Projects Need help finding clutch pedal
Discussion in 'The Hokey Ass Message Board' started by brokedownbiker, Oct 15, 2025.
  1. brokedownbiker
    brokedownbiker
    I've run into a snag on converting my '31 Chevy from a Powerglide over to a T-5 manual transmission. I'm currently running a Speedway 37-39 frame mounted brake pedal assembly (p/n 91631958) and need to add a clutch pedal. It isn't designed to add a pedal so I've been looking for a replacement frame mount assembly with both pedals- set up for non-power juice brakes and a manual clutch but, after a couple of weeks of searching, all I can find are for hydraulic clutches. I can't believe that everybody is running hydraulic clutches with the T-5 conversions.
    I've called and spoke to all the catalog places and major custom parts suppliers and none have anything to offer.
    Can anyone steer me towards a floor/frame mount brake/clutch assembly for non-power juice brakes and manual (non-hydraulic) clutch?
  2. FrozenMerc
    FrozenMerc
    Take the clutch master cylinder off and fabricate a linkage to operate the clutch manually.
    jazz1 and Tim_with_a_T like this.
  3. RMR&C
    RMR&C
    from NW Montana
    48-52 Ford F-1 PU pedals work good if you are bolting to a flat faced X member
    jet996 likes this.
  4. gene-koning
    gene-koning
    The dirt track guys are nearly all running hydraulic clutches. I think most are using Wildwood assemblies. They don't look like anything traditional, but they do work.
    bobss396 likes this.
  5. Fogger
    Fogger
    Google "Clutch and Brake pedal assembly", about 20 units show up, from eBay, Summit, Jeg's, etc
    Tow Truck Tom likes this.
  6. Phil P
    Phil P
    jazz1 and 2OLD2FAST like this.
  7. jazz1
    jazz1
    Something like these should be easy to source, image.jpg these were off 40’s pickups
  8. brokedownbiker
    brokedownbiker
    Thanks for all the options, I figured out a solution using parts I have on hand
    Phil P and Just Gary like this.
