Muncies and Hurst Shifters
Discussion in 'Off Topic Hot Rods & Customs' started by Oneball, Oct 6, 2025.
  1. Oneball
    Oneball
    My 69 Corvette race car has an M22 with a Hurst shifter, I find the change really tricky and often end up in the reverse plane when downshifting from 3rd to second. I’ve rebuilt the shifter and have metal bushings. I’ve added a weaker centring spring and tougher reverse spring. It’s an original Hurst not a modern one. I still find the change terrible, even a model a has a nicer shift. Anyone got any thoughts? Any different shifters out there?
  2. Mimilan
    Mimilan
    Use a 3 speed shifter on a 4 speed, and a separate lever for reverse is the easiest.
    Or if you want to get creative , vulture a shift lever off a Subaru with the Pull up ring and cable down the centre of the lever.
    Weld this to a tab to bolt on to a hurst shifter.
    Then make a cable operated detent to lock out the reverse gate
    Here is a Subaru lever spliced onto an FR500C remote shifter [it was used to lockout 1st gear AND reverse on a T56R]
  3. SS327
    SS327
    I never had any problems with a Hurst accidentally going for reverse. Compe***ion plus short throw. In my corvette and 63 Bel-Air both.
    big john d, Deuces and loudbang like this.
  4. Oneball
    Oneball
    I do wonder if there is actually something odd going on with mine.
    Deuces likes this.
  5. Oneball
    Oneball
    I’m sure they did a lockout lever for the 3 speeds but I’ve never seen one for the Compe***ion Plus.
  6. bowie
    bowie
    You may find one of these , will solve your problem. Seems there could be something wrong with your unit, though. I have never had any issues with my good old Hursts, even without a lockout kit. IMG_3820.jpeg IMG_0248.jpeg
  7. SS327
    SS327
    Is it possible you’re not used to shifting with your right hand? Might have to build that muscle memory?
    Deuces and Oneball like this.
  8. DDDenny
    I can't see the possibility of that happening.
    Are your levers oriented like this?
    Deuces, Tickety Boo and Oneball like this.
  9. Kerrynzl
    Kerrynzl
    It doesn't go into reverse [up by first on a Muncie]
    When aggressively down shifting from 3rd across to 2nd it over-centers to the reverse "gate" and cannot be pulled back.[this costs valuable time]
    This is an issue in Road Racing , not Drag Racing
    As Mimi posted above , Use a 3 speed shifter on a 4 speed is the easiest.
    Grumpy Jenkins [have you heard of him? :D] used a 3 speed shifter on his 2nd Gen Camaro pro-stock
  10. Kerrynzl
    Kerrynzl
    @Oneball is in the UK which is RHD , the same as NZ.
    We are use to shifting with our Left Hand and when we switch to driving a LHD car [shifting with the Right Hand] down shifting is more difficult at speed.
    You guys are use to power upshifting [this is easy], try lightning fast down shifting! If you shift too slow you can break the tyres loose and "swap ends" on corner entry
    Nice "Handbag" in that photo :p
    Oneball and 19Eddy30 like this.
  11. Oneball
    Oneball
    I’m pretty much split 50/50 between LHD and RHD and actually spend more time working a stick with my right hand but can concede that it could be operator error.
    I have been trying really hard to move the lever properly but it still often goes part way into the reverse plane and that’s why I changed the springs.
    I wonder if I could just mount a latch to stop the lever moving all the way to the left.
  12. Kerrynzl
    Kerrynzl
    Try this example on a high dollar 1957 Ferrari Testa Rossa
  13. Oneball
    Oneball
    That’s the sort of thing just without the gate.
  14. bowie
    bowie
    The other Hurst designed solution, would be the 70’s era Super Shifter. This does the same thing as the original Loc/out kit. Mine has been around the block a few times, but you can get the idea. IMG_3821.jpeg IMG_3823.jpeg IMG_3822.jpeg
  15. ekimneirbo
    ekimneirbo
    from Brooks Ky
    I had some pictures of a shifter (not a Lenco) that a guy had in his 32 Ford. It was American made and had a lever for each gear so it would be tough to miss a gear either upshifting or downshifting. Think it had a way to go from high gear to first and reset all the levers. Unfortunately I can't locate the info now, but maybe someone else knows the name of the company. It would solve the downshift problem and it looked pretty well made.
    Well, found some info on line about the shifter.........unfortunately its for an automatic and not a manual........fergot that little detail. :cool:
    https://www.facebook.com/watch/?v=608250331620024
  16. DDDenny
    Are you thinking of Kilduff?
    Pretty sure all their offerings are for automatic transmissions.
  17. chevy57dude
    chevy57dude
    Ram Rod, can't miss or hit reverse.
    bowie, loudbang and Tickety Boo like this.
  18. Happydaze
    Happydaze
    Watching Paul Cangislosi's videos on YouTube (gearboxvideo) makes me want a Hurst shifter!
    Chris
  19. LOST ANGEL
    LOST ANGEL
    Loved the shifter for making a 3 point turn on a busy street. o_O:cool:
  20. DDDenny
    I would own a Hurst shifter even if I didn't need one, I have two.
    Deuces likes this.
