Technical Ford starter button does nothing when pushed
Discussion in 'The Hokey Ass Message Board' started by djweaz, Sep 29, 2025.
  1. djweaz
    djweaz
    from Tennessee
    I want to run my electric fan and electric fuel pump when I turn the key, Inalsonwanted to replace the hot battery cable so I figured what better time to get it done. . So last night I was changing my starter solenoid over to a 12v it was still 6v so that I could have both ignition and starter poles. I put the new one in but now when I push my starter ****on I get nothing.
    I can start it with the key on using my remote start trigger.
    I have continuity on my ballast resistor.
    All voltage in proper spots on the starter solenoid.
    Pulled the ignition switch I have voltage on one pole coming in. No volts on others until key is turned on.
    I switched back to the 6v same issue. Never had the issue until I tried switching it over.
    It’s something super simple and I am banging on my head trying to figure it out but I think it is making me into the simple one. Haha
    Does anybody have any ideas?
    Rob
  2. If you had a 6v. solenoid it activated by grounding the pole. 12 v. activates by positive voltage to the pole.
  3. djweaz
    djweaz
    from Tennessee
    I’m confused as to what you are saying. I put the new cable on the battery side and the existing cable on the starter side until I get a chance to change it and the wire that was on the S Pole I pit back on it’s original spot
  4. The dash ****on provides ground for the original solenoid. The new solenoid you installed needs a B+ signal to activate as it likely is grounded through the mount. To correct this, you would need the correct 12v solenoid with (+) and (-) small posts with the mounting bracket isolated. You would run a constant hot to the (+) side and connect the push ****on to the (-) side.
    Also I will add that the "I" pole on your current 12v solenoid is not for running accessories like your fan and such, it is used to byp*** the ballast resistor during engine crank so that the ignition coil receives full battery voltage to ***ist with getting the engine to light off.
  5. djweaz
    djweaz
    from Tennessee
    So my best bet is to just go back to my 6v solenoid?
  6. alanp561
    alanp561
  7. Or get someone knowledgeable in 12v conversions & automotive electrical systems to help you in person. Electricity does not care if you make a mistake, it will punish you in the worst way possible if it is able to. The last thing we want here is another car burned to the ground by electrical faults or leaking fuel, there have been plenty of threads on the HAMB showcasing total losses of cars from these causes.
  8. djweaz
    djweaz
    from Tennessee
    I just went back to 6v still nothing on the start ****on
  9. lostn51
    lostn51
    from Tennessee
    Stupid question, are you making it negative ground instead of positive ground?
    djweaz likes this.
  10. djweaz
    djweaz
    from Tennessee
    it was converted to 12v before I purchased it. The PO just flipped the wires and changed it from Positive ground to negative ground. I’m just trying to go through it until winter time comes and I can yank all of the old wiring out and put a new harness it. Then it will be so much easier to understand and read. I have no interior lights but I have turn signals headlights tail light wipers break lights oil pressure, fuel , 2 thermostats, fuel pump fan and a horn, blower motor for the heater even a cigarette lighter. Just wanted the fuel pump and the fan to run off the key, now I can only start it with my remote starter trigger because whatever I do the push ****on won’t do anything. At this point I just wish it would start off the ****on and I could walk away from it for the day.
  11. Ziggster
    Ziggster
    I went through the same thing with my 6V system when creating the wiring harness from scratch. lol! Still scratching my head…The thing that really three me off was the 3-pole solenoids I used for the starter and electric cooling fan for the rad.
    djweaz likes this.
  12. djweaz
    djweaz
    from Tennessee
    That’s what someone told me to do was to put the dan and the pump to the solenoid so they could run
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    Your starter ****on is a grounding switch. You could add a relay and use your original switch to supply the ground to the circuit that pulls in the relay and allows the current to go to the solenoid
  14. pprather
    pprather
    Or reinstall the 6volt solenoid. It will easily handle 12 volts as the amperage in the 12 volt system is half of the amperage required by the 6 volt system.
    And it provides the starter ****on ground connection you desire.
  15. While it's true that 6V solenoid can handle the 12V switching current with zero issues, the 6V solenoid coil doesn't like the 12V input to it. It will fail, sooner or later....
    pprather, alanp561 and Moriarity like this.
  16. pprather
    pprather
    @Crazy Steve , can you suggest a 12 volt solenoid that works as the OP desires?
    Such as from Cole Hersee or one of the rod parts sellers?
  17. BJR
    BJR
    Algoma56, Ziggster and patsurf like this.
  18. 24riverview
    24riverview
    Standard Ignition SS587 is a 12v version of the stock solenoid. Keep in mind the battery cable needs to go on a specific side of that solenoid (usually marked). If your 6v isn't working now check that cables are correct.
    choffman41 and Algoma56 like this.
