Projects My New New Ride
Discussion in 'The Hokey Ass Message Board' started by grdra1, Sep 24, 2022.
  1. patsurf
    patsurf
    05snopro440 likes this.
  2. grdra1
    grdra1
    Finished and painted exhaust recently, so happy with how its turned out. Started on fuel tank today, decided to go with aluminum, a few pics, Glen 20251002_110517.jpg 20251002_110353.jpg 20251002_110344.jpg 20251002_132959.jpg 20251002_134641.jpg 20251002_155529.jpg 20251002_155801.jpg 20251002_155810.jpg
  3. grdra1
    grdra1
    A few pics of todays progress, fabbed up tank baffles and machined fuel sender unit bung ( I paid $45.00. for a sender mount kit but ended up making my own as mount kit was ****ing useless ). I need to practice my alloy welding as its been a while, approx. 3-4 years since I welded aluminum. Glen 20251004_180731.jpg 20251004_180738.jpg 20251004_180745.jpg 20251004_180830.jpg 20251004_180836.jpg 20251004_180915.jpg 20251004_181013.jpg 20251004_181730.jpg 20251004_182929.jpg
    catdad49, Stogy, RodStRace and 2 others like this.
  4. grdra1
    grdra1
    Fuel tank is still a work in progress, I ended up buying a new tig welder as my old unit had seen better days. They did not have a suitable foot pedal in stock so I needed to order one, when I receive the pedal I will start welding the tank, most of the tank is fabricated and just needs to be stuck together. While waiting for my pedal to arrive I fabbed up a cover for my rear crossmember, I also mounted my modified fuel cap, a few pics Glen 20251012_133843.jpg 20251013_122219.jpg 20251013_164000.jpg 20251011_170906.jpg 20251011_170913.jpg
  5. grdra1
    grdra1
    Welded up fuel tank today, still need to fab mounts and leak test and have certified, overall happy with result. Glen 20251014_172248.jpg 20251014_172319.jpg 20251014_172328.jpg 20251014_172335.jpg 20251014_180505.jpg 20251014_180511.jpg 20251014_190523.jpg af5fe910-9f33-4a4f-a613-cd6eadf72e75.jpg
  6. RodStRace
    RodStRace
    Nice! Will the sender R&I without pulling the tank?
  7. grdra1
    grdra1
    I didn't think it would, but I tried it today and it is changeable while in car. Glen
    catdad49 and Deutscher like this.
  8. grdra1
    grdra1
    Fuel tank done for now, I just need to pressure test myself before sending it out to be certified, today I started working on my firewall for distributor clearance and making my gearbox cover. My plan is to glue some 2 inch by 1/8 flat to the underside and bolt transmission cover to it ( this is how I fabbed the rear crossmember cover ). The cover will be made out of 16 gauge cold rolled sheet, I will also incorporate a provision for my Winters shifter. I was going to do in fibergl*** but like the idea of a removable cover, a few pics Glen 20251017_132132.jpg 20251017_135911.jpg 20251017_135918.jpg 20251017_135931.jpg 20251017_165810.jpg 20251017_184252.jpg 20251017_184300.jpg
  9. Rocky
    Rocky
    Classified Editor
    Nice! I had to "flip" the rear U-bolts so the nuts were on top to clear the quick change rear. Your mileage may vary.
  10. RodStRace
    RodStRace
    You might want to add a couple gussets to the neck. Lots of twisting and pull when that gets removed.
  11. grdra1
    grdra1
    Filler neck should be ok, lots of support in that area, pic doesn't show it, fuel cap side is machined out of solid, Glen
  12. grdra1
    grdra1
    A few pics of recent progress, I decided to fibregl*** area for distributer clearance, I will still fab a removable trans tunnel, a few pics, Glen 2cbf988f-94d0-4458-95d9-b24246b097bf.jpg 20251020_160334.jpg 20251023_163434.jpg 20251023_163437.jpg 20251023_163444.jpg
    catdad49, Deutscher, Robdski and 3 others like this.
  13. grdra1
    grdra1
    Fabbed up trans tunnel recently, happy with result, plenty of clearance all around, a few pics, Glen 20251027_164520.jpg 20251027_171843.jpg 20251027_171853.jpg 20251029_134151.jpg 20251030_192557.jpg 20251030_192608.jpg
  14. grdra1
    grdra1
    Next job was to mount my sidewinder shifter, it turned out that the shifter sat to low to reach and would have to be raised on some sort of mount. When I started to work out where it needed to be it was clear that it would not look that good and be difficult to operate if drag racing when strapped in, so I decided to fab a box to mount shifter inside and fab my own levers etc, I am unsure if I love the result but I do like it ( and no one else has one like it ), I still needed a reverse lockout function which is the reason for the second lever. I am also unsure of the shift knobs as the only aluminum rod I had was 30mm in diameter - I may fab some new knobs but will wait and see, I still need to mount cable etc. The Shifter still has all the functions of the original unit except the reverse lockout, a few pics, Glen 20251017_184252.jpg 20251106_114911.jpg 20251107_155854.jpg 20251107_180125.jpg 20251107_180129.jpg 20251107_180146.jpg
  15. RodStRace
    RodStRace
    No cup holder, phone buddy or other use for those big sides?
