Technical SBC Rope Rear Main Removal "Tool"
Discussion in 'The Hokey Ass Message Board' started by HalfFastHotRod, Sep 30, 2025.
  1. HalfFastHotRod
    HalfFastHotRod
    Hello, long time lurker and official new member. Let me start this by thanking you all, for all the knowledge available on this page. I'm a hobbyist at best and have never had anything to contribute that wasn't covered a million times on here already.
    I've recently acquired a SBC 283 out of a '57 vette that will be transplanted into my '50 Styleline and decided all new gaskets would be a good idea before throwing it in there. This was the first time I've had the pleasure of dealing with a rope rear main seal. I've searched and scoured on tips for removing the block side half of the seal and between all the ripping and fraying I found myself with both sides 1/2" under the block surface and was running out of options. I have read mixed reviews on the "sneaky Pete" tool but I'm both frugal and impatient and did not want to spend the time and little bit of money waiting on a specialty tool to show up.
    A couple minutes with calipers, my computer and 3D printer I came up with a way to safely drive it out of its seat without marring any surfaces. I designed a seal shaped piece that rides in the groove and can be drove in using a plastic punch. Once my plastic punch would bottom out I could simply add another piece and continue driving it in, it took a total of 3 of these pieces stacked to get the remainder of the seal out but absolutely no damage was done and it saved purchasing another specialty tool that would collect dust in my box.
    I realize this is a very niche situation to be in but I wanted to share it if even if only one other person would find it helpful. If anyone thinks this would help them please reach out and I can provide an STL file for these pieces.
    Again, thank you all and I hope to contribute to this community. PXL_20251001_000355318.jpg PXL_20251001_000400005.jpg
  2. patsurf
    patsurf
    you are making all of us w. a sharpened stick look bad...
    tractorguy, SEAAIRE354, SS327 and 5 others like this.
  3. pprather
    pprather
    Welcome to the HAMB from Illinois.
    Neat tool hack!
    HalfFastHotRod, alanp561 and Sharpone like this.
  4. miker98038
    miker98038
    Nice solution. But done right, the sneaky pete’s do work. I’ve had mine since before 3D printing was a pipe dream. But good thinking in the modern world.
    SS327 and HalfFastHotRod like this.
  5. Fordors
    Fordors
    You are off to a great start, ingenuity goes a long way when you’re modifying cars.
    HalfFastHotRod likes this.
  6. panhead_pete
    panhead_pete
    Nice!. Thanks for the offer of sharing the file too! Very generous.
  7. HalfFastHotRod
    HalfFastHotRod
    Ha, my sharpened stick kept breaking. I must not have followed the instructions well
    SS327 and Budget36 like this.
  8. HalfFastHotRod
    HalfFastHotRod
    This was my last ditch effort before ordering one. Hopefully I never have to deal with another one but will keep it in mind if that day comes!
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Old seal must have been pretty stiff (?) in order for that to work. As the saying goes. “You can’t push with a rope”.
    SS327, Joe Blow and patsurf like this.
  10. Clydesdale
    Clydesdale
    In my fairly limited experience, removing the old one was the easy bit!!!
    You'll need the Sneaky Pete for installing the new one for sure.
  11. HalfFastHotRod
    HalfFastHotRod
    Would that only be for if I'm using a new rope seal? I have a neoprene replacement on order and just****umed it'd be similar to other SB 2 pc seals.
  12. garyf
    garyf
    If the main bearings are worn out,that new seal wont last long.
  13. HalfFastHotRod
    HalfFastHotRod
    It was pretty stiff, I'm not sure of the history of this engine but I saw no apparent evidence that it's been opened up before so it very we'll could've been the factory seal. You may not be able to push with a rope but can definitely force a rope to move a certain way if it has no where else to go and a big enough hammer and punch.
  14. Clydesdale
    Clydesdale
    That's very true, my experience was with the Stovebolt in my 51. No alternative replacement for them so new rope it was!!
