Projects The barn find Falcon
Discussion in 'The Hokey Ass Message Board' started by Mike Miller, Sep 15, 2014.
  1. The Dougs headers are the only ones I've seen that fit without bashing something. One last thing; I hope you checked the cowl around the fresh air vents under the dash. If these things rot anywhere, it seems like it's there. A huge PITA to fix, but if you never drive in the rain it won't matter... Oh wait, you're in Oregon... never mind... LOL
  2. loveoftiki
    loveoftiki
    from Livonia,Mi
    Was in the right place at the right time…FB marketplace..and scored these never mounted, 660YA for an auto trans, Ceramic coated, Dougs Headers for my 65 Falcon for $300.00 I couldn’t get the money out of my pocket fast enough..they are still a tight fit! I bought the small bolts, and made a “custom” wrench, bit those shock towers make anything a challenge..
    Your Ranchero looks killer…I wish I wouldn’t have p***ed on one a few months ago… 1DF35FCD-160A-4BDB-8A72-759C0947A10E.jpeg 6A3E175E-DB5B-4A75-B0A8-8DF1704A97C0.jpeg 14D65A5B-3EBE-482F-AE90-BB1724699182.jpeg
  3. Mike Miller
    Mike Miller
    Well they fit, but DSCF5424.JPG DSCF5425.JPG you have to get every thing right for that to happen. Worked all day today to get the left side in, had to re-work some floor board issues the P/O created .
  4. loveoftiki
    loveoftiki
    from Livonia,Mi
    Yep…they’re a real treat…I bought the best gaskets I could find…complete pita…
  5. Mike Miller
    Mike Miller
    A real tight fit, but got both sides in. the right side barely touches the stock starter post so I ordered a compact starter.
  6. Mike Miller
    Mike Miller
    Been fixing some substandard fabrications, the previous owner used many things from the Grenada donor car when he did the engine swap and left some of it half done. thr throttle linkage was attached to the carburetor with a nifty swivel that sandwiched the large hole at the top of the arm between two 1/4 inch washers and was not secured to the firewall at all. I patched the spot on the firewall with a sheet metal plate and built a bushing for the swivel to thread in to.
    Then moved on to the engine and trans mounts. He built his own trans. rear mount which at first glance looked good but after the headers were installed the left side was hitting the floor and caused the back if the engine to sit too high, to compensate for this he added a stack of shims under the front mounts which caused the whole ***embly to sit an inch higher than it should, I suppose he did what he could with what he had at the time. There is an adapter crossmember and rear mount available to install a c4 in the 61 thru 65 falcons which will set things straight and I can lower the ***emble back down to where it should sit.
  7. Yeah, the '63-65 V8 Falcon/Comet used a weird trans mount unlike any other Ford car. Took a special tailshaft housing to boot... You used to see some pretty cobbled 'stuff' when using a 'normal' trans.
  8. Mike Miller
    Mike Miller
    This bench seat is pretty crunchy but I think I can save it, so into the mol***es vat it goes then I'll replace a few broken springs. I have a couple of buckets out of a 67 Fairlane but would rather have the original bench, That's what the car came with originally .
  9. Mike Miller
    Mike Miller
    Fixing the engine mounts, the way the previous owner had them crunched the collectors up against the floor so I ordered a rear mount to replace the concoction he had cobbled up, and removed the spacers he installed under the front mounts for heaven knows what reason. Had to re do the throttle linkage and the throttle pressure rod to the transmission.
    Been putting a lot of time and effort into my beater with a heater project but the 56 wagon
    but that will be another build thread.
  10. Mike Miller
    Mike Miller
    Starting to work on the interior, installed seat belts, new carpet and glove box liner. Ordered and recieved new seat upholstery and a headliner, think I'll hire someone that knows what they are doing to install that stuff. A man has got to know his limitations:D
    chryslerfan55 and pcbart like this.
  11. loveoftiki
    loveoftiki
    from Livonia,Mi
  12. Mike Miller
    Mike Miller
    Got busy last week and pieced together an exhaust system.
  13. Mike Miller
    Mike Miller
    here's how it sounds
    captaintaytay and chryslerfan55 like this.
  14. Mike Miller
    Mike Miller
    Still trying to find a guy to do the headliner and seat, one of the minuses of living in the sticks is a lack of people to hire for tasks like this. there are only two guys I trust with a job like this and they are verry buisey.
  15. So the new headers cleared the steering box ok?
  16. Mike Miller
    Mike Miller
    Yes, they were tight but they fit un modified.
  17. Mike Miller
    Mike Miller
    Still working on this little car, I decided to try to install the head liner and seat covers my Selfe. If I succeed good that's another feather in my cap, if I fail I just won't talk about it.:D
    RICH B and In_The_Pink like this.
  18. Mike Miller
    Mike Miller
    Layed out the headliner to let the fold lines relax and get an idea of what I'm up against. Don't look like much of a job. What could possibly go wrong? DSCF5881.JPG
  19. Mike Miller
    Mike Miller
    These are some seats from a 67 Fairlane that I acquired a while back, I mentioned them a few pages back. My original seat is beyond repair so I'm going to make these work. Here they are mocked up and I can fit my six foot 210 pound frame in them comfortably , so off they go to the upholstery shop to be recovered in the right colored vinyl.
    LOST ANGEL, loudbang and Deutscher like this.
