Projects '53 Mild Custom - Dads Hot Rod
Discussion in 'The Hokey Ass Message Board' started by oliver westlund, Jan 29, 2019.
  1. dwollam
    dwollam
    Number 2!
    Dave
    oliver westlund likes this.
  2. oliver westlund
    oliver westlund
    Tackling the roof finally. Ive been avoiding this for far too long. My skillset has caught up with the project finally haha I am ready to start finishing some areas and getting em crossed off the list!
    20250318_122226.jpg 20250318_122236.jpg 20250318_134723.jpg 20250318_135941.jpg 20250318_140138.jpg
    BigRRR, dwollam and Squablow like this.
  3. Squablow
    Squablow
    Those '57 Ford Custom moldings from a 2 door sedan are worth a small fortune. I bet you could get $750 for a pair of those on eBay. I'd be hesitant to cut up a set. I have '56 Fairlane side trim on my '53, '55 Fairlane trim fits as well. 55 Pontiac side trim also gives a similar look and fits very well on these cars.
    Not that I don't like the '57 Ford stuff, but I couldn't bring myself to cut a set apart. If I was dead set on that, I'd sell those and find a set off of a 4 door, which are already split right exactly where your mockup would necessitate cutting these, and they have nice finished edges in that area as well.
    oliver westlund, dwollam and patsurf like this.
  4. oliver westlund
    oliver westlund
    I only have 100 bucks in this set, Im pretty in love with how it fits the fender. Tried google but Im not seeing similar trim in a 4 door? Weighing a cpl options out. Skratch had some cool ideas but they all involve a lot more work!
    dwollam likes this.
  5. Squablow
    Squablow
  6. oliver westlund
    oliver westlund
    I see it now! Thanks! That lines in a different spot than where I need it. I definitely am sympathetic to the desire to preserve cool old parts! To sell my trim and then have to find other trim seems like a lot of work. Im seeing the coupe trim pieces for a combined total of around 400 bucks on ebay. I got these for 100 worth of trade. I just dont see the benefit of selling these to get 300 max profit then having to source more. I do get it though and I still sometimes cringe at the sacrifices that have to be made in the name of hot rods and customs
  7. oliver westlund
    oliver westlund
    Progressing along. Welded some holes in the roof and did some zero rust treatment on the areas 20250401_194013.jpg 20250401_193948.jpg 20250401_193946.jpg
    dwollam, brEad and Squablow like this.
  8. 53olds
    53olds
    For what it's worth when I had those moldings, I had them for sale for a LONG time with zero action until one day Dave offered me a trade for them. Keep em!
  9. oliver westlund
    oliver westlund
    Okay more progress afoot! Brought the 54 over to begin to prep for the body swap. Had a cpl buds ask why I dont just move the b pillar back and put the coupe doors on the 4 door. Sure, that would give me a much better car. Problem is, that would leave me with a pile of parts and 1 car. The way I am currently doing it, there will be a complete 4 door with****le when its all said and done that I can sell. So recent progress, 4 door is in the shop, 1st I got it running. I have a 4 barrel intake and some side dump lakes pipes with baffles so I think itll get cleaned up and set aside for some future hot rod. Then after looking at the car a bit I just had to punch some louvers!
    I did it with my homemade hand punch, turned out the best set Ive done yet and I am pleased. Then today I pulled and labeled most of the wiring harness under the hood. Its 12v converted but its the stock cloth wires. My plan is to rebuild it on the bench with modern cloth wrapped wire to match. Next I will be pulling the front end off then yanking the engine.
  10. oliver westlund
    oliver westlund
    Soaking the front end down in degreaser as I type this. I have a pair of 1990 aerostar front coil springs sitting on my desk. Hoping that before it gets TOO cold out I can get the body off and raptor line the chassis. Then I can spend the bulk of the winter making the chassis flawless and setting the coupe body back on. Then wrap up metal work, make it run, drive and stop and by the time the ice thaws in the spring all I will have to do is bodywork, paint and glass installation!
  11. oliver westlund
    oliver westlund
    Degreased.... cpl surprises. Looks like control arm bushings and brake flex lines are a part of the picture now. Theyre ordered and on the way
  12. dwollam
    dwollam
    Oliver, is that a 239 engine you want to put a 4bbl on? If so, make sure it is a 239 Ford or 256 Merc 4bbl intake as the later Y-block manifolds have way larger ports and it is nearly impossible to get them to seal up.
    Dave
  13. oliver westlund
    oliver westlund
    Fair point, I will check. I do believe its on a 272. Thanks Dave!
    dwollam likes this.
  14. oliver westlund
    oliver westlund
    Little more progress today. Degreased and pressure washed the 239.
    Degreased the front end again and sprayed a lil paint.
    Majority of the front end is coming apart though so most paintwork will happen the right way
    dwollam and 53olds like this.
  15. oliver westlund
    oliver westlund
    Little baby steps but trying to make near daily progress. Today I got the passenger side coil spring out, set her up on the bench next to the shiny new aerostar coils.
    Then I pulled the upper control arm amd rebuilt it. Smashed my thumb with a sledge.
    20251016_145310.jpg Then managed to stick the shaft in backwards. It all came together nicely in the end though! 20251016_170932.jpg
    FoMoCoMoFo, scotts52 and dwollam like this.
  16. oliver westlund
    oliver westlund
    1 side back together and complete!
    Relatively smooth sailin. Did make a video on the process...
  17. oliver westlund
    oliver westlund
  18. oliver westlund
    oliver westlund
  19. oliver westlund
    oliver westlund
    Baby steps, slowly working my way through the harness, opening the loom and making repairs anywhere needed. Replacing wire with cloth wrapped wires, soldered connections and heat shrinked. Cloth style electric tape to re-loom
