (all their own stuff is so **** that even metal recycling not accept...), they have done that long long time. I have not used their services last +20years, now I decided that this was last order. They can keep their business policy.
    When I moved to Los Angeles area 2003, my first orders I made to Speedway motors. When learned more this field, I bought all from Ashley (Reids rod parts), socal speedshop (1/4mile from my garage in pomona), Total cost involved, Afr, Currie enterprices, piston and crank manufacturers (****, venolia, ross, engle, arias, bryant,...., ) PAW had good stock and good pricing, Moon, CWmoss, CG early ford, BDS, Edelbrock, compcams, howard, hot hemi heads,...... and many other.
    Wednesday worked 5-6hours in garage. today I start to put all together.
    Aulis
    Nb. Be carefully with new fuel hoses. This engine hose was only 3months used, it´s full of small cracks !!!
    rod-coupe1671.jpg rod-coupe1672.jpg rod-coupe1673.jpg rod-coupe1674.jpg rod-coupe1675.jpg rod-coupe1676.jpg
  15. Deutscher
    Deutscher
    from Germany
    Wow, this turned out great, great work.
    Greetings Harald
    Stogy likes this.
  16. DrJekyllMrHyde
    DrJekyllMrHyde
    I don’t know if I have mentioned before, but you can use MyUS.com
    You can collect packets from different vendors at their warehouse, got it repacked in one box, pay freight and tax in advance, then goes direcly to you.
    Even ‘dangerous goods’, like oils, glues, paint.
    Not cheap, but works.
    Stogy likes this.
  17. AULIZ
    AULIZ
    Good to know. Speedwaychinamotors is only and one company who is not sell Europe.
    Summit Racing, Jegs, Cl***ic industries, ThirdGen, all orig. ford companies.... are think that
    " Old ford parts are not used in war technology globally, even not in Russia ".
    I was think, maybe somebody is help me and give his address where I can order those stuff from speedway (edelbrock heads, 8BA distr.gear, 2702 timing gear (49-53), oilpump pick up, one valve, big bore headgasket pr. Not big shipment. Only change shipping info on box and let me know all costs + salary.
    Aulis
    Stogy likes this.
  18. Stogy
    Stogy
    Awesome job on the intake, risers and carbs...it's all coming together nicely @AULIZ.
    brady1929 likes this.
  19. Deutscher
    Deutscher
    from Germany
    I have addresses of warehouses where I wanted to have it shipped,
    but they canceled that, too.
    My billing address was in Germany, and they wouldn't ship there.
    That's no problem for me, too;
    there are plenty of alternatives.
    Best regards, Harald.
    Stogy likes this.
  20. The 39 guy
    The 39 guy
    I like the way you machined the manifold to match the risers. The manifold now looks very much like a Thickston PM 7. You probably saved some money by useing this innovative approach.
    Stogy likes this.
  21. AULIZ
    AULIZ
    Thanks everybody.
    No show quality, just for driving. Old style = homemade ideas and realization.
    Today, I made fuel lines. Fuel hose was very bad condition (maybe 2-3months old). I opened ends and changed hose to Gates "all fuel resist". I pressed new sleeves on hose. Now fuel hose is very much shorter. When fuelpump now turns more, pump inlet comes very near of fuel line which comes from tank.
    I drove 10-20km. Runs good. Very powerfull engine. Idler is OK, after that there is small "dead" area. Maybe I try go change different powervalves. When Rpm is going over 1500.... Engine is scared strongly. I think, those too big in runners are done that. I adjust ignition and carbs many many times, now rather good. Next I change different power valves.
    When installed risers, I dont use any seals between risers and intake. Only Loc***e 5980. When there is no gaskets, looks better. All carb gaskets I permeate oil and grease. Keeps gaskets soft and easy open when needed. Carbs in this combination are "china" 94. Very good quality. I opened both, checked that there is all OK, and not dirt etc.
    Tomorrow I need to drive 50-70km to see my old friend. Next week need to make bigger maitenance, continue make electrics ready (rear turnsignals, brake lights, tachometer...). Also need to drill hole and install speedocable.
    Aulis
    There is old sacks on wall, never used.
    Another pic: Aulis & dragster year 1997 collection card. 12compe***ion during summer. biggest eliminations 64car field. 8 times I was in final, 6 wins. over 120 starts during 4-5months season. I was Young and good flow on.
    Now only "and"
    rod-coupe1677.jpg rod-coupe1678.jpg rod-coupe1679.jpg rod-coupe1680.jpg rod-coupe1681.jpg rod-coupe1682.jpg rod-coupe1683.jpg rod-coupe1684b.jpg
    AHotRod, Stogy, swifty and 3 others like this.
  22. AULIZ
    AULIZ
    Now Im very confused. I have try to get it this Flathead psyche.
    Engine starts nice, runs and drives. But,.... I feel in my **** and fingers that engine is not what I want. When it smokes, car is not push like it push when its Neutral or Lean...
    We know that when You are near "too lean" engine runs like crazy.
    there is very strong vacuum, exhaust runners also are flow very very good, which helps in side fill better cylinders, cylinders are empty before intake cycle. I note that I must open very carefully idle screws, or engine sound is change to "heavy" even when it is just idle running. Many engines are not very much change their sound when You open or close those idle screws, but when very strong vacuum, half round is very much open or close way....
