Build a bus? Why not?
Discussion in 'The Antiquated' started by iwanaflattie, Oct 2, 2025.
  1. iwanaflattie
    iwanaflattie
    Never finish anything.
    **** don't run that well,fkit,build one more.
    Screenshot_20251001_050054_Facebook.jpg Screenshot_20251001_050059_Facebook.jpg Screenshot_20251001_050110_Facebook.jpg 20250929_161533.jpg 20250929_161545.jpg
  2. iwanaflattie
    iwanaflattie
  3. slowforty
    slowforty
    I had a friend had a bus. Insurance company told him no more than 6 p***engers
    Sharpone likes this.
  4. Okie Pete
    Okie Pete
    Awesome. Looking forward to see what You build .
    chevy57dude and Sharpone like this.
  5. LOST ANGEL
    LOST ANGEL
  6. Lone Star Mopar
    Lone Star Mopar
    Well if youre building it, im sure it's gonna be cool !
    porkshop and Sharpone like this.
  7. iwanaflattie
    iwanaflattie
    I talked to a guy that drives a bus locally,he gave me a few pointers for insurance.
    Thanks.
    Is that from dumb and dumber?
    I sure hope so.
    I see that you also shortened between the back and the wheel opening...
    Did you have the high school army help you?
    I'll probably be by myself again,just my gantry,cherry picker and basic tools..
    I have an idea on how the final product will be..
    Story is that that guy bought it from an older guy in Az..it used to be an army bus..
    You can see some of the olive drab under the blue paint..
    I'm on the look out for a hood and front fenders..if you guys are bored and can keep eyes for something my way (online)
    51-52 f2 -f6 would be the same i was told.
    Hopefully will look like that minus the airbags.
  8. iwanaflattie
    iwanaflattie
  9. Yep. My army of misfits whacked up the bus
    Used gm c30 front suspension. Swuarebidy stuff
    Super EZ to drop
    Static
  10. iwanaflattie
    iwanaflattie
    I think I want to go with c30 suspension.
    The guy put the bus frame in the bin,I didn't have space or didn't want to remove the shell at my place,he offered to remove the body, cut AND load it onto my trailer..
    Poor *******.
    In the heat.
    And I got a ***le,,,I have a 55 vanette frame with straight rails,it would be easier to work on with the little space I have now, ill piece the suspension with marketplace stuff..I already found a c30 front suspension but it's 3 hours away...for 250..and ge can load it..I just don't have the space.
    porkshop, b-bop, Okie Pete and 2 others like this.
  11. Here’s a c10 graft to a 57 Chevy van ch***is
    Will plate the inside.
    The c10-c30 ch***is are 34 inches wide at the cowl area. Makes an EZ graft on an old ch***is.
    The track with is probably a good bit wider than stock on your bus though.
  12. iwanaflattie
    iwanaflattie
    I just measured my Ford E350(found another van with a 7.3 that might trade )but the track is too wide,so I measured my C30 track on my gmc coe and it fits better on the bus...
    I'm going with c30
  13. iwanaflattie
    iwanaflattie
    Question...how did you do your floor? Cut and ****weld?
    porkshop likes this.
  14. Plus easier and cheaper to drop
    porkshop and Okie Pete like this.
    Ours stayed on it ch***is. So that helped a lot. We chose cut locations, removed the not wanted section then the ****.
    It all went back in factory seams. We removed the factory wheel tubs as well. once the body was put back together we made tubs and the rear floor from new 14 gauge. Also built the floor around the frame notch.
    we put the floor back together like the factory. Just with the step and deeper tubs
  16. RMR&C
    RMR&C
    from NW Montana
    Seth, I have most of the front clip parts you need, but you know how far away I am from Vegas.....
    Cool project!
    porkshop and b-bop like this.
  17. iwanaflattie
    iwanaflattie
    Scott,I would love another trip your way..
    I loved your neck of the woods...
    I wanted to build a short bus,I always told my son it would be my last build,however it kinda landed in the middle..
    This was meant to be built in the sticks or in a nice full shop,not in a backyard in a quiet neighborhood in Las Vegas...
    I might just do as much as I can then put it in storage...
    Just too much **** to do.
    20251005_160817.jpg 20251005_160815.jpg 20251005_151818.jpg 20251005_151110.jpg 20251005_151108.jpg
    **** the guy that designed CLUTCH type screws!!!
    SS327, Squablow, Deutscher and 5 others like this.
  18. Roothawg
    Roothawg
    That’s a huge undertaking
  19. iwanaflattie
    iwanaflattie
    It seemed easy at first, thankfully not a lot of rust repair to be done.
    The guy messed up a bunch panels with the forklift and created more work than it needed.
    Roothawg and Okie Pete like this.
  20. iwanaflattie
    iwanaflattie
    Thanks,I removed one floor panel, just bolts holding it but I'll have to raise the shell after I brace it so I can crawl under to remove said bolts...
    Nasty work...I almost want to cut the floor itself where I can access the bolts from inside...
    What rivets did you use?
    b-bop and Okie Pete like this.
  21. The outside skin has regular pop rivets where we sectioned it. Welded structure.
    I’ve got real ones to replace the pop rivets with. Haven’t done that yet.
    Some parts had rounded Phillips head screws. The wheel house outer skin is screwed on
    makes changing the tire possible plus access to the gas tank.
    Deutscher, b-bop and Okie Pete like this.
  22. HOTRODPRIMER
    HOTRODPRIMER
    That's a lot of work, props to you guys.
    Not enough hot rod buses running up and down the hwys. HRP
  23. Front suspension on mine is Zd 4 inches into the floor.
    3 inch drop spindles and one coil cut.
    Add that to the front tire diameter difference and repositioning the front bumper. My fenders were 3 -4 inches higher than the bus body. So we extended them down along with the bumper.
    The front bumper height is 14-16 inches lower than stock
  24. Sharpone
    Sharpone
    Not to many can say I dropped my ride 14 - 16 inches
    Dan
  25. oldiron 440
    oldiron 440
    All I can say is why, and just because you can doesn’t cover it for me…
    Oversized ratrods is what I see.
    chlsnk and SS327 like this.
  26. Because I wanted to. No other persons blessing was needed. Simple concept
    A dropped bus was on my bucket list.
    This particular show along with others agree with your definition
    I just drive it with a big ole cheesy grin
    The paint is perfect
    simplestone, Deutscher, b-bop and 5 others like this.
  27. iwanaflattie
    iwanaflattie
    Good to know,ill have to bolt the front end to see how much is higher than stock,I told the guy to save the bumpers,the only thing worrying me it's the curved gl***,I might have to weld the curve shut and just do flat gl***.
    Not enough short buses around.
    Right?
    I'm used to ride the short bus so I want to relive my childhood
    Squablow, Deutscher, b-bop and 5 others like this.
  28. The curved gl*** is almost impossible to find
    I’m glad mine is flat
    when I got a tag the DMV lady asked me how many p***engers it held. Honestly at that moment it only had one seat so I guessed and said 8-10. Lady said good, I’d need a CDL if over a certain amount. Not sure what that is.
    For insurance, I called and gave my agent the vin. They sent me a bill. Done
  29. Okie Pete
    Okie Pete
    Awesome work guys ( I want a flattie) & ( Anthony) . Keep building big rods . Keep saving odd things and getting them back on the road . I for one understand and appreciate the work your doing.
