1983 3.8 GM V6 help needed from someone that knows these engines.
Discussion in 'Off Topic Hot Rods & Customs' started by Fat ASS Whitewalls, Oct 14, 2025.
  1. I'm trying to get an 83 Cutl*** running, 3.8 V6. Even fire I was told, whatever that means. I know nothing about the 3.8 V6. Someone else swapped the motor into it. I told them to put a V8 into, but they didn't. The original motor locked up. This motor is said to have came out of a running car. All the electronics on the motor have been removed, I replaced the distributor and carb with new ones for a 1977 Buick V6. I replaced the spark plugs with some good used ones, but I think I'll stop and get some brand new ones today. I don't think the spark plugs are the problem, but you never know. The problem is the motor will only start if I hold the throttle wide open, and then it just stumbles and shakes. It will barely run. I'm at a loss. What am I missing. It has good compression, the firing order is 1-6-5-4-3-2. It has fuel, it has spark on all cylinders. It doesn't really spit back through the carb like a timing issue. The car has set for about 4 years before I got into it. A buddy said maybe the exhaust is plugged, I guess it could be, I work by myself, so I haven't been able to check that yet. This is what you get when you take on someone else's mess. Thanks for any help you can give.
    tractorguy likes this.
  2. squirrel
    You probably need to figure out what engine it has, first. Buick changed from odd to even fire in 1977, and the engines look the same, but the crankshaft, camshaft, and distributor are different. If someone put the even fire distributor on an odd fire engine, then strange things will happen.
    Of course there could be a bunch of other things wrong with it.
    Dick Stevens and SS327 like this.
  3. MAD MIKE
    MAD MIKE
    from 94577
    If it was an odd vs even fire mismatch, there would be a lot of misfiring.
    If the cars original CCC carb is still being used it will run rich. Need to replace the DualJet with a non-CCC one from 75-79.
    What is the base timing set to?
  4. Wanderlust
    Wanderlust
    I’d be looking at the state of the fuel if it has sat for four years and obviously you need to determine if you have the correct distributor for that engine
  5. Jokester
    Jokester
    Years ago I put a 231 into a 72 Vega. The engine was combined from parts of three engines. I lacked a distributor so I picked up one at the boneyard that had no distributor cap. I got it running with an even fire cap, but with no power and limited range of ignition timing where it would run at all. I subsequently changed the pickup coil with a new even fire one (didn't realize that it had odd fire one in it). Ran great and was one of the most fun cars I ever had.
    As previously stated, you need to find out if your engine is even fire or odd fire. Then proceed.
    .bjb
  6. How do I find out if it's even Fire? The motor is a 1983 3.8 V6. in a 1983 Olds Cutl***. Is there numbers I should look for? Thanks.
  7. 31Apickup
    31Apickup
    The 76 and earlier use the nailhead looking covers, 77-78 had a smooth style and 79-87 used the one pictured. I ran an even fire HEI on an oddfire in a Jeep when I was young and didn’t know the difference, got it cheap and it ran okay. Later found out and swapped the points one back.
  8. Ok, I did some more research. I love learning new things. The original distributor cap is definitely even fire. All spark plug terminals are even spaced, not uneven spaced. As asked above, I put fresh gas in the car. I replaced the carb with a new carb that doesn't have the electrical connections, and I replaced the distributor with one that only has the one key hot plug. I don't like doing work that I don't need to, but I will unhook the exhaust from the exhaust manifold. Maybe the exhaust or the cat is plugged. That wouldn't surprise me if it was. Thanks for the replies so far.
    porkshop likes this.
  9. Oh, I guess I should have added that I tried to start the car with the original carb and distributor, and it acted the same way. I tried hooking up all the computer connections, but it wouldn't even start then.
  10. 31Apickup
    31Apickup
    I got a 84 Cutl*** with 3.8 for $75 back in 94 from a coworker. It ran bad had 2 fouled spark plugs. Even after replacing those it was low on power. Dropped the exhaust at the cat, took a crowbar and busted up the inside of the cat and cleaned out the pieces, it ran a whole lot better after that. You could have a plugged up catalytic converter.
  11. 31Apickup, that's what I'm thinking.
  12. gene-koning
    gene-koning
    If the car came to you because the guy before couldn't get it to run correctly, the odds have improved that it has a plugged cat.
  13. The car never got far enough to run before it came to me. The motor and ****** wasn't even bolted in, but the exhaust was the only thing hooked up. I'll unhook the exhaust tomorrow, and go from there.
