History ID This Car?
Discussion in 'The Hokey Ass Message Board' started by Veronica1965, Oct 10, 2025.
  1. Veronica1965
    Veronica1965
    Hi Fellas!
    I know this is not a great pic, but I'm hoping there's enough here for one of you to identify this car make and approximate year?
    Appreciate any and all help, Ronnie
  2. I may be wrong ( incorrect that is) but I think it’s a Packard.
  3. 26 T Ford RPU
    26 T Ford RPU
    The wheels look Packard, so two for Packard, JW
  4. jet996
    jet996
    from WY
    image.jpg X3 -They used that hexagonal center for a long time...
  5. RodStRace
    RodStRace
    The flat fender is early 20s back, but the solid wheel is possibly later?
    I found this resource to be able to scroll thru a lot of identified pictures.
    Remember that the luxury makers often supplied ch***is to coach builders.
    https://www.packardsonline.com/slide-show.cfm
    EDIT:
    Going thru, the 21s seem to have the flat fender, but spoke wheels and 'hoop' handles. Note both have no exterior hinges and both have front hung doors in the rear.
    The 22s have a cowl/windshield that match better and solid wheels, but round fenders and more typical door handles.
  6. lostn51
    lostn51
    from Tennessee
    Definitely going with Packard and they loved the solid wheels too. The hood shape favors the early models maybe somewhere around the mid to late 20’s?!? Either way a regal car for a well to do gentleman
  7. rusty valley
    rusty valley
    Custom top on a touring car. Sometimes called a "California" top. Wish we could see the front, that would nail down the Packard theory.
  8. Veronica1965
    Veronica1965
    Thank you all for the responses!
  9. Joe Blow
    Joe Blow
    I'd concentrate on the steering wheel....although it looks like it might possibly (slim) be a version of a Fatman?? which was aftermarket. Also, the tag on the pic is "Browning". There is a section of the Browning Museum in Ogden, Utah that has antique cars.
  10. RodStRace
    RodStRace
    With the characteristics I pointed out that seem to mix year breaks, lack of handles and that steering wheel @Joe Blow mentions, it is quite possible it's A. not Packard, B. modified.
    The apron between the body and running board is very similar, but the spare mount, custom top, no handles and no curve on the edge of the fender lean toward mods.
  11. 26 T Ford RPU
    26 T Ford RPU
    Last year we had a Packard gathering in our area that i went to and this one has the same style of spare wheel fixing and wheel type. JW
  12. 26 T Ford RPU
    26 T Ford RPU
  13. Veronica1965
    Veronica1965
    Thanks for sharing those pictures JW., both outstanding cars! I think the car I posted has more "primitive" looking fenders than both of those above. Your thoughts?
  14. 26 T Ford RPU
    26 T Ford RPU
    You are correct but these are newer Packard's that have the same style wheel although more wheel studs and the same (very similar if not exact) as the pic you posted. I may have to dig deeper. JW
  15. 49ratfink
    49ratfink
    googled Packard phaetons back to 1913.... didn't see one with square doors, there was 100 auto manufacturers in 1920. it would be close to impossible to find a photo of that car.
  16. Ziggster
    Ziggster
    Google AI reverse image search. Quickly found the pic in this thread. lol!
  17. 49ratfink
    49ratfink
    porkshop and Stogy like this.
  18. Ziggster
    Ziggster
    Don’t be so quick to trust the AI response…
  19. Ziggster
    Ziggster
    Another AI response from Google.
  20. Ziggster
    Ziggster
    This feature (air intake?) on the orig pic, matches that on one of the cars posted by @jet996
  21. 26 T Ford RPU
    26 T Ford RPU
    The Kissel never had flat fenders or disk wheels, the Packard had flat fenders to 1921 and disk wheels from 1923 (wood spokes also). As has been said there were many coach body builders and the car in the photo "may" have newer wheels fitted.
    AI makes **** up so i never use it or trust it. JW
  22. RodStRace
    RodStRace
  23. 26 T Ford RPU
    26 T Ford RPU
    The plot thickens, Maxwell's never had a side mount spare. One interesting feature on the original pic is the rear door hinges.
    This shows that the door quit far rearward over the fender. JW
  24. inthweedz
    inthweedz
    I've got an old corroded br*** 30's Cadillac hubcap that looks/is shaped like that, hexagonal center, with a round silver/stainless badge in the center with the Cadillac logo, and "standard of the world" around the edge..
    Found it in a river, lying at the end of a severly rusted diff and the collapsed remains of a wheel..
    Edit... I have just been up in the loft and checked my hubcap, it's diameter is approx the same width, but mine has a raised center leading up to the hex..
  25. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    I had a '26 Stude 4 door sedan. The same disc wheels were on it.
    Veronica1965 likes this.
  26. That hub on the rear wheel does not match the shape of any of the suggested examples. It's short and has a larger diameter all the way to the cap. The hex could just be for a wrench to remove the hub cap.
  27. RodStRace
    RodStRace
  28. 26 T Ford RPU
    26 T Ford RPU
    I looked up Mechanics monument and i can't seem to see it there.
    That steering wheel would be a sure tell tale to the correct make. JW
    Ziggster, Stogy and Veronica1965 like this.
  29. 49ratfink
    49ratfink
    I had a better mustache than that when I was 13.
  30. banjeaux bob
    banjeaux bob
    from alaska
    porkshop, inthweedz, Ziggster and 6 others like this.
