1962 Falcon Gasser project
Discussion in 'Off Topic Hot Rods & Customs' started by Lloyd's paint & glass, Sep 22, 2025.
  1. OK Lloyd, give us an update. Knowing you it is all but going up and down the street.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
  3. chevy57dude
    chevy57dude
    He's probably sold it already;)..
    Sharpone, enloe, 427 sleeper and 2 others like this.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
  5. Probably, but he likes to get em running first. It is a neat little car and I cant see him not wanting to spin the axle in it before he sends it down the road. He must be on a cruise livin it up.
    Okie Pete, Sharpone, porkshop and 2 others like this.
  6. nrgwizard
    nrgwizard
    from Minn. uSA
    Nice Guardian Shop Cat, too. :) .
    Purrfect for those *****-paw-prints racing stripes. :D .
    Bonus points if they're Sick-O-Delic racing stripes , dbl-points iffen you've got the matching boots too... "Dig the Psychedelic boots, baby!" (old Hulk Hogan, long ago). :) . May as well go whole hog w/a the Matching Helmet...
    Marcus...
    Sharpone and porkshop like this.
  7. CJ95
    CJ95
    That is an absolutely stellar build!!! If you need any falcon trim parts I may have some stashed!!!
    Lol nothing to update. Block is in the machine shop getting bored, cleaned, plugs and cam bearings. Reconditioned the rods, and putting them on my @lumpy 63 pistons. I've got the cam & lifters. Bought a fresh set of 906 vortec heads. Gonna be 12.5-1 according to the sheet that came with the pistons, but it doesn't seem to account for the. 030 bore. Picked up this intake at the swap meet Saturday. $70 :cool: and i got a set of fenderwell headers for it. Should be set as far as engine/ trans goes. Had a great conversation with quick performance about the axles and rear gear. But I've got narrow the rear housing still, cut the ends for C clip eliminators, and order said eliminators lol. The car is just sitting around waiting :D
  9. They are Bluetooth shocks lmao! You're guess is as good as mine. I'm not sure what they were planning to do there. I'll get to that later
  10. chevy57dude
    chevy57dude
    Lloyd, I have AN fittings and braided steel hose. If you want to replace the blue stuff on those crossovers, I'll send you the pieces.
  11. Sooooooo!!!!!!! a weekends worth of work for you. Cant wait to see what you make of it. It will be a neat little car to beat on.
  12. slowmotion
    slowmotion
    Yeah, nothing cooler than a snotty little Falcon with radiused wheel wells and some rubber hanging out! Go Lloyd!
  13. Got a phone call from Jamie today at quitting time. My stuff is ready to pick up. Gonna run over there first thing tmrw before I go to the shop.
  14. oldiron 440
    oldiron 440
    Hey with that 8.8 the thing to do is to weld 9’ ends on it because nobody makes c clip eliminators for the Explorer 8.8.
  15. Seriously? See this is why I'm not a fan of Ford. I thought they were the same! Lol... thanks man
  16. oldiron 440
    oldiron 440
    Maybe check around nobody made them when I had Quick Performance setup my 8.8.
    enloe, Sharpone and porkshop like this.
  17. squirrel
    The 8.8 uses C clips to retain the axles, the 9" doesn't. The rears are completely different, although the strength is similar.
    porkshop and enloe like this.
  18. oldiron 440
    oldiron 440
    That’s why you put 9” ends on the 8.8 you can use 9” axles on the 8.8.
    Usually the Explorer 8.8 has 2 7/8” removed from the long end to center the differential so the axles will be the same length. But if you put the billit 9” ends on each end you can build whatever width axle you want and get rid of the C clips.
    Im lucky enough to live less than a hundred miles from Quick Performance in Ames Ia., I took them a clean axle housing sandblasted and washed with no brackets they welded the center to the tubes and welded the 9” ends on. At the time with there work the cost of the used axle ***embly new axles crush sleeve eliminator and new differential clutch kit I had a complete ***embly with 3.73 gears an LD differential and 31 spline axles for less than a grand. I’m thinking about getting spool and 4.10 or 4.30 gears now but I’m finding that the parts are not cost prohibitive for the 8.8.
    Okie Pete, Sharpone and porkshop like this.
  19. squirrel
    how much you have to do to it, also depends on how fast the car is, eh? Might not need to mess with it at all?
  20. True.
  21. Running a spool from QP, requires C clip eliminators. Guess I'll get vigilant on finding a 31 spline posi. 20251015_102103.jpg 20251015_102137.jpg 20251015_103237.jpg 20251015_110728.jpg
    mad mikey, Deuces, SS327 and 12 others like this.
  22. Sharpone
    Sharpone
    How fast or quick in the 1/4 mile before c clip eliminators are required?
    I understand that axles can be broke with relatively low hp. However I do believe that normally to break an axle in heavier set up like the 8.8 is uncommon until a certain performance level is reached. Not sure what that level is.
    Dan
  23. squirrel
    Rear axle rules usually depends on whether you're running a normal limited slip, vs a locker or spool. You need good axles with a spool.
    mad mikey, porkshop, enloe and 4 others like this.
  24. I'm using quick performance axles. Was gonna run their spool also, but now I've gotta dig deeper into the eliminator thing.
    mad mikey, porkshop, enloe and 2 others like this.
  25. I swore I watched a video of a man prepping an explorer 8.8 for them. Went out and looked at my axle ends to see if they looked like his (the small shoulder that you have to retain to locate the eliminator) and mine look just like his did.
    porkshop, enloe, Okie Pete and 3 others like this.
  26. Quick Performance does list eliminators for 8.8’s, but they say they are for Mustangs.
    porkshop and Sharpone like this.
  27. I'll call em. Not near to that point yet. Won't be long though lol
    mad mikey, porkshop, enloe and 3 others like this.
  28. Hell I've got an open carrier, I'll just put a damn mini spool in it
  29. John Bowen
    John Bowen
    Not a g***er and kinda cheesy, but this thread reminds me of this video.
    Sharpone, Thor1, porkshop and 3 others like this.
