Projects All The Twos: 1962 Mercury, 352cui, 2bbl, Too Many Doors.
Discussion in 'The Hokey Ass Message Board' started by Oneball, Oct 28, 2023.
  1. Oneball
    Oneball
    Waiting for the ferry in Caen by Bill Millin's statue on Sword beach. The story goes that the German soldiers thought he was nuts wearing a kilt and playing the bagpipes so they didn't aim at him
  2. Oneball
    Oneball
    Back in England now. Just stopped off at Membury services. Doesn't look much now but it was RAF Membury. Some of the 101st Airbourne Division took off from here on D Day.
  3. Oneball
    Oneball
    Back home in the garage. Only issue I had was when I pulled into an underground car park and stopped at the barrier it stalled. I’d been sitting in traffic on a hot day for 30mins so I’m wondering if it was fuel vaporisation and the ramp down into the car park pushed it over the edge. Not a fan of the steering at high speed though. I think I need to do something with the power steering control valve. I’ve rebuilt it already and replace the sliding sleeve but I think the body may be worn. 20250924_120808.jpeg
  4. Oneball
    Oneball
    Got the PS control valve off and I can't get my head round if there's anything wrong with it. There's more play than I would consider normal at the wheel and it seems to be within the control valve as you can see the shuttle moving more than I'd think but on the bench can't find anything. The book says 0.06 inch of movement when ***embled but without the centereing spring there is a lot more. It wanders quite nastily at speed but I can't work out why. It's better than it was since I've rebuilt the front end but I'm still not happy.
    Okie Pete, Sharpone and guthriesmith like this.
  5. Oneball
    Oneball
    I can’t find anything wrong with the steering or the front suspension. There 0.060” of movement in the control valve which is what the book says there should be on the bench. There’s no play anywhere else. There’s 1/8” toe in and 3deg caster and it’s still scarily moving around the road speed. I’m utterly out of ideas.
  6. RMR&C
    RMR&C
    from NW Montana
    Wheel offset other than stock can change the scrub radius and cause wandering/darting. Some cars are very sensitive to even a small amount of change
    Sharpone and Oneball like this.
  7. Oneball
    Oneball
    I did look at that, I might put the originals back on just to rule it out but tire width, rolling radius are as per stock and offset is very similar.
    Sharpone, guthriesmith and RMR&C like this.
  8. Oneball
    Oneball
    Been through the whole front end with the Ms waggling stuff and there is absolutely no play anywhere. Next job I’ll try putting the original wheels on and if that doesn’t work I’ll change the geometry. Part of me is thinking this might actually be a rear end issue.
  9. Pontmerc
    Pontmerc
    from Finland
    That much caster may cause bump steering.
    Also you could try add some toe in.
  10. Oneball
    Oneball
    Had a proper go at the front end geometry last night. Got 4 deg caster, -0.5 camber and 0 toe and it’s so much better. One hand cruising on the dual carriageway. Think it might need a bit of attention to the rear end around spring mounts but I’m a lot happier.
  11. Oneball
    Oneball
    I never cease to be amazed by people’s stupidity when repairing cars. At some point in its past the Mercury has had a new exhaust and instead of using the factory mounting holes in the bumper iron like they did on the left hand side, Someone used a self tapper to screw the right exhaust rubber to the trunk floor, which has pulled through.
    Using the same hardware Ive rewelded the dropper so the rubber now bolts to, yes you’ve guessed it, the factory holes for the exhaust mount in the bumper iron.
  12. Oneball
    Oneball
    Okie Pete, 67drake, 61Cruiser and 3 others like this.
  13. Oneball
    Oneball
    Decided to put my big boy pants on and sort out the wobbly heater core. It’s been rattling around like a ***** in a bowler hat. It’s been never ceases to amaze me how much h***le it is to get a heater core out. At least it’s not dash out on this. IMG_4941.jpeg
    Replaced the foam around the core and the stuff on the flaps which had been blowing in my face when Ive had the demister on.
    The boot from the heater to the scuttle had disintegrated so replace that with some foam too that should hopefully seal up to the sheet metal.
    Okie Pete, RMR&C, 61Cruiser and 4 others like this.
  14. Getting the fundamental equipment to operate as designed, can be just as gratifying as the high profile items.
    61Cruiser, Oneball and Sharpone like this.
  15. ClayMart
    ClayMart
    God, I love that kind of talk! Or should I technically call it banter? Well at least you shouldn't have any problems with the catwalk . . . ;)
  16. Oneball
    Oneball
    Getting married on Saturday. Thought I’d test out my knot tying!
    Okie Pete, 1oldtimer, 67drake and 5 others like this.
  17. Jeff Norwell
    Jeff Norwell
    MODERATOR
    WELL CONGRATS!
  18. patsurf
    patsurf
    well done on the casual understatedness -send a pic of the proceedings please-bravo!
  19. Sharpone
    Sharpone
    Congratulations
    Dan
    RAK and Oneball like this.
  20. Oneball
    Oneball
    Thanks Jeff and Sharpone.
    We’ve been living in sin for 12 years, it’s been coming a while!
    Jeff Norwell and Sharpone like this.
  21. patsurf
    patsurf
    :D:p
  22. 61Cruiser
    61Cruiser
    Congratulations to you both. Hope you have a long and happy marriage.
  23. Oneball
    Oneball
  24. patsurf
    patsurf
  25. Sharpone
    Sharpone
  26. RMR&C
    RMR&C
    from NW Montana
    Awesome, congrats!
  27. Okie Pete
    Okie Pete
    Congratulations. Wishing the both of you many years of happiness
  28. Oneball
    Oneball
    Serviced the Merc, adjusted the front tracking and changed the rear shackle bushes so hopefully a little more stable at high speed. Now started packing ready for my trip to France next week. Having such a big trunk means I’m not exactly economical with loading it!!
    61Cruiser, patsurf, bobss396 and 4 others like this.
  29. Oneball
    Oneball
    Morning from Normandie
    61Cruiser, Sharpone, RMR&C and 3 others like this.
  30. patsurf
    patsurf
