Does anyone know if the 1940 Mercury Eight 4 door & 1940 Ford Sedan use the same Scuff Plates
Discussion in 'The Hokey Ass Message Board' started by Charlie001, Sep 30, 2025.
  1. Charlie001
    Charlie001
    - Can anyone confirm if the 1940 Mercury Eight 4-door Sedan and the 1940 Ford 4-door sedan use the same Scuff plates. Can not seem to confirm this or find the needed mercury Scuff plates anywhere. Does anyone also know the part number for the 1940 Mercury eight 4-door sedan Scuff plates part numbers?
  2. pprather
    pprather
    I'm not clear on what a scuff plate is?
  3. Charlie001
    Charlie001
    Scuff plates are also known as door sales in other more modern cars. For the 1940 Mercury car this means a metal plate that then has rubber that hangs over the doorsill to the running boards of the car. My issue is I can’t seem to find anywhere that tells me where to order these from or if I can use the Ford version of the 1940 car my understanding is the mercury and the Ford are totally different Car designs by 4 inches longer and a bit wider
  4. pprather
    pprather
    @Moriarity , can you move this to the main board, where it will get more views?
    Thanks.
    Moriarity likes this.
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    Yup, moved to the main board. The antiquated forum is for NON automotive 65 and older "stuff"
    pprather likes this.
  6. lothiandon1940
    lothiandon1940
    My guess would be no they aren't interchangeable but, as usual, I could be wrong. The Mercury seems like a bigger car than the Ford and not sure the door openings would be the same.
  7. abe lugo
    abe lugo
    You have to check the wheel base if it's longer or the doors are longer the plate would longer.
    Call places like the old ford store or CW Moss maybe they have some of those pieces.
  8. deucemac
    deucemac
    Mercury for 39 and 40 were 4 inches longer in the body. For 1941, the 4 8nch increase was in the cowl forward. I owned both a 39 and a 41 Mercury.
  9. dwollam
    dwollam
    Get one for a Tudor '40 Ford and cut it down as needed?
    Dave
