Technical Arcing from coil
Discussion in 'The Hokey Ass Message Board' started by 4211papas34, Oct 3, 2025.
  1. 4211papas34
    4211papas34
    from chicago
    Hello gents was wondering if someone could give me a little help I have a small block Chevy with an external coil I changed the plugs and wires recently and upon startup I noticed that
    The coil was arcing from both the positive and negative side any suggestions on what can be causing this
    My thought process is
    First double check all the electrical connections to make sure they're correct which I did
    change out the coil for a new one
    I'm thinking an extra ground strap could not help currently there's only one on the vehicle
    And that is the extent of what I can think of any suggestions would be appreciated thanks
  2. jaracer
    jaracer
    Open high tension coil wire. If it arcs a long time it will carbon track the coil tower.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    That coil wire boot looks loose (too big)? Coil being wet on top. Is it just moister or is the coil cracked? IMG_4730.jpeg
    Mr48chev and Algoma56 like this.
  4. tubman
    tubman
    That coil looks pretty dirty and oily. I suggest a complete physical cleaning of the ignition system.
    1971BB427 likes this.
  5. 1971BB427
    1971BB427
    from Oregon
    Dirty coil, cracked, and poor fitting boot. I'd swap in a new coil, and bet it fixes the issues.
    57Fury440 likes this.
  6. 4211papas34
    4211papas34
    from chicago
    I'll give it a shot right away I did notice the new coil wire has a cap that is significantly smaller than the last one I'm going to grab the old cap out of the trash put it on and see if that makes a difference
  7. winduptoy
    winduptoy
    jet996 likes this.
  8. Mr48chev
    Three people said the same thing I thought even before I saw the photo. DIRT AND MOISTURE plus a possible crack.
    Step one, take the coil out and clean it up so it is clean and dry and inspect it closer for a crack.
    Algoma56 likes this.
  9. 4211papas34
    4211papas34
    from chicago
    Thank you to Tubman and all the other replies so I took some brake clean and a rag voila I found the issue thanks again for the help guys
    ras likes this.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    J. A. Miller and Moriarity like this.
