Technical Angle Plug Heads
Discussion in 'The Hokey Ass Message Board' started by Racingsnake, Oct 5, 2025.
  1. Racingsnake
    Racingsnake
    from So Cal
    IMG_5341.jpeg IMG_5340.jpeg IMG_5339.jpeg I’ve got a small block Chevy with Brownfield aluminum heads that I want to run in my '64 El Camino. Problem is it has angle plug heads and I’m not sure what headers will work. Some headers that state they work with angle plug heads have a note that it is only GM style angled plugs - I think that means they are just angled inwards and not rolled down as well like the Brownfields. Not been able to find a whole lot on Brownfield heads so not sure whether any more modern heads have the same plug angle.
    Anyone run these heads or know a header that would work in my application?
    Tow Truck Tom likes this.
  2. Dan Hay
    Dan Hay
    IMG_0186.jpeg I have angle plug heads, I used a block hugger header for angle plug. Notice the primaries for the end cylinders bump out more for clearance. I also used shorter plugs for additional room. They are accel but I don’t have the part number at the moment View attachment 6539726
  3. Racingsnake
    Racingsnake
    from So Cal
    Thanks, looks like those are the GM style heads that angle the plugs in but don't roll them down like the Brownfields do. Don’t think shorties would work on the El Camino.
  4. Ericnova72
    Ericnova72
    from Michigan
    Brownfield turned into Air Flow Research (AFR); you might contact them and see if they have any info..
    mad mikey and INVISIBLEKID like this.
  5. Racingsnake
    Racingsnake
    from So Cal
    Thanks, that's a good idea
    seb fontana likes this.
  6. 28rpu
    28rpu
    You may need to build a set of headers to fit your application. Give it a try. Some flanges, J bends and collectors. It's a fun skill to learn.
    mad mikey and RMR&C like this.
  7. swade41
    swade41
    from Buffalo,NY
    Fenderwell headers, the answer is always fenderwell headers
  8. 19Eddy30
    19Eddy30
    from VA
    If Not using Fenderwell headers
    Make Sure header 's are for Angle plug heads ,,
    Angle plug headers are even a better
    Choice for regular straight plug heads
    Spark plug clearance / room .
  9. 1935ply
    1935ply
    from peyton,co
    My experience with older brownfeild heads was for racing only. I agree you will probably have to build a set of headers, not only to clear the plugs and wires, but to fit the El Camino.
  10. Racingsnake
    Racingsnake
    from So Cal
    Not really looking to build headers for this or run fender wells - it's just supposed to be my daily. Probably going to put the motor in something that I can run fender wells on
  11. 28rpu
    28rpu
    They are certainly easier to build versus inside the frame.
    427 sleeper likes this.
  12. 1971BB427
    1971BB427
    from Oregon
    I put a pair of aluminum angle plug heads on my Austin g***er that has Patriot fat fender fenderwell headers on it. I could barely get to the two front spark plug on each side of the engine. I bought two expensive Accel shorty plugs to make getting a spark plug wrench on them easier. Eventually I took the heads off and went back to straight plug heads and no issues. I can put a spark plug socket right on the ratchet handle and change plugs.
  13. mad mikey
    mad mikey
    Or go the ROADKILL method and dent them in until you have clearance.:D
    seb fontana and 19Eddy30 like this.
