Art & Inspiration Tech School Students Doing Good
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Nov 7, 2014.
  1. Surface pattern for a firewall. 64 Chevy.
    340 in a mid 60s Dodge ***embled from pieces by students. IMG_8791.jpeg they rebuilt the drums as well.
  2. Fortunateson
    Fortunateson
    Sharpone and chryslerfan55 like this.
  3. ?
  4. Sharpone
    Sharpone
    You’re in the reflection
  5. Sure is:)
    That’s my Amish straw hat.
    When you have a lot of students on trips like this, it makes you EZ to find
  6. SBC test for in a mid 60s Dodge
  7. Dick Stevens
    Dick Stevens
    There's enough room in there for a BBC, or a Hemi! :D
  8. Cast iron is cast iron
    But free cast iron, now that’s special
  9. Wonder when the last time a teenager gutted a model A tank in shop cl***? IMG_9945.jpeg
  10. Un-street roding old Henry rails
    Nice weld on the shock mount
    Knocked it off with a hammer
  11. guthriesmith
    guthriesmith
    So...looks like you got the frame you mentioned. :D
  12. Ain’t it pretty:)
  13. Roached 32 rail was over 4 inches high at the nose.
    getting closer. Buckle at the cowl area is walking out
    Got all the street rod removed.
  14. Pressure, stress relieve repeat
  15. Nose of the rail was 6 1/2 inch high from datum (bottom of frame bench)
    We’re at 2 1/4 now
    no heat
  16. Todays Sr. discussion:
    Zero plane
    Centerline
    Datum
    Or length,width,height and 3 box/zone vehicle construction. Center, front and rear. All in that order.
    a lot of ugly still to remove from the rails. The plan is to establish original 32 specs then change to fit the A.
    Cut the rear rails just behind the cab. Then section the center part of the rails. Remove a 1 inch section from the center, wedge cut the front section of rail. Probably bob the front.
    The easiest way would be to fab a new top for the center frame section. Remove the top 2 inches, replace with a 1 inch tall section of bent angle (or a cut section of square/rectangle tubing). That would lower the profile and replace the crusty top portion of the frame.
  17. Cowl parts were successfully separated. Students drilled out the spot welds for the firewall/cowl sides.
    Parts are now soaking in mol***es
  18. Automotive cl*** next door got a new tool
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
  20. alanp561
    alanp561
    How cool is that? I guess that's way better than the old traditional way of packing a tube with sand, heating it where you want the bend, then you and your buddy grab the ends and bend it around a tree.
    Deutscher, porkshop, X-cpe and 4 others like this.
  21. willymakeit
    willymakeit
    Best set of cl***es I had was 50 years ago in autobody taught by Oscar Lewis.
    Besides skills with the right teacher comes a lot of life lessons for 15-18 year old boys at that time , that remain with them.
  22. 51504bat
    51504bat
    I had a really great machine shop teacher in HS. Mr. Lowery. He spent a lot of time "resizing" cigarettes with a band saw that students had in their top pocket. Never realized what a great guy he was until years later after he retired and lived near a friend of mine. I would see him walking his yellow lab and and enjoyed talking to him about everything under the sun. The school district did away with machine shop after he retired.
    Deutscher, porkshop, bobss396 and 3 others like this.
  23. 11 days in an 8:1 mol***es mix
  24. Johnny Gee
    Johnny Gee
    from Downey, Ca
  25. patsurf
    patsurf
    if you lick it....
    Okie Pete, SS327, porkshop and 4 others like this.
  26. Bout 2 1/2 weeks in the mol***es
  27. Sharpone
    Sharpone
    alanp561, porkshop and anthony myrick like this.
  28. New tool today. A self piercing riveter
    uses these IMG_0776.jpeg The tool will remove and install the rivets.
    Comes with several dies
    Here’s what it does
  29. Here’s a manual version. Much more economical.
    Good looking flush mount rivet.
    Okie Pete and porkshop like this.
  30. jaracer
    jaracer
    They used some self piercing henrob1.JPG henrob2.JPG rivets called henrobs at the Freightliner plant. I used to have a demonstration piece. Darned if I didn't find it.
