Projects finally found a true 57 265 Chevy
Discussion in 'Traditional Hot Rods' started by bfalfa55, Sep 23, 2025.
  1. bfalfa55
    bfalfa55
    If you lived closer, I'd buy it just so I have one ! Ha ! Unless you make it to the Cleveland Ohio area sometime in the future. What is your price tag for it ? And is it the Chartreuse color or is it actually yellow ? From what I have found, there could possibly been a truck engine painted a yellow color. Check the stamped code and see what it is. Compare it to the letters I posted in this thread to see if it came in a car or a truck.
  2. unfinished
    unfinished
    I bought a 55 265 a couple of years ago, I recently decided to go another route and will be selling the 265 soon if anyone's interested. Pretty cheap.
    Sharpone, bchctybob and chryslerfan55 like this.
  3. Shain
    Shain
    from Omaha
    Someone here mentioned a 210 hp 265. The 210 hp version of the 265, was sold by Chevy in a 56 Corvette with a solid lifter cam, and 4 bbl. (205 hp version came in full size body cars/wagons, etc....had hydraulic lifters) Same engine except for solid lifter cam. Made a big difference in performance. (specs for cam were different.)
    Used to race a 210 hp 56 sedan (see avatar), when NHRA allowed the Vette engine in full size cars. That was a long time ago.
  4. Fordors
    Fordors
    I don’t know how to post a link from my cellphone but here’s a screenshot of a post I made about the 210 horse cam-
  5. patsurf
    patsurf
    he didn't do the 3030??
    Sharpone and chryslerfan55 like this.
  6. silent rick
    silent rick
    I have a pair of 56 210hp power pack heads
  7. Fordors
    Fordors
    No, another engineer in Duntov’s group did that, his name was Denny Davis, just another of the unsung heroes behind the boss in any organization. And even if his name was common knowledge saying “I’m running a Davis 30/30.” wouldn’t have the cool factor would it?
  8. GlassThamesDoug
    GlassThamesDoug
    57 265s use 57 283 casting, should be thick cylinder walls.
  9. GlassThamesDoug
    GlassThamesDoug
    Had a 1957 truck 265 that was yellow. Did not know what I had in 80s. No side motor mounts, we had Camaros and Chevelles at the time.
  10. Uncle Lee
    Uncle Lee
    I didn’t think that early of a casting would have the provision for mounting the starter to the block.
    bchctybob, bfalfa55 and 427 sleeper like this.
  11. Uncle Lee
    Uncle Lee
    Would that have been the 078 cam?
  12. oj
    oj
    I've got a tripe two-barrel intake for the 265, proper carbs too if anybody is interested in going that way.
  13. bfalfa55
    bfalfa55
    To the best of my knowledge, if you had a 283 with a Turboglide transmission, the starter did mount to the block. Someone can verify or debunk this statement since I don't know if it is fact.
  14. I have a 57 283 that was originally bolted to a turbo glide. Can't say if it actually had a block mounted starter as it was swapped into a 55 bel air in 1960 and bolted to a manual 3 speed with od. But I does have starter mount holes on the block
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    All 57 283’s were drilled and tapped for block mounted starters because they had no idea what trans was going to end up behind it along the ***embly line.
  16. I guess I could flip the block over and hunt for ancient witness marks from a starter removed almost 70 years ago. Really need to get the block out and cleaned up a bit for the machine shop anyway
  17. bfalfa55
    bfalfa55
    Well, because I'm just crazy enough to keep it in the range of a 265. If I do decide to make a 283, I have to 57 era forged factory cranks and a set of standard bore 283 pistons with 4 valve reliefs and a set of 270/283 standard bore pistons with 2 valve reliefs that I can use. Yes, there is no replacement for displacement but I think you can make a 265 run good with more modern parts than the good old days.
  18. Shain
    Shain
    from Omaha
    I had several 55's and lots of 56's back in the 60's and 70's. (Raced a 56 in NHRA stock cl***. - AVATAR) Had a garage full of extra 56 265 engines, and spare blocks. We raced a 265 4 bbl with 3 speed trans.
    In the upper Midwest I don't recall ever seeing a yellow 56 engine/block.. etc Maybe I just don't remember it, but ....
  19. bchrismer
    bchrismer
    I thought Brad took that one home with him.
  20. bfalfa55
    bfalfa55
    The only block that might have been yellow and wasn't Chartreuse like an early 57 265 could have been in a truck. Truck engines were all together different colors and I have yet to find concrete answers as to what colors they were painted in Tri Five trucks. It would just be cool to have an early 57 that is actually Chartreuse, then I guess I could say I truly have one of each! I need my head examined!
  21. brigrat
    brigrat
    from Wa.St.
    To any purist here I have an early NOS, '55 dizzy available! IMG_6152.JPG IMG_6153.JPG IMG_6154.JPG
    Sharpone, NoSurf, bchctybob and 4 others like this.
  22. Shain
    Shain
    from Omaha
    If I remember right.... 55 265's didn't have a oil filter, but had block mtd starters, all 56 and 57 265's had block mounted oill filters and starters.
    Never had a yellow 56 265 block
  23. HEATHEN
    HEATHEN
    from SIDNEY, NY
    All 1955-56 V8s had bell housing mounted starters.
  24. There is a logical reason to keep it 265 ci. Hypothetically that'll allow for more rebuilds on it meaning that core could last a LOT longer. Just work your way up to 283 one piston oversize each rebuild lol
    bfalfa55, Sharpone, bchctybob and 3 others like this.
  25. Butch M
    Butch M
    i have 55 265 it has Canada on the block no oil filter
    Sharpone and GlassThamesDoug like this.
  26. GlassThamesDoug
    GlassThamesDoug
    Somebody in Connecticut had a few 57 265s on here and Craigslist.
    bfalfa55 and Sharpone like this.
  27. 49ratfink
    49ratfink
    tri 5 chevy guys are nuts. I had a standard bore 265 a guy gave me that I parted out. everyone interested in the crank and block wanted to know the date code down to the month.. I thought just finding a standard bore block would be enough.
  28. I would ***ume those were Corvette guys. Those early Corvette guys are nutty on that as the early cars actually didn't have numbers to match
    bfalfa55, Sharpone and 49ratfink like this.
  29. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I had 265 55 style but the casting numbers came up as a replacement block: No one wanted it.
  30. bfalfa55
    bfalfa55
    All 55-57 265's had bellhousing mounted starters. The only 57 Chevy I am aware of that had a block mounted starter was a car that came with a 283 & a Turboglide transmission. if I am wrong about that, please correct me.
    Ralphies54 likes this.
