Leftover Panhard kit from Speedway from a project, brand new in Speedway Box. 25.00" Tube Length, 27.50" Center to Center, Steel With cross steering a Panhard bar is a must-have item due to the added side for applied by the steering linkage This kit will stop side-to-side sway of ch***is relative to the axle Designed for spring over 4 bar front ends with I beam axle Ch***is bracket will need to be welded to your frame Choose from raw steel or polished stainless steel components
