Technical Chevy bolt pattern wheels on a Ford.
Discussion in 'Traditional Hot Rods' started by billsbird, Sep 29, 2025.
  1. A friend of mine has a '55 Ford & found some wheels that have a Chevy bolt pattern. How can he get these to fit? Thank you! Bill
  2. poco
    poco
    from oklahoma
    You will have to use adapters
    billsbird likes this.
  3. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    Or else REDRILL the needed pattern on your present brakes providing there is enuf room to make the change!!! IMG_1273.jpeg IMG_1256.jpeg
  4. oldolds
    oldolds
    There are 4 ways to do that.
    1 Redrill the wheel
    2 Redrill the drums.
    3 Use adapters. That probably will not work on a that year T-bird because of clearance on the rear wheel openings.
    4 Buy wheel that fit.
  5. jnaki
    jnaki
    Hello,
    Unless there is really something special in those Chevy wheels, it may not be worth it to spend money on redrilling the hubs to fit them on a Ford. Adapters have been used, but it may make it unstable and slightly wider.
    What I wanted was the look of a set of American Racing Equipment 5 spoke mag wheels. But, the cost was horrendous and out of the question. I was able to buy a set of Buick Skylark wire wheels (5) for the cost of two 5 spoke mags. No, they were not stolen. The previous owner got some 5 spoke American Mags, so, it was a reversal of sorts...
    Unless your new rims look like these Buick Skylark Wire Wheels that actually were worth the effort to have a machine shop do the modifications to the hubs and axles to fit them on my 58 Impala. It may not be worth it.
    That changeover was worth the effort to pay someone to do it right. No adapters and the new look was outstanding.
    upload_2025-9-29_4-47-59.png Thanks to @themoose
    Each spoke was tightened, had Loc-***e on each nub and each individual wheel was trued and balanced. All that was done made the 58 Impala fast and gave it a one of a kind (at the time) custom look for a 58 Impala.
    But a year later, this was the final look prior to selling it to a young friend for his new, fast adventures. It helped my next adventure of going off to college, too.
    Now, he had the only Impala in the USA with black Buick rims.
    billsbird and themoose like this.
  6. Happydaze
    Happydaze
    Ford wheels are getting scarce? ;)
    Chris
    billsbird and lothiandon1940 like this.
  7. squirrel
    Buy a Chevy, or buy Ford wheels.
    really, is that that difficult to understand that you have to buy parts that fit the car you have?
  8. Bandit Billy
    Bandit Billy
    I heard that Fords came with a factory option for chevy engines and transmissions, I just ***umed you could order chevy bolt patterns as well. Keep it in the family.
    deadbeat, X-cpe, Driver50x and 6 others like this.
  9. chevy57dude
    chevy57dude
    Front or rear? Get new axles or yours re drilled. Show us the Chevy wheels and maybe someone will buy them so you can get what actually fits your car.
  10. Or do like my BIL did in the '60's. Hog out the wheel holes and get some large flat washers.:eek:
    X-cpe, Just Gary and billsbird like this.
  11. 1971BB427
    1971BB427
    from Oregon
    Not all wheels can be redrilled. Some have raised bosses around the holes and by moving the bolt pattern it ends up outside the heavier area. If they're not fully flat on the backside they can't be redrilled.
  12. gimpyshotrods
    gimpyshotrods
    What wheels are unique or rare enough that it would be cost effective to buy them, and then pay a machinist to make the necessary modifications?
    Most OEM Ford axles from the HAMB-era have at least one access hole drilled in the flange, disallowing a re-drill, unless it is filled (>>$$), or you buy aftermarket axle shafts (>>>$$$).
    Pattern adapters work, but in order to be strong enough, the need to be at, or over about a inch thick.
    05snopro440 likes this.
  13. The front. He's putting a new rear end in so he can just get the Chevy bolt pattern for the rear. I haven't seen the wheels but he says they're American mags at a good price.
    chevy57dude likes this.