  14. Today was a day of no progress. I removed the exhaust and it still won't run. I thought it was going to idle, but that was short lived. The little it did run, it shook really bad. I pulled it outside with a rope. I have other cars that need to be worked on and it was taking up space. I didn't put the new spark plugs in it, but I really don't think they are the problem. I will put them in, and probably wash my hands of it. If anybody has any other suggestions, I'm all ears. The motor is just like the one in this picture that 31Apickup posted.
  15. Wanderlust
    Wanderlust
    Next I’d be making sure the timing is correct, may have jumped a tooth, that’s if you’re still willing to work on it ;)
    SS327 and porkshop like this.
  16. Wanderlust, That's what I'm wondering. I'll get back on it later.
  17. Well it's been about a month since I touched this car. Had some nice weather today, and some time, so I pulled the valve covers. The inside of the heads are dry, no oil. The rockers barely move. The push rods spin. So I'm thinking the lifters aren't pumping up. I'm going to pull the distributer tomorrow and try to prime the oil pump. Hopefully my oil pump primer tool for a small block will work. If not I'll make one. The timing looks to be ok. I don't think the timing chain is bad.
    SS327 likes this.
  18. mcgyver
    mcgyver
    I got talked into putting one in a hot rod for a buddy 20 years ago and from what I recall there were a few quirks when compared to a chevy v8. If I remember right it was highly recommended to pack the oil pump with grease to get it to prime. For sure ask someone else/look in a manual, but I'd investigate doing it.
    I also recall the spark plug gap was double or more what I was used to with a stock HEI.. It also wanted a huge amount of timing once started, it wasn't a stock cam, so not sure if that was normal or not. I found a Q jet intake for it and ran one of those.
  19. Thanks. I'm hoping the oil pump will prime without having to do that. I might put really thin oil in it if it won't prime with the 10w30 that's in it. Did a little research and I guess the oil pump is driven off the crank. So I need to look into that.
  20. SS327
    SS327
    Pack the oil pump with Vaseline. It’s the proper way to get it to prime.
    31Apickup likes this.
  21. I had a lot of experience early on with g body 231s. If it's a low mileage engine it could still have the failure prone cam gear and timing chain tensioner
    SS327 likes this.
  22. SS327
    SS327
    Oil pumps are distributer driven in those.
  23. Also Buick engines use a hex shaft pump drive so SBC prime tool won't work
  24. Picked up a BIG tub of petroleum jelly today. The old lady at Walgreens asked what I was going to do with all that. I just smiled and kept on walking. Hopefully I can get the Cutl*** back inside tomorrow. I probably won't work on it until Monday. I might be able to get a little time tomorrow, but probably not. Saturdays are usually for my buddy and I to do lunch, and then whatever else we decide to do.
    porkshop and SS327 like this.
  25. Nothing new to report. I pulled the Cutl*** outside shortly after my last post. I did pull the oil pump, broke a bolt, but just the head broke off, so I should ne able to get it out easily. I've had two other cars to work on, a 69 Roadrunner convertible, 383 4spd, and a 69 VW Bug convertible. The owner of both of those cars turned out to be a real pain in my ***. I'm going to do some shop rearranging then get back on it.
  26. Just realized you're in Sedalia. I could easily lend a hand if you want
    Fat ASS Whitewalls and porkshop like this.
  27. NoelC
    NoelC
    Having owned a Cutl*** Salon back in the day, I'm going to guess you're 180 out with the distributor. I could be wrong. But if I was to bet money, I'd place money there.
    As for the oil pump, yes, if removed and drained, it should be packed. Otherwise it will be filled with air that won't pull oil in no matter how fast you spin it.
    Also, rotating the crank back and forth watching for rotor movement, measuring the degrees turned will give you an idea on gear /slider wear and chain stretch.
    But you know where I placed my money.
  28. HOTRODPRIMER
    HOTRODPRIMER
    All the shaking sounds like a odd fire V6, I had a 1979 Buick V6 in my Model A pickup and it ran smooth. HRP
  29. Thanks. I work all kinds of weird hours. More in the warmer months. If I need anything I'll let you know. When do you have free time? I'm home all day and tend to go in the house by 5.
  30. I pulled the original distributor myself, and put the new one in the same way. I thought maybe it was 180 out, and tried it 180 degrees from what I had it, it wouldn't start, so i put it back. With the rockers not moving much I'm still learning to it being no oil pressure, and the lifters not pumping up. Thanks.
