Projects Plymouth Powered Boat-Tail?
Discussion in 'Traditional Hot Rods' started by Driveway builder, Oct 12, 2025.
  1. Driveway builder
    Driveway builder
    Hey guys… I just picked up a complete 1935 Plymouth flathead 6 and 3 spd trans. This will be going into my boat-tail speedster. Some quick measurements looks like it should just fit. Is anyone running one of these motors in their roadsters? Looks like double the horsepower of a stock model a motor and close to the same weight. Any pros and cons? FB92518F-A1F2-427E-BB9F-E52D86B5D9B3.jpeg IMG_9539.jpeg
    rwrj, mrquickwhip, LOU WELLS and 13 others like this.
  2. rusty valley
    rusty valley
    The mopar flat 6's were all good engines. They don't like high RPM though, long stroke I guess.
  3. Rickybop
    Rickybop
    I don't know, the whole thing looks like a lot of trouble.
    I'll come around and haul it away so you don't have to deal with all the headache and heartbreak.
  4. inthweedz
    inthweedz
    Over here in New Zealand, back in the 60 & 70's, those flat 6's were used a lot in boats and speedway ''stock cars''.
    deadbeat and Sharpone like this.
  5. gene-koning
    gene-koning
    The Chrysler corp used basically the same flathead 6 (in two different length block formations) in their cars and trucks in nearly all of their divisions, from the early 30s up through the late 50s. Then the motors showed up in several farm and industrial applications for years after that. The motors are very solid and repair or rebuild parts are still easy to find. Newer versions have higher compression, larger bores, and a few oiling improvements over the older versions.
    It would look right at home in that boat tail speedster.
    Sharpone and Driveway builder like this.
  6. CJ95
    CJ95
    I absolutely love the way the flat 6 runs in my 48 plymouth
    tractorguy and Hollywood-East like this.
  7. Kosmos55
    Kosmos55
    Cool build. I have a 23” 201 in my “new” ‘40 Plymouth and have only heard good things about these engines.
  8. Squablow
    Squablow
    What's the history on the speedster? Looks like it was very well built at one time, was it burned, or just stored for decades?
  9. Driveway builder
    Driveway builder
    Unfortunately it was in a garage fire a few years ago… then stored outside. It’s a mess but I’m going to save her.
    mrquickwhip, tractorguy, rod1 and 3 others like this.
  10. Driveway builder
    Driveway builder
    What a great guy!
    mrquickwhip, Rickybop, rod1 and 2 others like this.
  11. Toms Dogs
    Toms Dogs
    from NJ
  12. Mr48chev
    The only issue might be engine length. You have to have room for those two extra cylinders. Plus you need at least the front half of the driveshaft to be able to match up with the U joint.
