Technical AutoMeter face falls off
Discussion in 'The Hokey Ass Message Board' started by milwscruffy, Oct 5, 2025.
  1. milwscruffy
    milwscruffy
    Anyone ever have the bezel and glass lenses fall off a tach ? I went on a 290 mile cruise yesterday, got up early to clean the wagon, when I went to wipe off the tach the bezel and lenses falls in my lap. I will be calling AutoMeter in the morning as it being a Sunday would be pointless. The tach still works just fine and attempts to reattach it were not successful. Just wondering if anyone else has had this happen and if there is a home brewed fix for it. Thanks !!! IMG_3997.JPG IMG_3999.JPG IMG_4001.JPG
    Stogy and bchctybob like this.
  2. squirrel
    is the crimp just a bit too loose to hold it?
    Stogy, bchctybob, alanp561 and 2 others like this.
  3. BJR
    BJR
    Why did they blow the whistle at a leper hockey game?
    Because there was a face off on the ice! :D
    Sorry, but I just couldn't resist.
    Stogy, bchctybob, SS327 and 3 others like this.
  4. gimpyshotrods
    gimpyshotrods
    Can be had in a multi-pack, with accelerator, on that rainforest site.
    https://bsi-inc.com/hardware/hardware.html
    Stogy, bchctybob and milwscruffy like this.
  5. milwscruffy
    milwscruffy
    That would be my guess and a manufacturing flaw. Going to bend up a couple small flat 90 degree pullers and see if I can persuade it back into place as getting to the wiring to pull the unit out will be a pain.
  6. milwscruffy
    milwscruffy
    That would be a good plan if I can get the crimped area back over the housing, so far no luck and yet it came off !
    Stogy, bchctybob and 19Eddy30 like this.
  7. K13
    K13
    I wonder if heating it a bit might expand it enough to get it back on? Would definitely have to be careful with the glass.
    Stogy likes this.
  8. 19Eddy30
    19Eddy30
    from VA
    Test to see if you can walk back on ,
    If So then see if you can easy remove,
    If So afew little dab of clear silicone or few dabs of superglue Re install ...
    I would start @ top try walking as move closer to bottom on both sides .waybe help with using .003 feeler gauge .
    With all the Autometer gauges I have I've never seen that happen
    70 to present most of mine tho are Comp
  9. milwscruffy
    milwscruffy
    Weird been on the car for 4 years with no issues, still trying to get back on without damaging it any, in case of a possible replacement from AutoMeter. *It is a no go without doing damage to it. I took the glass and plastic insulator out and just tried to see how the bezel would fit on the housing and it's not even close and can't even get it started. My guess is it was not "seated" on the whole way from the factory and stayed in place half cocked until now. Guess I didn't inspect it enough when I bought it... Will see what a phone call comes up with tomorrow.
    Stogy and rockable like this.
  10. kabinenroller
    kabinenroller
    If Auto Meter can’t or won’t fix it I would bet Roger at Speedometer Service on Villard Ave. would be able to help.
    Phillips, Stogy, bchctybob and 2 others like this.
  11. A Boner
    A Boner
    Any chance Auto Meter gauges are made by Stewart Warner?
    Stogy, 427 sleeper and milwscruffy like this.
  12. 2OLD2FAST
    2OLD2FAST
    from illinois
    Dunno , which 3rd world country makes the parts for SW ?
    Stogy and milwscruffy like this.
  13. milwscruffy
    milwscruffy
    Gosh, haven't been there in so long that when I was there I probably dealt with Rogers dad or grandpa. Guessing I haven't set foot in there since 1977 or so. Waiting to hear back from AutoMeter's service department, I think it would be hard for them to deny it was a manufacturing defect...but then again.
    Stogy and kabinenroller like this.
  14. milwscruffy
    milwscruffy
    Not sure but they are based out of Sycamore, IL. and appears to be made there and USA made.
    Stogy likes this.
  15. milwscruffy
    milwscruffy
    Have to fill out a form and send it to them.
    Stogy likes this.
  16. milwscruffy
    milwscruffy
    Well it was a one week turn around and and things are back in one piece. Turns out the bezel butts up to the flare on the can, so no clue how it's secured, maybe just snaps in place ? A little epoxy will be added to the seam for insurance for the future. Back to my regularly scheduled programming now. IMG_4023.JPG
  17. 427 sleeper
    427 sleeper
    At one time they had the same address, in Elgin Il. which leads me to believe, they were in close contact. Possibly being made in the same facility, to different specs. Or just a cheaper version of Stewart Warner.
    milwscruffy and Stogy like this.
  18. Stogy
    Stogy
    You redlined it!! Joking aside yeah glue is probably the method they used...the more you add the more solid the effect and seal. You could glue on 4 to six points and use a clear caulk around the circumference and wipe the excess making it possible to remove again easier if you have too.
    milwscruffy and 427 sleeper like this.
