Hot Rods Has Anyone Taken Her Advice Lately?(Photos)
Discussion in 'The Hokey Ass Message Board' started by LOU WELLS, Sep 25, 2025.
  1. 29Sleeper
    29Sleeper
    from SoCal
    Look on the bright side - once you are past the wear bars you'll have none of those traction robbing air spaces in the tread.
    flatheadpete, Stogy, Sharpone and 3 others like this.
  2. jnaki
    jnaki
    Hello,
    It is all for show and hopefully we all know that. Some folks still don’t get the picture. A catchy slogan for sure…
    If the time period is fairly accurate as to the activities in the film, the late 50s with the white Impala would be right in line.
    But, the one thing we learned is if one lays a strip of dual tires smoking off of the line, you lose.
    Even on the street, if one lays a strip on the surface, the opponent is off and running away. So, we learned fast and with our 58 Impala, the stock tires for cl*** compe***ion was always pure rubber on the tarmac. When we put on the Bruce slicks during the timing runs prior to the eliminations, again, traction was the name of the game and those slicks were always an up in speed and low in e.t. times. No smoke off of the starting line.
    No smoke from the tires, just traction for the best times.
    Jnaki
    When we got the new C&O Stick Hydro installed, there was no way to peel away at anytime. Every start from a stop light or on our Cherry Avenue Drags location provided pure traction. By the time the other driver realized it was GO, the Impala was about two car lengths ahead with the Positraction 4:56 gears and the C&O Stick Hydro doing its fast get away action.
    So, as several TV shows always show burn outs from the position on a street, , they never do those burn outs when the timing lights turn green at the certified dragstrip location. Green light means pure traction and no loss of traction from burning tires leaving a trail of smoke… YRMV
    We are not John Force Racing cars with 10000hp motors, too…yikes!
  3. gene-koning
    gene-koning
    My 49 pickup tends to be a bit light in the rear and is bit nose heavy. With a V8, and over 4,000lbs weight, the single wheel drive does lack a bit of traction if I step on the gas pedal too hard from a standing start. I'm an old man, so I try hard not to "peel out" intentionally, but sometimes I overestimate the traction level. I usually let off the gas when the tires remind me about the low traction. There probably really isn't much difference in the "peel out" if I let off the gas, or kept in it until the traction caught up, but by letting off I can cover it with an oops, and not look like I'm trying to show off or something.
  4. whiteknuckle
    whiteknuckle
    from Dryden, NY
  5. s.e.charles
    s.e.charles
    i still giggle when i fart. let's face it: they're magical.
    you can be in a room with 20 people, somebody squeaks one out, and No One thinks it's the door hinge, or a chair was dragged across the hardwood floor . i mean, they're
    like snowflakes for crying out loud. each has its own little personality.
    i think it's a gift.
    41 GMC K-18, 427 sleeper and twenty8 like this.
  6. LOU WELLS
    LOU WELLS
    from IDAHO
  7. jamesgr81
    jamesgr81
    The Cherry Ave drags....
    A good buddy of ours was burning rubber on the back street behind Harbor Chevrolet. 1967 SS 396 Chevelle. Pretty fast car. When he pulled out onto Cherry just up the street from Reath Automotive the cops were waiting. They wrote him up for exhibition of speed without seeing anything, just from the sound. I laughed and asked if he thought he was at the sonic drags. Evidently LBPD did.
    Anyhow down at 415 W. Ocean Blvd, sadly one of our often visited locations, the Long Beach Courthouse, we sat as he took the case to court. The judge got mad at the cops and chewed them out for writing him up for what they didn't see. They never figured he would take it to court. A small victory but unfortunately, we usually ended taking traffic school, or just paying $40.00.
    41 GMC K-18, Russ B, Stogy and 2 others like this.
  8. deathrowdave
    deathrowdave
    from NKy
    After buying the Tiger , everyone local that has one has stopped by , with their car . It’s a different crowd of people than usually stop by ! But one guy says hop in let’s go for a ride . His Tiger will peel out with the best of anything , traction is not going to happen well in a well prepped Tiger . I used to peel out plenty with a hot 90 plus cubic old Harley , but those days are gone also . Thanks for the memories
    Sharpone and LOU WELLS like this.
  9. Last time I tried that I broke an axle key......
    My fault, the nuts were not very tight, after lapping the side that broke and torquing, I may be ok but what a PITA.
    Stogy, Sharpone and LOU WELLS like this.
  10. seb fontana
    seb fontana
    from ct
    Last night! I forgot how hard my stick car launches, especialy with the new to me radial rear tires. First one was not much rpm at launch, testing the waters so to speak, a little tire noise.o_O Second one I came out at 5k,:eek:!
  11. 34 5W Paul
    34 5W Paul
    from Fresno CA
    My long-time neighbor jokes that I am "tractionally challenged" which is pretty fitting. Was driving the hot rod around a bit and my across the street neighbors were out. Meghan shouted "do a burnout" so I felt like I had to oblige. This isn't really a burnout just a 25mph roll. (Tried to imbed the vidya but TJJ says this is not a valid link???)
    https://youtube.com/shorts/lIx6o3yjG3Q
  12. chevy57dude
    chevy57dude
    No pic of the crime but I laid a good patch today cruising with these dudes. 20251003_103214.jpg 20251003_103106.jpg
  13. warbird1
    warbird1
    Yeah, "accidently" hit the pedal in my roadster a bit too much on the way to the shop this morning...