  19. The cheapest and easiest one to find would be a winch solenoid. Most off-road places should have them, here's one for only $36 including shipping. Note this one has four big terminals and three small ones.
    New Heavy Duty Winch Relay Solenoid 12v 500A 12000lb Max For ATV UTV Truck 4x4 | eBay
    It's got a 500 amp rating, more than adequate. You won't use all the terminals, but it will do what you want.
    But the best (and cheapest) solution is do what Mark says in post 13. A $10 relay and a bit of wire using your push****on to operate the relay and use the relay to supply power to the 'regular' (and common) solenoid.
    If you've ever had a horn start blowing uncontrollably, it's because they're wired like the early Ford starter ****on, with the horn ****on supplying the ground. If the ****on or wire short to ground, you lose control. If you use a relay and power the relay coil off the ignition circuit and use the ****on to supply the coil ground, simply turning off the key will stop it. Otherwise, you'll have to pull a battery cable. This is why Ford changed it...
    That's a 4-cylinder Ford tractor solenoid and is listed for both 6 and 12V (???). Did the '53-57 Ford tractors use positive ground? May be what he already has...
    Right wiring, but another 4-cylinder bit, this time stolen off a Nissan.
    As to the cooling fan and fuel pump, you'll need a couple of relays again if you want to control them with the ignition switch.
    Algoma56, pprather and Moriarity like this.
  20. 29Sleeper
    29Sleeper
    from SoCal
    Apples and Oranges. Basically all coils are 6V (unless they are marked 12V). A 12V system uses a ballast resistor to cut the voltage to 6V at the coil. The Ford solenoid with 2 small terminals uses 1 to supply 12V from the start switch to the electromagnetic coil in the solenoid. That pulls a plate to contact the 2 large wires and supply voltage to the starter. The other small terminal also gets energized and supplies a full 12V to the coil (while the key is in start) for easier starting.
    The single terminal solenoid should show 6V (or 12V) on the small terminal when just sitting there. When that gets grounded it energizes the solenoid.
    The Ford 8N Tractor uses the same 6V solenoid. You can see the wire from the solenoid is hot and the switch grounds it to activate the solenoid.
    Algoma56 likes this.
  21. rusty valley
    rusty valley
    I've had the original ford ground ****on running the ford 6v solenoid running on 12 v neg ground for many years now, no problems. I like the old original ones with the manual ****on on the solenoid so you can start it from under the hood. You can but them new, sorry no part number, Cole Hersey I believe.
    djweaz and Algoma56 like this.
  22. djweaz
    djweaz
    from Tennessee
    The new 6v solenoid I have,is a Standard SS571. It doesn’t have any markings on it to determine batteries starter side. I tested my original 6v and it has no click when putting voltage to the S terminal. It has a sticker on it saying “Batt” for the Battery side so when I installed the 571 I set it up the same way. As you stated and I have seen in videos trouble shooting that they have to be set up on the correct side to work, I have not found a way to test which side is which so I flipped it upside down hoping that I could have had it reversed. Still won’t start without my remote trigger, still have no voltage going beyond the battery.
    I pulled the starter ****on to check out the configuration. Of it and put a jumper wire from it to the S pole it wouldn’t start with that method either. I am wondering if the starter ****on needs grounded so today I will try to ground it and use the jumper wire to try and start it. Hopefully that will work.
    I will say it is much easier to troubleshoot a 12v system, or maybe it is because I am used to a 12v system. The starter ****on is foreign to me so ai am trying to think of it as just a separated wire from the keyed ignition. I purchased this shoebox because it was basically a factory car. The Previous Owner had kept the same wires band switch it to negative ground and made it 12v. He added a 12v wiper system. The generator is from a 1966 F100 so it looks like a 6v generator to keep the look. I knew that I was going to replace the harness anyway so I wasn’t really worried about that for the short term. I just wanted to be able to drive it for the season. I actually have a new wiring harness being shipped. I just don’t want to take it down before winter.
    Just scratching my head as to what I am missing
    The ignition has Voltage when the key is turned on.
    The Ballast Resistor has around 3ohms when testing it.
    As Moriarity said, the starter ****on is a grounding switch. One of the things I found odd when I got the car was I can push the starter ****on even with no key in the ignition and it will crank but not start. I don’t like that it does that. I feel the system should be dead until voltage is out though it.
    If the only wire is the starter ****on wire on the S pole, where is it getting the feed from the Key? Unless when I took off the nut a wire fell off without me seeing it. I haven’t seen a loose wire anyplace below it. It could have happened because my garage isn’t the brightest. It’s starting to make me think I’m not the brightest either.
  23. Ziggster
    Ziggster
    I have the same solenoid and had to run a jumper wire to make the ign work after wiring it all up. Wish I was at home so I could explain what I did.
    djweaz likes this.
  24. djweaz
    djweaz
    from Tennessee
    Could be what I need to do
  25. Ziggster
    Ziggster
