Technical HAIR PINS AND MUSTANG BOX ON 32 FORD???
Discussion in 'The Hokey Ass Message Board' started by ALLDONE, Sep 25, 2025.
  1. lostone
    lostone
    from kansas
    Sounds like a whole lot of work for little gain.
    If it drives good and it's well engineered and assembled I'd leave it alone and drive the wheels off of it.
    No offense but if I were worried about what everyone else said or thought my car would change daily....
  2. hotrodjack33
    hotrodjack33
    I didn't notice how far forward your steering box was...and yes, my steering column (87 Astro van) goes through the floor and is directly "D coupled" to the steering box....no universals.
    Yes, a 302/C6. Don't have a good side view but I did recess the firewall a couple of inches and used a 289 "shorty" waterpump and had plenty of room for a mechanical fan...stock length hood.
    Actually, a harder time fitting a 302/AOD in my '36 Cabriolet... recessed firewall 5" and still needed a Zoop's serpentine setup to pull it off. 0.61.jpg 0.62.jpg
    ALLDONE and lothiandon1940 like this.
  3. RICH B
    RICH B
    You hinted F-100 in one post. Here is how we did a F-100 box ('57 & up arm) in a deuce with split bones (would have the period look you mentioned). Wouldn't worry about heating and bending the steering arms again if needed; after all they are good Henry Ford forged steel.
  4. A Boner
    A Boner
    Put the fenders back on.
  5. ALLDONE
    ALLDONE
    but i want a hi boy coupe... if that matters..
  6. ALLDONE
    ALLDONE
    thanks for the pics and ideas
  7. ALLDONE
    ALLDONE
    thanks for the pic... if my box was back like that I could pin it...
    hotrodjack33 likes this.
  8. ALLDONE
    ALLDONE
    I don't know if the worried part was directed at me on just a general state ment... but I want what I want when I want it... and usually not happy till i get it... I want a more tradition all steel 32 henry Ford hi boy ....
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    Keep in mind that with the mustang box and the pitman arm pointing up that you will have bump steer with split wishbones and hairpins. you will not have bump steer with 4 bars....
    bchctybob, Ned Ludd, ALLDONE and 4 others like this.
  10. ALLDONE
    ALLDONE
    Interesting... thanks for posting...
    Moriarity likes this.
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    even though the 4 bars look street roddy, Roth used them on his Outlaw in 1959, and Norm Grabowski used em on his T. they used Tie rod ends back then. Maybe you could make yours look older??
  12. ALLDONE
    ALLDONE
    thanks again for posting.... My guess the car was done 50 years ago....it has a real 32 chassis and a really nice steel body...so my thought was kick it back to more traditional looking... the chassis works excellent, nothing weird , and pretty smooth ride... no clanking and such.... but every idea i get short off cutting everything off and starting over...I hit a differant road block.... this whole set up would be bitchen in my full fendered 31 more door Cdan... I'd endup with dropped axel and disc brakes... but it's 5 on 4.5 bolt pattern.. IMG_6133.jpg I could also use the drilled split bones...
  13. ALLDONE
    ALLDONE
    here's some better pics of what i got...all ideas and suggestions welcome...
    there has to be something i'm just noT seeing... the 4 bars are only 17'' long pretty sure that would too short for a hair pin
    here you can see how far the steering box is pushed forward.. I didn't really look at this part with the fenders on.. i seen the 4 bar.. and figured it was an easy swap..
  14. ALLDONE
    ALLDONE
    If I wasn't 72 yrs old ,and handicap the motor and the whole frontend would have been already removed... re painted and a so cal polished and chrome buick drum covers front would be on ..
  15. ALLDONE
    ALLDONE
    just wondering.. hair pins are around 27'' if I used a flat top pin, could I run them around 20'' long???
  16. ALLDONE
    ALLDONE
  17. Moriarity
    Moriarity
    SUPER MODERATOR
    you will have bump steer with hair pins.....
    Ned Ludd likes this.
  18. ALLDONE
    ALLDONE
    even with the mustang box
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    yes absolutely, get a Pete and Jakes catalog. It is all spelled out there
    ALLDONE likes this.
  20. ALLDONE
    ALLDONE
    look at this pic... if I use the top mount bolt , and use a flat top hair pin...it would work the same as a stock ford steering....right???
  21. ALLDONE
    ALLDONE
    the drag link and the top bar of the 4 bar is close to level...parallel
  22. Moriarity
    Moriarity
    SUPER MODERATOR
    might be ok if you can use the top hole.... looks close to the same plane
    ALLDONE likes this.
  23. ALLDONE
    ALLDONE
    pete and jake says it works.....????? page #3
  24. Moriarity
    Moriarity
    SUPER MODERATOR
    let’s see, I don’t have a catalog, can you post a picture?
    ALLDONE likes this.
  25. ALLDONE
    ALLDONE
    thanks for the post...I was thinking... make 2 short flat top hair pins and try it... if it don't work put the 4 bar back....???
  26. ALLDONE
    ALLDONE
  27. ALLDONE
    ALLDONE
  28. RICH B
    RICH B
    Been a while that I put a P&J 4 bar set-up on; but I don't remember the bars being that short or the box mounted that far forward.
    Sounds like the only way to get what you want is to cut it all off and start fresh.
    ALLDONE likes this.
  29. twenty8
    twenty8
    Before the days of hairpins, four-bars, and cross-steering, this setup was the only way things were done. A split wishbone is mounted on the bottom of the framerail, and an F-100 or Mustang steering box is bolted to the rail with the Pitman arm sticking up and the drag link running forward.
    https://www.hotrod.com/how-to/solid-axle-front-suspension-details
  30. ALLDONE
    ALLDONE
    yeah, this is 2 wrongs won't make a right..