  14. topher5150
    topher5150
    Someday soon.... hopefully
  15. swade41
    swade41
    from Buffalo,NY
  16. wheeldog57
    wheeldog57
    Today I went around the block in the roadster, half way around I knew that one needle and seat was stuck- leaking. So I pulled over at an intersection, opened the hood, and tapped on the carburetor, all good. As I am closing the hood I noticed about a half dozen old dudes in their lawn chairs sitting on the front lawn, they are all looking my way. I get in, and proceed to do a giant, melty burnout leaving the stop sign. They were cheering and clapping! Made my day too!! 1759699034650978821756475406767.jpg
  17. twenty8
    twenty8
    You really should get that over sensitive throttle pedal fixed.............................. one day.
  18. wicarnut
    wicarnut
    Funny story, years ago my step son Jim called and asked to bring the flatbed trailer as his car had a trans problem, So I hook up the trailer and find him and his car on the road with the sign pictured, huge puddle of trans oil under his car. As I'm walking up to him the first thing he tells me, the rubber lines on the road was not him, Hmmmm, I don't say anything, we load the car up and take it back home, his Mother rips him a new one and I'm trying not to laugh, thinking back how many times my Dad towed me home with a chain, I got real good at keeping the chain tight. All said and done I did ask him if he learned anything today, his answer was, yes as he is looking at has shoes. Good kid, turned out to be a good adult. I have many stories of me driving like a dumb *** in my youth.
  19. Haven't peeled out for a while, but do like the "chirp" you get when it hits second gear just right.
  20. Nope, tire smoke see wasted horsepower! Hook it up and go!
    A Dale Inman (Richard Petty's cousin and an 8 time championship winning crew chief) quote on victory lane burnouts.
    You don't see the winner of the Kentucky Derby get off his horse and start beating the **** out of it!
  21. chevy57dude
    chevy57dude
    This ain't the Kentucky Derby, and these are cars, not horses. He can go piss up a rope.
    A little burnout is not beating the **** out of anything.
    swade41, bowie, LOU WELLS and 2 others like this.
  22. Just the other day I let fly with my off topic car.
    I'm not gonna lie, it still felt great!
    Toms Dogs, Sharpone and LOU WELLS like this.
  23. Koz
    Koz
    That will cost you $ 1,100.00 in Wildwood. Ask me how I know...... might be the best money I've ever spent. ()Didn't do **** to discourage my juvinile behavior though.) Technically it's called "Did embed rubber in a public roadway". Lots of fun if you're not endangering any spectators.
    LOU WELLS, Sharpone and bowie like this.
  24. wicarnut
    wicarnut
    Thinking about this subject, now 77, once in a while my inner child shows up, still alive and well and I stand on one of my cars, need for speed Never dies in my case, it has diminished with time. My Dodge Magnum RT hustles along pretty good, love the feeling, brings up memories, life is good. Funny story, had the Dodge on a cruise UP Michigan and I let her RIP and thought man for a big ole car, this 5.7 Hemi pulls pretty good as the sheriff coming toward me up out of a dip in the road, flips his lights on. Hmmm, ****ski, how much is this going to cost me. I pulled over instantly, he asked, do you know how fast you were going, my answer, Too fast Sir. He stated 120 on his radar and we get talking and he's a car guy. He writes me a ticket for 77 in a 55, $280 and 6 points, very big break IMO. My insurance agent ripped me a new one over this event ( wife is in the insurance business) and I heard about this for a while. I always say, I'm a lucky man in so many ways, been married 41 years together for 45 years., dragged her to every **** hole dirt track in the Midwest in my racing days, again I'm a very lucky man ! Everyone Have a Great Day ! My am coffee and the HAMB, pretty good start of the day.
    Sharpone, 41 GMC K-18, GuyW and 2 others like this.
  25. duecesteve
    duecesteve
    I always thought the red 8 sided sign meant " Spin Tires On Pavement "?:) OIP.jpeg
    Jeff34, Toms Dogs, Sharpone and 5 others like this.
  26. banjeaux bob
    banjeaux bob
    from alaska
    The big deal at my high school(Boy's Tech, Milwaukee) was to back your car up to the front doors and do a burn out. Usually done on a Saturday or Sunday night. You had to back up on the sidewalk to get to the doors. I never did that though. 14125003_10157307603940627_5095430853745151264_o.jpg
    duecesteve, Sharpone and LOU WELLS like this.
  27. deathrowdave
    deathrowdave
    from NKy
    Only means spin tires on pavement when the sign is outlined with white , optional on signs pay attention closely
  28. duecesteve
    duecesteve
    In high school '79,my friend had a'68 Bonneville w/421 duals 4door it was a wicked sleeper one night we were at the new Burger King in Hyannis and we did the driveupand asked for 2 more fries the guy said we had to drive around again ! My buddy got pissed they had words and then Danny proceeded to do a full on posi brake stand at the window it was awesome he filled the restaurant with fresh smoke, not from the grille we still laugh about to this day it was epic :)
    Algoma56, LOU WELLS and Sharpone like this.
