Hot Rods 1950 Olds 3 Speed Transmission Shifter?
Discussion in 'The Hokey Ass Message Board' started by 51 mercules, Oct 16, 2025.
  1. 51 mercules
    51 mercules
    olds.jpg I acquired a 1950 Olds 3 Speed Transmission from a buddy. Someone was doing an LS swap into a 1950 Olds. My buddy ended up with the 303 Olds Rocket, trans and rear end .A couple of years ago he gave me the trans since he wasn't going to use it. Since then I've been looking for the elusive Hurst Mystery shifter or shifter bracket to no avail. Did anyone else make a shifter for the olds or Lasalle? Also I thought I saw a thread or in a thread on the HAMB where someone was making a shifter bracket? Does anyone remember seeing that. Eventually the Olds is going behind a 331 Hemi.
  2. Tim
    Tim
    from KCMO
    There is an active thread on this going right now, thought I was having double vision lol.
    it’s on page two. I think you’ll find some helpful info there.
    51 mercules likes this.
  3. Andy
    Andy
    You ever see what guys did before shift kits were sold?
    They shortened a column shift ***embly’s so they were only inches long and mounted them on the top of the transmissions. Then lengthen the shift lever and the shifting arms.
    Toms Dogs and 51 mercules like this.
  4. 51 mercules
    51 mercules
    Thank you! I'll see if I can find it.
  5. F&J
    F&J
    The other thread is for the 51-64 Olds selector transmissions. Your 1950 Olds is one year only based on Cadillac side shifted (and older LaSalle side shift transmissions). Several companies made shifters for your style, including Hurst, Eelco and probably others.
    The Eelco was a wild design because it had a shift handle raised "tower" to look like a top shifted transmission like the 37 LaSalle had. I sold mine to a traditional parts collector guy in Rhode Island, but I know I put up pics of it years ago on here somewhere, I will try to find that.
    I also had the Hurst for those transmissions and it uses a very simple and typical looking mounting bracket that uses a normal looking Hurst 3 speed shifter body.
    RMR&C, Tim, tb33anda3rd and 1 other person like this.
  6. The dual pattern hurst is better shifter.
    the bracket should be simple.
    I’ve got a mid 50s gm trans that had a mystery shifter on it. Previous owner made a simple homemade bracket. Cut down some shift arms. Worked ok.
    I replaced it with a NOS duel pattern I picked up recently
    Toms Dogs, jaracer and 51 mercules like this.
  7. F&J
    F&J
    RMR&C, Tim and 51 mercules like this.
  8. 51 mercules
    51 mercules
    That Eelco sounds pretty cool! Thanks!
  9. 51 mercules
    51 mercules
  10. Here’s a pic of the bracket
    guy put a ton of miles on it.
    A guy down here just sold a couple dozen NOS eelco/other non hurst shifters. All late 30s to mid 60s universal applications.
    Might could find out a lead on who got em.
    RMR&C and 51 mercules like this.
  11. 51 mercules
    51 mercules
    Thank you and thanks for the pic!
    anthony myrick likes this.
  12. F&J
    F&J
    RMR&C, 51 mercules, Tim and 1 other person like this.
  13. F&J
    F&J
    Above link pictures, Notice the oblong hole in the main Hurst side bracket for the speedo cable.
    51 mercules and tb33anda3rd like this.
  14. Srfnken
    Srfnken
    This is what you want, sorry not for sale. This bracket is for the ford conversion for the lasalle. But basically the same as the 50 olds
  15. jjjmm56
    jjjmm56
    from FL.
    I have a complete setup. If this is what your looking for.
  16. 51 mercules
    51 mercules
    Yes!Thanks!
  17. 51 mercules
    51 mercules
    Thanks for the pic's.
  18. 51 mercules
    51 mercules
    Nice!Just looking for a shifter right now!Thank you!
  19. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I used to have one of the Eelco shifters you mentioned; a very strange animal.
  20. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I've got a Hurst shifter mounting bracket that's not for sale, but could give you some pictures and dimensions. As for the shifter, just about any Hurst three speed shifter will do. The arms that bolt to the transmission are the same design as what Hurst used for the 1949-65 Chevrolet three speeds, so they're not too hard to find.
  21. 51 mercules
    51 mercules
    That would be awesome!Thank you!
  22. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Guys also used to stick a slab of raw meat on the end of a tree branch and hold it over an open fire for a couple hours. Thankfully, things have gotten better since then.
  23. skooch
    skooch
    We all get your point but maybe use a metaphor that doesn’t sound so damned appealing.
    patsurf likes this.
  24. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I'll try to snap out of my Alzheimer's and get you some pictures tonight.
  25. 51 mercules
    51 mercules
    No prob!Thank you!
  26. HEATHEN
    HEATHEN
    from SIDNEY, NY
  27. HEATHEN
    HEATHEN
    from SIDNEY, NY
    ...and they transferred upside down. Great. Anyway, if you want to try to make one, I could make you a pattern out of paper.
  28. 51 mercules
    51 mercules
    Thank you for the pic's. That would be great if you could make a pattern. I have buddy who's a machinist with a ton of tools that I could use and If i get in trouble he can help me out. Thanks again.
  29. Tdesoto276
    Tdesoto276
    from Des Moines
  30. 51 mercules
    51 mercules
