Customs looking for advice /help with 292 y block ford
Discussion in 'The Hokey Ass Message Board' started by buick61, Oct 6, 2025.
  1. buick61
    buick61
    have a 61 galaxie with a 292 y block , one side exhaust is running cold , about 1/5 the heat and pressure of the other exhaust pipe , engine is running well and firing on all eight cylinders,
    have checked the muffler for blockages , not blocked.
    have checked valve clearances , all ok .
    checked timing .
    have done a compression test to check for blown head gasket , all cylinders between 115 and 125 .
    checked for inlet manifold leaks , no leakage found .
    fitted new plugs , leads, cap and rotor .
    anyone had any experience with this, or any advice on what else the problem could be .
    thanks in advance
  2. miker98038
    miker98038
    Did you check the heat riser valve on the (usually) p***enger side exhaust, right below the manifold? Sounds like it might be stuck closed.
  3. buick61
    buick61
    yes . heat riser valve has been removed as was leaking
  4. jaracer
    jaracer
    Does it seem to have ample power? I'm ***uming it is stock with a 2 bbl carb.
  5. buick61
    buick61
    4 bbl carb , holley 600 . i am ***uming a stock intake , and seems to have ample power for for a 292 and 2 stage auto , have checked intake by spraying starter fluid around gaskets and carb base , seems to have no leaks ,
  6. KenC
    KenC
    Only advice I have is to get yourself an laser thermometer and check over each port in the manifolds to gather some real info. Might find a cylinder problem or not, but having the data can't be bad.
    One more thing, the exhaust crossover in the heads or intake may be blocked, cracked, burned open or something.
    Ralphies54 likes this.
  7. buick61
    buick61
    maybe something to look at , i think a lot of people for some reason block off the exhaust crossover , how would that effect the presssure and heat one one side of the exhaust , thanks
  8. Wanderlust
    Wanderlust
    Just to clarify, you say that you checked the muffler ( as in singular) for blockage , is this one of those 1 inlet 2 outlet jobs or do you have a true dual exhaust, h pipe, x pipe? nobody is immune to a brain fart but without a full understanding of your exhaust system we’re throwing darts over our shoulder
    warhorseracing likes this.
  9. buick61
    buick61
    2 separate pipes , 2 separate mufflers , straight from exaust manifolds to the rear ,no crossover pipe , only weak on the p***enger side and have checked with muffler removed , still weak on that side
  10. Wanderlust
    Wanderlust
    Ok well that’s bizarre then, what exhaust manifolds are you using? Have you had the intake manifold off, should be able to tell if the exhaust riser is open by the paint being burnt off the intake in that area, can’t see an exhaust manifold being so restrictive that the flow would choose to cross over.
  11. Wanderlust
    Wanderlust
    Have you checked the head casting numbers, two different heads? Just spitballing here, mine has different heads same numbers, ones Cleveland the other São Paulo, even the casting lines are different.
    y'sguy likes this.
  12. buick61
    buick61
    will check heads , not sure how to , but will figure that out , heat riser on the manifold has been removed as was leaking arround the shaft . pluged holes and welded them in ,so no restriction there . would not think the exhaust manifold would be blocked , maybe the crossover , but should still exit out the exhaust on that side
    y'sguy likes this.
  13. Oneball
    Oneball
    The intake should equalise things out but seeing as you seem to have tried everything else see whether your carb is only idling on one side. Screw one mixture screw in and see what happens then try the same with the other.
  14. manyolcars
    manyolcars
    at 5:59 you say, "no crossover" at 11:03 you say "maybe the crossover"
  15. buick61
    buick61
    did think of that . took the carb off and turned it arround to check , still weak on the same side even with the carb mounted backwards
    Oneball likes this.
  16. buick61
    buick61
    no crossover in the exhaust pipes , but crossover in the inlet manifold
  17. Oneball
    Oneball
    You’ve not for some weird reason got a crossover valve in the exhaust at the end of the manifold as well as the one in the intake?
  18. buick61
    buick61
    a heat riser valve on the manifold , which has been removed . and the inlet manifold has a heat crossover were the exhaust heats the inlet manifold/carb
  19. CSPIDY
    CSPIDY
    Maybe the problem is on the hot side
  20. miker98038
    miker98038
    Ok, so it’s running and driving ok? Not just idling, driving at speed, even 30 mph.
    I’d get an infrared thermometer (cheap enough on Amazon) and start at the exhaust ports on the manifolds. Then both manifold/head pipe connections. Check the temperature at the back of the heads, temp gauge sender on the drivers side, and the soft plug under the distributor. Then the head/intake water p***age on the manifolds, side of the thermometer housing.
    Don’t be surprised if the water temp varies some, or the exhaust ports. But they should be close. I’m having a problem figure out what’s going on given it’s driving ok. Got to be a cold spot somewhere.
    y'sguy likes this.
  21. ClayMart
    ClayMart
    y'sguy likes this.
  22. y'sguy
    y'sguy
    from Tulsa, OK
    It sounds like you have tried the most obvious and common things I myself would have done. At this point, you might try backflushing the cooling system. Do you have a bacflushing kit? Like from Prestone or something similar? It is the only thorough way I have found to get sediment out of the block.
  23. y'sguy
    y'sguy
    from Tulsa, OK
    As was mentioned earlier, check to see if the head casting numbers match. You could very easily have different heads or non-matching. Not a deal breaker, it happened a lot when a mechanic would simply change out just one. ALSO check to see if you have matching rocker arm sets. Could have a hi-lift on one side and not he other. I have seen this a few times. Still not sure if this would. cause the issue you are having.
  24. Wanderlust
    Wanderlust
    Head gasket incorrectly installed on driver side is also very common, check to see if you have square corners to the front both sides
  25. Wanderlust
    Wanderlust
    If you zoom in the corners are evident at the front of the heads
    y'sguy likes this.
  26. buick61
    buick61
    yes , think i will order one , even if only to try and narrow down the problem area , and yes is running and driving ok even at hi way speeds
  27. buick61
    buick61
    thanks , but yes head gaskets are mounted correctly
  28. buick61
    buick61
    have a vacuum gauge , will hook it up next week , just waiting on my distributor to come back from the rebuilders,so i can have it running again
  29. buick61
    buick61
    i would not think it would cause it , but will check the casting numbers and rocker arms this weekend . first thought was a blown head gasket between 2 clyinders , but compression test came out normal
