Unisteer?
Discussion in 'Off Topic Hot Rods & Customs' started by Towtruckjoe, Oct 1, 2025.
  1. Towtruckjoe
    Towtruckjoe
    I’ve read all the pros and cons of the Unisteer setup. I have a flaming river box with about 2-3K miles and lot of wandering at slow speeds. Highway speeds ok. Tried to adjust box but wasn’t much play in adjustment. Just wondering if anyone has some pics or dimensions. Some posts say horizontal shaft pokes outside drivers frame rail when turning and can hit the hairpins or 4 bars limiting turning radius. Also looks like Unisteer is mounted forward on their bracket. Does that make up for distance of the pitman arm on Vega box? Or is drag link going to be on an angle- will angled drag link affect steering? Angled front to back? Not parallel up-down. Everything is set up nice and parallel with my Vega box and company says it’s basically a drop in unit but Leary about dropping cash with no dimensions given. Any advice or photos appreciated Thanks in advance
    Tow Truck Tom and chryslerfan55 like this.
  2. Mike Lawless
    Mike Lawless
    I'm gonna replace the main boot on a Unisteer equipped '32 here sometime soon. I gal I know inherited it when her husband p***ed, so I've been doing some work on it. It's a nicely done car, (wishbone/dropped axle front) and I can get some photos, but it'll be several days. I don't have any other experience with 'em as of yet.
  3. alchemy
    alchemy
    Why not just get a good Vega style box from Borgeson? Direct bolt in, and will outlast the Chinese knockoffs.
  4. 2OLD2FAST
    2OLD2FAST
    from illinois
    And check the rest of the steering , including the axle, & also the alignment .
  5. 19Eddy30
    19Eddy30
    from VA
    @Towtruckjoe
    Are you New to car ?
    My opinion flaming River products are not that great.
    If new to car , Flex in steering components,
    Kingpins ,
    Box not 0 out @ installation & going straight.
    Wheel off set , tire pressure .
    Whats the caster , maybe needs more Caster
    How far away & angle of is the
    Cross-steer from steer arm ,
    I install keeping Cross steer to steer arm
    Like about 2 1/2 inch going straight .
    Tow Truck Tom likes this.
  6. Bandit Billy
    Bandit Billy
    When I built my Roadster, I used the Chrome Vega box from Flaming River but soon started experiencing the same issues as the OP. Not a tight box (insert pun here). I pulled it off and installed a Borgeson box and it made all the difference in the world. The only issue I had was the pitman arm (also chrome) was not fully engaging the splines as the nut was making contact with the shoulder on the shaft too soon so there was a bit of play. I machined a thick washer to push the pitman arm up the splines fully when the nut is torqued. Car handles great now.
  7. Bandit Billy
    Bandit Billy
    I was going to say, unisteer is hideous looking on a car without fenders. IMO. If it has fenders, I hear they are good handling but never drove one so I can't offer an experienced opinion.
  8. 325w
    325w
    Did unisteer on a 36 Ford sedan. It drove great.
  9. pprather
    pprather
    @Mike Lawless , when I replaced the outside boot on my unisteer I struggled.
    Un-installed the Unisteer so I could work on the work bench. Using four hands, two to hold rack and two for getting the boot in the groove, done in ten minutes.
  10. pprather
    pprather
    @Towtruckjoe , I like my Unisteer just fine. Over 60k miles.
    But I agree the Borgeson Vega box might be an easier fix.
  11. Mike Lawless
    Mike Lawless
    Thanks. I'll keep that in mind.
    pprather likes this.
  12. I'm a unisteer fan but there are many reasons mentioned that might be causing your problem.
  13. dadz34
    dadz34
    from Sanger, TX
    I've run a Unisteer since they released them for sale. I had paid $500 for a new high-end Vega box (not Flaming River) and it was just "meh", so while at the Nationals and the new Unisteer box was revealed, I was intrigued by the sales pitch and installed it as soon as I got back home. After my first drive, I was hooked and it's been one of the best changes I've ever made to my '34...and I gave away the almost new high dollar Vega box to a buddy in need. Zero regrets with my experience.
    There are lots of complaints about limited turning radius compared the the Vega, but it's never been a problem in my opinion. With a 383 stroker and ZF6-speed transmission, I cruise between 82-92mph down the freeway and only need 2 fingers to hold the wheel while changing lanes.
    As for the boot replacement, I too had to perform that exercise and speaking from experience...I think it was caused by not having the gear exactly in the middle and it strained the boot when going full lock. My Tudor has a 4-bar setup and Unisteer has never come in contact to the suspension.
  14. Mike Lawless
    Mike Lawless
    Just got done replacing the boot on this '32 Roadster. It was fairly easy. Did not have to remove the rack. Plenty of room to work.
    I think if I was gonna do a steering rack on something like this of mine, I'd seriously consider a unisteer. I think it would work on Ol' Furd too if I was of a mind.
    I did notice the lack of a jam nut for the shaft that connects to the box. I think that threaded section musta been welded or jammed to the bottom of the threads. I couldn't get it unscrewed without boogering the chrome any more than it already was. Outer tie rod end has a jam nut. It was loose. I went through all the steering and suspension bolts to make sure everything was tight and safe. Pams32Steering.jpg
  15. HOTRODPRIMER
    HOTRODPRIMER
    I had a pal that worked at the Chevy dealership and told me there was a brand new Vega box on the shelf in the parts department, I bought it, dust and all and it's still on my 32 sedan,never any problem. HRP
  16. poco
    poco
    from oklahoma
    Does any one make a unisteer for 49/50/51 fords?
  17. pprather
    pprather
  18. Happydaze
    Happydaze
    I was going to say Unisteer had folded some time ago, but seemingly not! Good news! I love the unisteer steering on my roadster.
    As regards the ops queries, on full lock the end protrudes from the frame about 2.5 inches, clears my hairpins. In plan view whether the swap alters the parallelism is a mute point. Must depend on the position of the vega mount and the related pitman arm length. I can't recall how parallel mine was with the vega box (I suspect not perfect by virtue of the motor mount) but with the unisteer it's not parallel, but not horribly out of alignment. Things remain level with the swap, but there is a shallower mount available, plus the standard mounting can always be refilled to change the height. Drives great nevertheless. I swapped from Vega to get quicker steering, and I'd say mine is perfect, for me anyways!
    Pics are worth a thousand words!
    Chris
  19. Ned Ludd
    Ned Ludd
    Lack of steering lock is due to limited travel within a very short rack & pinion unit, plus the length of the steering arm on the opposite-side spindle.
    The obvious way to increase lock, and quicken the steering at the same time, would be a shorter steering arm. Getting that to work is more easily said than done. It'd likely be a packaging nightmare, due to where various components end up.
    Another way would be to pivot the rack rod directly onto the tie rod, and not onto the opposite-side spindle. It means that drag-link-style spindles/arms can be used. That would give about 28% more lock, and 28% quicker steering. The difficulty would be in detailing the attachment so that the tie rod doesn't want to rotate around its own axis.
    Parallelity in plan does bear on steering geometry a bit, but it really isn't critical. Parallelity and ball-park similar length between the Panhard rod and the rack rod in front elevation is much more important.
