Projects uncle Charlie's hot rod model A projects
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Feb 19, 2025.
  1. tb33anda3rd
    tb33anda3rd
    thank you, glad you are enjoying!
    Stogy likes this.
  2. patsurf
    patsurf
    is that easier ? more accurate? than taking the door off to work it??
    Stogy likes this.
  3. Grumpy ole A
    Grumpy ole A
    I am so glad you are helping Charlie with this build. It does the old timers good to see a younger guy take a real interest in helping an older guy build his hot rod. Thank you
  4. tb33anda3rd
    tb33anda3rd
    the door has no inner structure left, if I did it off the truck it may not have fit. I will make an inner brace on the truck, then take the doors off and fix any details that I can't get while they are on. I am doing it this way , on this type of build because it is not a restoration or are we looking for anything more than done.
    we are going to keep are eyes out for another set of doors, cheap.
    TFoch, Stogy, dwollam and 2 others like this.
  5. tb33anda3rd
    tb33anda3rd
    Charlie is known a****st are friends as "uncle". For the last 25+ years he has been all of our, "go-to" guy, for any automotive trouble shooting we have needed. Charlie remembers, in detail ,how things he repaired were fixed and what we needed to do to fix them, including hints and tricks to get the job done. for example : how he would "jack back" a rear on a 1950 Buick to change the seals in the ****** instead of taking it all apart and what tool was needed to get the seal to slide into the ball. last time he actually did it was in the late sixties:cool:. we owe him big time and it is a pleasure to help him.
    TFoch, Deutscher, Stogy and 8 others like this.
  6. patsurf
    patsurf
    :cool::cool::cool::):):):)
    Stogy likes this.
  7. ct1932ford
    ct1932ford
  8. ct1932ford
    ct1932ford
    UC project! IMG_2413.jpeg IMG_2414.jpeg IMG_2412.jpeg IMG_2411.jpeg IMG_2409.jpeg IMG_2410.jpeg IMG_2408.jpeg IMG_2416.jpeg
    cactus1, TFoch, Stogy and 7 others like this.
  9. rusty_bits
    rusty_bits
    I love your dash panel, very nice.
    Stogy and tb33anda3rd like this.
  10. tb33anda3rd
    tb33anda3rd
    I can't get Charlie to paint the tank area the light tan to match the panel. I think it would look better if all the raised areas, on both the panel and the tank were light tan and everything else was the dark brown. Charlie says no.
    Deutscher, TFoch, Stogy and 2 others like this.
  11. tb33anda3rd
    tb33anda3rd
    @ct1932ford thanks for putting the pictures up for me.
    TFoch, Stogy and ct1932ford like this.
  12. ct1932ford
    ct1932ford
    I have to agree with you on this one! Should all be one color.
    Deutscher, TFoch, Stogy and 1 other person like this.
  13. Outback
    Outback
    from NE Vic, Oz
    A cool truck with a great back story, good on you guys, it’ll be a grouse lil pickup when it’s done!
  14. tb33anda3rd
    tb33anda3rd
    TFoch and Stogy like this.
  15. tb33anda3rd
    tb33anda3rd
  16. Lookin' great ,keep up the good work :cool:!!
  17. tb33anda3rd
    tb33anda3rd
    thanks! we will.
  18. It just gets better and better.
    Stogy, tb33anda3rd and Robdski like this.
  19. tb33anda3rd
    tb33anda3rd
    thanks
  20. ct1932ford
    ct1932ford
  21. partssaloon
    partssaloon
    I notice you have license plates on it. When you build a truck from pieces like that do you have any problems getting a ***le for it? Totally enjoy watching your builds.
    Stogy likes this.
  22. tb33anda3rd
    tb33anda3rd
    it is registered with the motor number. Connecticut has no inspection, other than, vin is verified by a registered emission inspection station.
    thanks for following along.
    Deutscher, TFoch and Stogy like this.
  23. tb33anda3rd
    tb33anda3rd
    so I stopped by Charlie's and we set the bed sides up with a couple clamps. Plan is to drill a few mounting holes then Charlie will put some primer on them. I also fit the pieces I made for over the doors to seal the top side.
    Charlie started to make up a seat....
  24. Stogy
    Stogy
    That Lil Pickup looks really sharp Fellas...Connecticut Cool Indeed...
    TFoch, deathrowdave and tb33anda3rd like this.
  25. deathrowdave
    deathrowdave
    from NKy
  26. tb33anda3rd
    tb33anda3rd
    that seat was the p***enger seat out of a 1965 suburban parts truck. I made the base under it shorter than the original.
    ct1932ford and TFoch like this.
  27. ct1932ford
    ct1932ford
    cactus1, GuyW, dwollam and 9 others like this.
  28. ct1932ford
    ct1932ford
    The beat goes on! Dash looks much better all one color. IMG_2672.jpeg IMG_2671.jpeg IMG_2669.jpeg IMG_2670.jpeg
    rusty_bits, cactus1, loudbang and 5 others like this.
  29. dwollam
    dwollam
    WOW! I agree!
    Dave
    tb33anda3rd likes this.
  30. Grumpy ole A
    Grumpy ole A
    Love the way the dash turned out.
