Hot Rods Vintage Silver Beauty 206 Battery Charger
Discussion in 'The Hokey Ass Message Board' started by FatFndr, Sep 21, 2025.
  1. FatFndr
    FatFndr
    I have a vintage Silver Beauty Model 206 battery charger which is wired incorrectly. I cannot find a wiring diagram for this particular model online after many searches.
    I need to know where the power cables go as well as the positive/negative cable.
    If you have one (its come to this for me) could you open it up and make a simple wiring diagram of those cables referencing the transformer.
    Thank you
  2. FatFndr
    FatFndr
    Bump. Still searching.
  3. Budget36
    Budget36
    I’ll go out on a limb here.
    I’d ***ume the 120v goes into the input side of the transformer.
    There might be a rectifier out of the transformer, I’d (again on a limb) would think that’s where the cables go.
    But I’ve never had a battery charger apart, so I don’t know what switches one from 6 to 12 volts output.
    Good luck!
  4. tubman
    tubman
    Most likely a tap on the secondary windings of the transformer. There should be two outputs from the transformer to the 6/12 switch and one output to the rectifier.
  5. Budget36
    Budget36
    I did say I was “out on a limb”. :)
    But I’m guessing if the OP can find a schematic of a same era charger, it may be similar, ie Marquette, etc.
  6. tubman
    tubman
    Just helpin' out.:)
  7. 57Fury440
    57Fury440
    There is one listed on Ebay for $50.00. It says "remanufactured".
    Budget36 likes this.
  8. Budget36
    Budget36
    Oh yes, hope you didn’t take what I wrote in a wrong way.
    And I was teetering on the limb;)
  9. BJR
    BJR
    How about taking the back off and posting a picture of the inside? That may get some better replies from the electrical experts on board here.
    warhorseracing likes this.
  10. FatFndr
    FatFndr
    Thank you BJR, excellent idea, here they are, hoping for the best. I know little about transformers but I can solder.
  11. FatFndr
    FatFndr
    Ooops, didn't include the uploads
  12. sean2955
    sean2955
    I just so happened to pick one up yesterday so I will go ahead and pour it apart if you would like or you haven’t resolved your problem yet and take some photos
  13. sean2955
    sean2955
  14. sean2955
    sean2955
    The first image is where the negative goes to. The third image is where the positive ends up on the backside of that breaker
  15. FatFndr
    FatFndr
    Thank you very much. I see some things that need to be checked on my end. Where do the leads go to charge a battery? I'm thinking of making a drawing, which I'll publish here, and you can see if my wiring is correct or if I need to make some changes.
    Thanks again
    Algoma56 likes this.
  16. FatFndr
    FatFndr
  17. FatFndr
    FatFndr
    OK, I know, I forgot to include the drawing I made. Getting old and keeping up is getting harder, here it is. Silver Beauty Wiring Diagram.jpg