    I have try to install smaller jets, change power valves (both way),... still spark plugs are very very black.
    Distributor (stromberg electric) cap look very very bad (see pics) afte 100-200km driving...
    I think that:
    1) distributor is not enough for this engine?
    2) there is somehing elecrical problem in distributor?
    3) this engine needs more carburetors (more trottle area)?
    Feels that engine has huge potential, it tries to push strongly, but when more trottle, rather much smoke behind car ( its rich, not lean), even have normal size 53-55 nr. jets.
    Is there too small trottle surface area? or is this stromberg distributor **** /out of order....
    spark plugs are black even drive very carefully. I take 5min test drives and drive direct back in to my garage.
    Why distributor cap looks terrible?
    I have fix it many times. I have 3-4 caps, I have changed fixed cap too many times.
    I have ready 100% rebuilt Harman Collins magneto with new points, condenser and coil.
    I have installed and adjusted it ready. Must I change it to see how engine works with it....
    I like challenges, no hurry nowhere, but sometimes feels that not "find goal"...
    Aulis
    AHotRod and Stogy like this.
  23. patsurf
    patsurf
    well i for sure want to hear what people come up with regarding the contacts in cap--maybe jim will have some ideas--could they include moisture and or grounds??
    Stogy likes this.
  24. AULIZ
    AULIZ
    I wonder if spark is not enough strong or engine dont get enough air.... Black candles (spark plugs) is not good thing.
    First I need to change ignition from stromberg to harman collins magneto.
    Im not very interested in to order one intake more (3 x 2bbl).
    Stogy and Chris L. like this.
  25. AULIZ
    AULIZ
    OK, today I removed stromberg electr. ignition. I check that all has been right position. Cam, crank, distributor rotor... All has been perfect. I wonder why I had need to fix distributor cap many times, and spark plugs are lampblack.
    When magneto was installed, I tune it up slowly, check many times right timing.
    Started up engine. Now engine runs like crazy. No black smoke behind when I pedal more.
    Spark plugs are OK. Engine takes easy Rpm, not dead area when drive, sounds powerful even when run Idle rpm ...
    Ou ****. That stromberg distributor set wasn´t enough strong... They say "its normal oxidize".... Im not sure that its normal if every 50-100km You need to fix distributor cap..... Even, when all fixed, engine didnt feel what it must be.
    Aulis
  26. The 39 guy
    The 39 guy
    Congratulations! I am happy to see you solve this ignition problem. I knew you would eventually.
    Stogy likes this.
  27. AULIZ
    AULIZ
    Thanks Man !
    I like challenges, but sometimes it feel bad when You do same job time after time....
    I like those Magnetos. Strong spark even if little too much "soup" feed to the engine...
    Idle rpm sound is strong &powerful. I don´t care if little grey/black smoke when full trottle (p*** a car etc), if
    hot rod is run strongly and I feel it in my backside that there are all three-legged horses are stored there ....
    I make my rush order to Stromberg on June when magneto died. It gave spark when plugs are out, but when there was pressure in cylinder nothing happens. Coil vas recoiled here in Finland. 2nd time "magnetoman" fail.
    Now stromberg coil+wirings+distributor is good sparepart set. I pack those small box and keep in trunk when I drive longer roadtrip... I can install it in hour without need to remove radiator. Magneto installation need to do more closely if You want to get out strong spark right time...
    Now need to install one switch more under dash. I need to make new bracket there etc.
    Weather is now real autumn. Leaves falling down, extra job to fix yard... Next week I have one week vacation, when we fly to Rockingham to see AMRA motorcycle drag racing finals.
    Aulis
    AHotRod, Stogy, lurker mick and 3 others like this.
  28. AULIZ
    AULIZ
    Magneto "killing switch" is installed. Not under dash, I put to steering column.
    Bracket is Limeworks column shifter upper end bracket. When I had hot rod shop, shipments arrived nearly weekly, got also wrong or damaged stuff which is good to "reuse" or sell. And switch is 1939-> Ford starter ****on.
    Aulis
    AHotRod, Stogy, hotrodA and 5 others like this.
  29. AULIZ
    AULIZ
    Hello
    Next Tuesday we take flight to Charlotte NC.
    If somebody has something interesting stuff for sale, Im there (cash) in Charlotte - Rockingham - Abedeen -area 6days.
    I need small parts to my project engine (cam gear Alum. 8ba style distr. gear, SS valve, Alum. heads). Is there any shop in NC area where I can visit, possible to order stuff ready.....?
    And what places is good to see? I have hear that there is Nascar museum. That is interesting, what else?
    Aulis
    AHotRod, Stogy and Chris L. like this.
  30. AULIZ
    AULIZ
    Yesterday I ordered stuff from Speedway motors. I ordered to my Hotel address in Nort-Carolina.
    Today they cancel my order. "we dont sell parts to European Union area"......
    I hate those communists. Need to send them 2kg cow****.
    A
    hotrodA, 19Eddy30, Stogy and 3 others like this.
