Hot Rods MY 31 THINKS IT'S A 32
Discussion in 'The Hokey Ass Message Board' started by ALLDONE, Sep 24, 2025.
  1. ALLDONE
    ALLDONE
    Been working on this more door 31 for a while, today went on a 40 mile trip... dang she's running good.. I put 32 grille... frnt/rr bumpers.. motor, fuel tank. whacha think?
    mvee33, hotrodjack33, Stogy and 10 others like this.
  2. 5window
    5window
    Looks good but it appears there is an awful lot of stuff sticking out the rear end. Camera angle maybe?
    Stogy likes this.
  3. 19Eddy30
    19Eddy30
    from VA
    IMG_4023.png When I did this one , I made my own
    Kit from 32 cut off's . Tank under father
    Higher , & little tilt for rake .
    Stogy and LTM75110 like this.
  4. Mr48chev
    32 tanks are way more visible on a Model A than they are on a 32 or at least the "Look at me " factor plays big. Black paint should take care of a lot of that though.
    Stogy and Kiwi 4d like this.
  5. ALLDONE
    ALLDONE
    mine is in farther from looking at the pics..
    Stogy likes this.
  6. ALLDONE
    ALLDONE
    that tank is getting swapped with the one on the 32 coupe..
    Stogy likes this.
  7. ALLDONE
    ALLDONE
    I hauled this 31 to kanab utah... got there and the brake peddle went to the floor and it wouldn't start.... wanted to have it there because it's so dependable.....lol... hauled it back to vegas..
    Stogy likes this.
  8. 19Eddy30
    19Eddy30
    from VA
    Not for sure ,
    Your 31 rear shape @ bottom of body looks to be made different
    Then mine ,,,
    Yours looks more of a curve lower portion , Maybe looks that way because shinny pair , & silver reflecting making in a optical illusion..
    I do not know enough about that part of rear body panel same ...
    My tank I made EFI before they where made , I was unable to stick father under , there was a body brace , & I did not want to modify to clear pump & I was using # 10 high flow smooth feed with # 8 high flow smooth return.
    Also I made fuel pick up inside towards rear so pump did not starve for fuel on hard accelerations .
    ALLDONE and Stogy like this.
  9. Stogy
    Stogy
    Looks really good @ALLDONE...a vintage hop up, so the red tank is going on the sedan...black as suggested would tie in with the fenders in a wrap around like the top...red would match the rims but still look out of place, kinda sorta...it's your call. Sounds like the Shakedown is underway...have fun with it!
    Congratulations
    ALLDONE and hotrodjack33 like this.
  10. Greenblade
    Greenblade
    When I get back to working on my '30 sedan I would like to put a 32 tank in the back. I like the look and not having a gas tank above my lap
    Stogy and ALLDONE like this.
  11. winduptoy
    winduptoy
  12. ALLDONE
    ALLDONE
    I have to paint both tanks, and have to remove them the 31 will be painted black...might try to put frame horn covers also
    Stogy likes this.
  13. ALLDONE
    ALLDONE
    I think it didn't like Utah
    Stogy likes this.
  14. ALLDONE
    ALLDONE
    B motor with son built headers and working lake pipes...39 trans 7.1 head fsi ign. and elect. over drive
    IMG_8807[8523] (1).jpg IMG_8807[8523] (2).jpg IMG_8807[8523].jpg IMG_8810[8526].jpg
    dwollam, mvee33, 51 mercules and 5 others like this.
  15. ALLDONE
    ALLDONE
  16. winduptoy
    winduptoy
