9s for $9k
Discussion in 'Off Topic Hot Rods & Customs' started by squirrel, Mar 18, 2025.
  1. squirrel
    it's a brave new world
  2. DDDenny
    What's a flip phone?
  3. Harv
    Harv
    from Sydney
    It's like your standard can-and-string phone, but you don't take the lids all the way off :D
    Cheers,
    Harv
  4. rockable
    rockable
    Jim, I'm sure you know this but double check your filter. Any leak that allows air into the inlet will cause a noise like you describe. Recently, I poked a little hole in a ST400 filer while installing it and it was driving me crazy until I pulled it off and found the culprit.
  5. noboD
    noboD
    What about the phone holders that fit in a cup holder? Cheap does have a cup holder, doesn't it?
    41 GMC K-18, porkshop and Sharpone like this.
  6. squirrel
    This needs to be in front of me, not down where the cup holder is (which also has a holder for my real phone).
    Just for fun I turned off wifi on the cheap dash phone last night, and let it sit overnight, and the battery went from 96% charge to 95% charge. So it has very little battery drain in standby mode.
    I'll play with the 2 step some more today, I'll drop the timing down to zero in the area of -1 to +10 psi boost, 2000-2200 rpm and see what it does.
    And probably just ignore the transmission until it blows up. Or do something with it if I get some inspiration. I had a similar problem with my 55 years ago, it would buzz when cold, when the filter was getting a bit plugged.
  7. RodStRace
    RodStRace
    Jim, the chart looks okay except the AFR during the stall portion.
    I'm guessing it was on the 2 step and the ignition was holding RPM, which is why the AFR went way high? No ignition means oxygen is not ignited, which means more oxygen in the exhaust.
  8. squirrel
    That's what it looks like to me.
  9. TrailerTrashToo
    TrailerTrashToo
    Work continues in spite of my interruption...
  10. squirrel
    getting ready to head up to Tucson....maybe I'll post a few pictures of the Drags...
  11. 41 GMC K-18
    41 GMC K-18
    squirrel and Sharpone like this.
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    porkshop, Deutscher, Sharpone and 6 others like this.
  13. squirrel
  14. riv63
    riv63
    from Texas
  15. oldiron 440
    oldiron 440
    That’s what I do when Sire keeps getting it wrong because if I say you **** it tells me I’m not nice…
    porkshop likes this.
  16. oldiron 440
    oldiron 440
    Good mph looks like it could use converter and boost at the hit.
    porkshop, 41 GMC K-18 and squirrel like this.
  17. squirrel
    still not launching worth a darn...but it is fun to drive!
  18. oldiron 440
    oldiron 440
    If you could get your 60’ down in the 1.40 range and take the difference off your ET that would be worth a smile…
    porkshop, squirrel and 41 GMC K-18 like this.
  19. chicken
    chicken
    from Kansas
    It's certainly making power. 129 mph is typically in the 10.30 ET range in a naturally aspirated car with good 60'.
  20. AmishMike
    AmishMike
    Search internet easy to find formulas use weight, et, or mph to calculate horsepower.; come up with 2 numbers. Mismatch usually means tire spin. With a turbo, mismatch means top end horsepower not there at the start
  21. Do you have a stock converter?
  22. squirrel
    not a stock converter. Notice in the datalog I didn't have the throttle open all the way when I was trying to build boost, that doesn't work.
    I'll play with it some more.
  23. squirrel
    Went back to the tune I had on drag week. Just foot braked without the two step. Quickest p*** yet. Still has a dismal 60 ft, but mph is good.
    I probably won't run again until the beater race tonight.
  24. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Nephew Gene say’s nice.
  25. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I see the underlining connection now. Nephew Gene doing the tap tap as well. IMG_4804.jpeg IMG_4803.jpeg
  26. squirrel
    I got in the 5k beater race.
  27. RodStRace
    RodStRace
    9s for $9k
    10s for 5k;)
  28. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Just sipping… IMG_4805.jpeg waiting on an up date. ;)
    Mean time Jim we gotta head back to the track this morning. Gene struck a deal yesterday to buy a 70 Chevelle. Now the complex part. Getting two cars back home on a one car trailer.
  29. That conundrum reminds me of my demolition derby days. We would sometimes buy a compe***ors car and then need to figure out how to get it home. Usually we stacked them on the rollback
