Technical Adaptor early Hemi
Discussion in 'Traditional Hot Rods' started by 3w Hank, Oct 13, 2025.
  1. 3w Hank
    3w Hank
    If using the early Hemi ( 392 ) and use a Lasalle transmission.
    I know a adaptor for sale ( no name, so
    not ex Hildenbrant ) but starter at std side = not good for a 32 frame/steeringbox ) but is was market ’early Hemi to Lasalle’ but if that mean the baby Hemi pre 55 with the incast bell or the 392 - I don’t know.
    I do know it did not fit to a 392 block.
    Seller had no idea why.
    I suspect one should use the std adapter ring this engine might has (?)
    I saw this in a book.
    Look like starter at p***anger side ?
    3 bolt rows to get this togheter.
    Se picture of the adaptor for sale.
    Ideas.
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    It might be a Trans-Dapt housing. If it is, it will have a part number cast on it somewhere (like HC-27) that will identify it. It wouldn't bolt directly to the engine block; it would bolt to the original thick aluminum plate that mounts the starter.
    51 mercules likes this.
  3. oj
    oj
    Did you check with Wilcap?
  4. 3w Hank
    3w Hank
    Ok so I try to find a std Chrysler manual shift bolt-on plate.
  5. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I don't believe that the plate has to be from a standard shift car. I used to have a Trans-Dapt bell housing that allowed the use of General Motors 4 speeds behind a '54-'58 Chrysler hemi, and it worked in conjunction with the factory plate from an automatic.
  6. Gotgas
    Gotgas
    from DFW USA
    I bought a short bellhousing 331 that has a very similar adapter to that. It has the starter on the p***enger side. It also came with an aluminum flywheel and a Long-style pressure plate setup. I couldn't find any identifying marks anywhere on it, not even a part number.
  7. 3w Hank
    3w Hank
    Your 331 is that 54/55 or the one before with bell in block ?
    Nice has the starter at p***anger side.
  8. Gotgas
    Gotgas
    from DFW USA
    The block is actually an Industrial, 1957 I think. It does not have the extended bellhousing.
  9. 3w Hank
    3w Hank
    This seems be as the picture from the book, a std Chrysler adapter ring ( you has 2 rings, right ? )
    So after the std ring is then ex a Cragar ring to early Ford.
    Thats a good idea but how to find second ring ?
    But then one need find the adaptor early Ford to Lasalle with starter on p***anger side.
    -This will not be easy 2025, or ?
    Only way I guess find a kit with a transmission that has fit togheter.
    This was not unusual way then but today ?
    One case is guys has parts never let it go.
  10. oj
    oj
    that is similar to how mine is, 2 adapter rings, I have 354 to early Ford, the problem is getting a T-O bearing to work, yes, it mounts the starter on the p***enger side.
  11. 51 mercules
    51 mercules
    My buddy said he used a Hemi to a 49-64 ford trans adapter and then an adapter for a 49-64 trans to Lasalle adapter on an Anglia he used to have.Not sure of all the details. Borrowed pics from the internet. hemitoford.jpeg Part-5044-3-300x300.jpg
    Gruntis likes this.
