I should be able to pick up my 1941 Ford pickup sheet metal soon now that the field work is nearly done (the owner wanted to wait). I was told right up front that there is no ***le with the truck and I wasn't concerned. The issue that dawned on me the other day is that I really have no number to use when attempting to get a ***le since the frame for this pickup is gone. The only frame I have found that wasn't big money or very very far away is a '35. These two things have got me wondering, is it going to be possible to get a ***le that says this is a 1941 Ford pickup? Or are they going to want me to ***le it as "special construction" or some other garbage? I am in Iowa, FYI. I appreciate any words of wisdom you guys can offer.
Ask the Iowa DMV those questions. No other answers will be correct. Remember the answers will change according to how you phrase the question. A local hot rod shop will probably be able to tell you the proper way to do it.
I was just hoping someone in the area had dealt with this recently and could at least prepare me for what I was getting into. The DMV/Courthouse here in Polk County has become completely useless. I have considered licensing everything at my Mom's address just to avoid this courthouse. It would actually be less h***le to drive 180 miles round trip to go and do my business at that courthouse. I wouldn't be quite so angry if it weren't for the specific reason (which never, ever should have been allowed to begin with) that has spurred the awful changes in Polk County. But, I digress.
Go to a friendly small county courthouse and ask the ladies in the treasurer’s office, at a time when they are not busy. Try 10:30. Tell them you are thinking of buying this truck, and ask what process you could use. There might be a process similar to bonding a ***le. I’ve never done it without a frame or transmission that has a serial number stamped in it. I was told you can do all your registration stuff at any courthouse that borders your home county. I haven’t tried that yet though.
I thought Iowa had adopted the SEMA model for ***ling street rods the year after I ***led my '36 as reconstructed. I don't know the details, but supposedly you can ***le them easier as the actual year and make of the vehicle. My '36 is a 2009 Reconstructed vehicle, with the model being 1936 Ford pickup. Gary
I don’t want any other year or special designation on my ***les except the original year. I’ll jump through all the hoops to get the car ***led as it originally was.
My experience from a couple of years ago may help. https://www.jalopyjournal.com/forum/threads/getting-a-***le-for-a-kit-car-in-iowa.1301636/
It seems that without a frame stamped serial number or drivetrain (engine and/or trans serial number), that what you are buying is just some old sheetmetal. There can't be a ***le to something like sheetmetal without any serial number. The idea to buy a 41 parts truck hopefully with a ***le and then swap your better sheetmetal onto it, seems the way to go. Use the parts truck frame or drivetrain serial number that should match the ***le of the parts truck. Even if you have drivetrain serial number, there are processes which allow for swapping out to newer drivetrain if you have the original numbered part. All of this requires talking to your Iowa motor vehicle dept. Or go the special construction route, which you need to talk to your state Iowa motor vehicle dept to determine what that requires.
Find a 41 transmission. A big truck trans should be free. A p***enger/pickup case should be close to free, as most get their guts stolen for use in 39 transmissions. I’ll look in my pile. Then just do a bonded ***le with the number on the trans.
"Ask the local DMV as no other answers will be correct" then "try a local hot rod shop, they probably know" ... Well which is it? Their "local hot rod shop" ain't the DMV so therefore isn't their answer automatically incorrect? If you are willing to accept a local hot rod shops answer, why isn't it possible someone on this site might have the correct answer? Now, where the heck did I set down my Super Strength Midol pills?
I know a lot on here are against ***igned VINs, but I'd rather have a legitimate ***igned ***le tha a 'made up" one. Gary
First you are stuck with what applies to Iowa and no other state. Second, what does apply to every state on a vehcicle like this is that every state wants full do***entation that all major parts = engine, frame, body and maybe trans and rear axle were obtained legally. I've known clowns who didn't keep receipts or bills of sale for the parts they bought because they didn't want their wives to know what they spent on the car. Trust me, they know anyhow. The application for a bonded ***le is pretty simple if you had a vin [Iowa DOT] 411008. Application for Registration and Bonded Certificate of ***le for a Vehicle Ford Barn 41 Ford pickup vin info. 1941 VIN Location - Ford Truck Enthusiasts Forums The simple but not easy solution would be to hunt down the front part of a 41 Ford frame or left frame rail with a good serial number stamped in it. It doesn't matter car or pickup as long as the serial number starts with 18 and has a number within the range. Then make sure that you have a nice looking bill of sale from the seller stating 1941 Ford pickup as is where is no ***le. The 41 car frame is wider and has a two inch longer wheelbase than 35/4o and 41 pickup though. According to this Technical - 41 Ford Car vs 41 Ford Truck Ch***is | The H.A.M.B.
my 31 pontiac was built in 1985 so it had an iowa ***le as a 1985 ***embled vehicle with an ***igned vin, IA51**x. previous owner had ***le transferred to a nebraska ***le with no issues but I wanted to use a 1931 yom plate. nebr dmv said no, yom plate has to match the ***led year.
