Projects 1962 Biscayne Jr Stocker for the Street Build
Discussion in 'Traditional Hot Rods' started by Stock Racer, Mar 15, 2022.
  1. Dave G in Gansevoort
    from Upstate NY
    Glad to help… spend your money!
    Stock Racer and enloe like this.
  2. AHotRod
    AHotRod
  3. Motorwrxs
    Motorwrxs
    Really enjoying your thread and all the steps you are taking to follow the rules…hope to see a video of the Biscayne running down the strip when it is all said and done.
  4. Junior Stock
    Junior Stock
    Look for chemical milling. Used mostly for aircraft parts.
    Stock Racer and 427 sleeper like this.
  5. Stock Racer
    Stock Racer
    Cool, thanks for the info. Yea, cost will be the deciding factor.
  6. Stock Racer
    Stock Racer
    Thanks for following along. Next spring/summer is the goal.
    427 sleeper, Motorwrxs and loudbang like this.
  7. Stock Racer
    Stock Racer
    That would be great and I've done plenty of Ford engines but yea, the logistics would be a bit of an issue.
    427 sleeper likes this.
  8. swade41
    swade41
    from Buffalo,NY
    I just went back through the whole thread, you've did a heck of a lot of work on this car.
    On my current 57 pickup project I'm getting ready to start cleaning the front half of the frame and under the cab. Just curious if you wanted to come do it for me. Lol
    And everything covered in dirt. Lol
  9. Dave G in Gansevoort
    from Upstate NY
    I hate it when I do that!
  10. Stock Racer
    Stock Racer
    If I would have known then what I know now, I would have started with a better car. I'm in it for the long haul now.
    I can feel and smell every one of those pictures, lol (see my avatar). If you were closer, I'd come help you (glutton for punishment).
    I'm still finding areas in my shop that need cleaned.
  11. Stock Racer
    Stock Racer
    I decided to strip down the firewall and cut it in before the engine goes in. I figure painting it now will make things easier down the road.
    In my travels I found the dash harness is burned up and the turn signal switch is missing. I got another harness with the car so someone new what was going on, lol. The turn signal switch is no big deal but I wish they would have left the attachment screw.
    The good news is I've now been through every inch of this car and I'm thinking this is the last surprise.
  12. saltflats
    saltflats
    from Missouri
    I probably have a screw for that if you need one.
    Will you be at Tristate this coming weekend?
    loudbang, Stock Racer and enloe like this.
  13. Stock Racer
    Stock Racer
    I will not.
  14. Chucky
    Chucky
    I’ve mentioned it on other X frame threads, but my experience with a new (aftermarket) turn signal switch was that the internal flat thin spring contacts were not quite formed properly and were a bit short in length which caused the new switch to work poorly and inconsistently. I ended up transferring the old spring contacts into the new switch and it worked great. Maybe I just had a ****py new switch, but the more you know, the more you know.
    For the record, I only changed my original switch because one of the canceling tabs was broken.
    saltflats, loudbang and Stock Racer like this.
  15. Stock Racer
    Stock Racer
    I prefer good used OE or NOS stuff over new Chinese ****. That's a lesson I've learned on more than one occasion. Thanks for the heads up!
  16. Stock Racer
    Stock Racer
    Got the firewall sanded and removed the dried out/loose seam sealer. Got most of the rust cleaned up and used some Rust Mort in the seams and tight spots.
    When I did the seams in the trunk, I found the seam sealer too thick to get the brush marks like factory. I took a stiff brush, cut it short and with a ragged edge. I cut a bondo spreader and put grooves in it with a cut off wheel.
    tr_rodder, Deutscher, swade41 and 3 others like this.
  17. Stock Racer
    Stock Racer
    Sealed the firewall seams. The brush worked so good, I never tried the bondo spreader. The spreader did work great for next day touch-up.
    Tickety Boo, Deutscher, SS327 and 9 others like this.
  18. Stock Racer
    Stock Racer
    There's this gash on the left rear quarter and I'm getting ready to paint the trunk. Figured I'd give it a couple s***ches now so I don't burn the new paint. Still needs a little hammer and dolly work but it's in a tough spot.
    tr_rodder, enloe, Tickety Boo and 8 others like this.
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
  20. Stock Racer
    Stock Racer
    Yep, Bondo is wonderful stuff.
  21. Stock Racer
    Stock Racer
    The trunk is painted.
    Before
    I couldn't get under the stiffener to clean it very good so I shot rust reformer under it. To my surprise, the can sprayed good nearly upside down.
    Cleaned up the rust and primed. DA'd the old paint down with 80 grit.
    Happy with the outcome, especially the patched area's.
    Here are my weapons of choice for the trunk.
  22. DDDenny
    Wow, the things that pop out of a guys mind...........out of nowhere!
    1970, a high school pal of mine bought a 62 Impala SS just like this one, had damage in nearly the same area but no tears in the metal, beat it out, bondo'd it up, sanded and rattle can painted it, NAPA had a color real close, turned out pretty good for a 16 year old.
    Tickety Boo, enloe, SS327 and 2 others like this.
  23. SS327
    SS327
    Does that spatter spray paint need a clear coat to keep it from washing away with water?
    enloe likes this.
  24. Dick Stevens
    Dick Stevens
    NO
    Stock Racer, SS327 and enloe like this.
  25. Wobbly
    Wobbly
    from Ireland
    Very nice work, lots of hard dirty graft done. Cant beat working upwards from a solid base.
    Stock Racer likes this.
  26. Stock Racer
    Stock Racer
    Well... On the can it says "water resistant" and "durable" Time will tell, lol.
    tr_rodder, SS327 and loudbang like this.
  27. Stock Racer
    Stock Racer
    Thanks!
    Yep, I feel like I'm getting close to doing some of the fun stuff finally.
    SS327, Wobbly and 427 sleeper like this.
  28. SS327
    SS327
    I just asked because I know the old stuff wasn’t waterproof until you sprayed a flat clear over it to seal it. I found out the hard way. :oops:
  29. Stock Racer
    Stock Racer
    I appreciate the heads up. I might shoot some on a test piece and check it out.
    loudbang, SS327 and 427 sleeper like this.
  30. Stock Racer
    Stock Racer
    A couple updates...
    I found an NOS T/S Switch on the auction site.
    I painted the floor drains for the trunk. Threw one in a bucket of water and the paint is NOT water proof so I'll be shooting some clear in the trunk.
    Uh-oh, Captain rattle can got a new toy. This could be trouble, lol.