  16. grdra1
    grdra1
    No way will any cup holders or any other modern **** will be in this hotrod, I cannot stand cup holders in hotrods, I feel they look so out of place. Shifter is not quite finished, I may put the original sidewinder name back on the side ( the one in the first pic ) or hunt the internet for a cool sticker for the side of shifter housing. Glen
    RMcCulley, VI Lonewolf and AmishMike like this.
  17. grdra1
    grdra1
    Shifter on hold at present as waiting for new Knobs to be delivered although cable ***embly all done now. Next job is to install 2 speed wiper kit, today I fabbed up a windshield frame out of some old frames I purchased of a local hot rodder ( they were supposed to suit a 34 but they were all different ), there are 3 different sections all with different profiles but its gunna work. still to work out how to hinge and install winder ***embly, a few pics, Glen 20251113_122340.jpg 20251113_131222.jpg 20251113_131227.jpg 20251113_134652.jpg d7d9b222-6605-455c-87d2-1c56cc6f73a5.jpg b4b09c5f-cec1-42e0-83ec-262079cbab06.jpg 20251113_122604.jpg
  18. grdra1
    grdra1
    Shifter 99% done now, so happy with how it turned out, a few pics, Glen 22b2e69f-7a61-4da3-a2fc-661b75728151.jpg c5fdd2b2-f055-4a0d-83ad-84b9b6d4db05.jpg 20251120_164949.jpg 20251120_164934.jpg
  19. grdra1
    grdra1
    A few pics of todays progress, started mounting scissor winder and reinforced roof area for windscreen top hinges, Also purchased a pair of Holley carbs at a swap meet recently. Glen 20251122_134548.jpg 20251122_134558.jpg 20251122_163916.jpg 20251122_163921.jpg 20251122_172223.jpg 20251122_172232.jpg 20251122_172512.jpg 20251122_172551.jpg 20251122_172555.jpg
  20. grdra1
    grdra1
    I have spent heaps of time on this windscreen frame, very rusty / pitted and thin metal, also I spent a lot of time fabbing the hinges. The end product will look ok but will have limited movement due to hinge design, I fabbed hinges based on original type hinges but due to design of body / fibregl*** thickness etc etc, all these factors led to limited frame open position. I am happy so far as I have put in a lot of work into this frame. I will also have to paint unit as it was heavily pitted and very thin in parts - I will be using a chrome paint, a few pics of current progress. I also finished filling around vent and distributor recess. Next job is to make a windscreen frame gl*** template and then repairing some old inner front fenders to use on this build. Glen 20251114_142623.jpg 20251114_165736.jpg 20251114_165744.jpg 20251221_141418.jpg 20251221_141425.jpg 20251224_175026.jpg 20251224_175036.jpg 20251224_171151.jpg 20251224_171154.jpg 20251223_164348.jpg
  21. clem
    clem
    the end result looks good !
    ( I’ve done 3 x new ones on deuces and couldn’t believe the amount of work involved to get them working correctly, especially fabricating the hinges ).
  22. catdad49
    catdad49
    You really got it going, Glen. This should be quite the Street Beast! Merry Christmas to You and Yours, Carp.
  23. NJ Don
    NJ Don
    Nice fabrication skills!
  24. grdra1
    grdra1
    Thanks guys for nice comments, and Merry Christmas to all. I also fabebd up some side interior panels recently, I was gunna make them fancy with beads etc but decided against this as they wouldn't be seen anyway, they also needed to be recessed for seat belt retractor and bracket clearance. I painted them with a hammered copper paint, I will also paint the door trims the same color. A few pics, Glen 154b0b90-cd16-4efb-b42b-19864650b479.jpg 20251130_143349.jpg 69482e95-2544-4f2b-b8e6-8ef03276dab1.jpg faba9a52-fb5b-496c-881f-c23b0173c0a7.jpg
  25. @grdra1 just read the whole thread.Great work and skills! Keep the pics coming cause I'm hooked,lol! Merry Christmas down there!
    Robdski likes this.
  26. grdra1
    grdra1
    Thanks Bill, I still have so much more to do on this hot rod, so there will be plenty of pics to come. Glen
  27. grdra1
    grdra1
    I recently spent a couple of days sorting out inner fenders and decided to use a pair of gl*** units I purchased a couple of years ago - they fitted better than the steel ones. A few pics including finished windscreen frame, Glen 20260105_190421.jpg 20260105_190428.jpg 20260105_190459.jpg 20260105_190509.jpg d57ba912-3045-48e0-b780-00ab554c3b55.jpg d721a2a9-ccf8-470a-aee3-cfd86d8f5116.jpg
    5w Jen, Robdski, duecesteve and 3 others like this.
  28. grdra1
    grdra1
    A few pics from today, I mocked up headlights for the first time, I am happy with the result, I also painted the inside of coupe black, Glen 0ea1462b-e183-43e8-8859-f338925e2283.jpg 1fe65f5c-25a0-4ccf-8d64-53b9f7ce335a.jpg bfa9e8ad-a6f0-41de-a871-c4b89f9ce6ad.jpg dfb0a79e-eca8-4225-b9c4-2507cab17767.jpg 0fad6579-cdd5-4cc7-a76c-d6094b7c9058.jpg