  14. Thank you for the replies everyone! Thank you to include the 'wise *** remarks' cuz I like to laugh!
    Driver50x and Happydaze like this.
  15. twenty8
    twenty8
    Is he still here to tell that story...???:confused:
  16. 05snopro440
    05snopro440
    If you found wheels that don't fit your car, you didn't find the right wheels. Even if you want to swap the car to 4.75, you'll then need a new spare tire and it will forever be 4.75. Not a big deal if it's a hot rod, pain in the **** if it's a cl***ic.
    Unless you're doing a custom build where you can choose your bolt pattern just get wheels that fit the car, end of story.
  17. gimpyshotrods
    gimpyshotrods
    What brakes are on the front? Are they original drums, or aftermarket discs?
    Original hubs and drums can likely be re-patterned, although I would suggest new drums if they can be had.
    Aftermarket discs often use an Aspen/Volare rotor, for the Ford/Mopar bolt pattern.
    That rotor can be bearing swapped with a like dimension Camaro rotor, for a no machine work retrofit.
    billsbird and VANDENPLAS like this.
  18. The front drums can be redrilled. Or if he upgrades to discs in front, he can probably get rotors with the chevy pattern.
    billsbird, jimmy six and TERPU like this.
  19. nochop
    nochop
    from norcal
    Re drill, adapters always seem unreliable.
  20. 1971BB427
    1971BB427
    from Oregon
    Changing bolt patterns is hotrodding. My '39 Chev coupe has a ford rear axle with 4.5" bolt pattern, and I changed the I beam front axle spindles to 4.5" also so they matched all around. Easy job, and cheaper than redrilling wheels.
  21. jimmy six
    jimmy six
    I’ve drill new bolt patterns in axles and drums for years using a floor mounted drill press and a dual (or more) template. The plastic ones work fine. Put the template over the Ford pattern studs first and mark the 4-3/4 circle pattern, remove the studs, then center punch and drill.
    The main problem with this is the Chev wheel could be 7/16” instead of the 1/2” of a Ford. Wheels and drums should be centered on the axle center hub.
  22. brading
    brading
    If it is not possible to drill another set of stud holes in the hub you could do it this way using the original stud holes.
  23. dln1949
    dln1949
    Keep stirring Billy
    billsbird and Bandit Billy like this.
  24. Andy
    Andy
    Offset studs?
    billsbird and alchemy like this.
  25. swade41
    swade41
    from Buffalo,NY
    Almost all aftermarket "mags" have a 11/16's hole for the stud, it doesn't matter if it's a 1/2 or 7/16's stud. Whenever I get aftermarket axles I always choose the bigger 1/2 inch stud even in Chevy pattern.
    TagMan, billsbird and Driver50x like this.
  26. Bandit Billy
    Bandit Billy
    It's like fondue or that queso my wife makes in the croc pot for football parties, if you don't stir it coagulates on top. No one wants that on their Frito.
  27. Andy
    Andy
    It is hard to find late ford to Chevy wheel adapters. The long Ford studs is the problem. I think it is an insurance problem. I needed a set and ended up buying a set of Jeep adapters. They had the right bolt patterns but ended up having metric studs. I went thru the Dorman chart and found perfect replacement studs. They are the stock studs for Chevys. I had to cut the Ford studs shorter.
    I agree that bolt on hubs and drums is a possibility. It would take a lot of measuring. I had a Mullins trailer and it had 6 hole Chevy hubs and wheels. Somebody suggested 40 Ford hubs and wheels. They fit perfectly.
  28. GuyW
    GuyW
    adapters ****
  29. JimSibley
    JimSibley
    I have a 1970 camaro that the previous owner hooged out ford pattern slot mags for. He ran it that way for 30 years. I wouldnt do it, but it has been done with great success.
  30. RodStRace
    RodStRace
    You could knock out the studs and use these, but 20 of them are Expensive!
    Budget36 and billsbird like this.
