Hot Rods New deuce Vicky owner
Discussion in 'The Hokey Ass Message Board' started by deucepickup32, Mar 24, 2024.
  1. :cool::):cool:!
  2. loudbang likes this.
  3. I noticed that there was some pressure build up in the Winters QC last time I checked the level so just installed a remote breather. It’s a small oil catch can and installed it so it’s tough to see plus blends in with the rest of the area. Not shown is the hose that now attaches it to the fitting on the top of the QC.
  4. Took the Vicky to Mill Bay on Vancouver Island Saturday morning for the LG Speed and Kustom reliability run. Raining when I left Parksville and cleared up for the day on the drive. The Buick nailhead is running fantastic with no complaints.
    woodz, rusty1, Tim and 2 others like this.
  5. uncle buck
    uncle buck
    Roger, How was the turnout for Lee’s run? Also I have found that when the differential vent is in the center close to the ring gear it will fling off the ring gear and be a problem. If you find that the catch can fills up try moving the vent fitting to one of the axle tubes.
  6. It was a great turnout and definitely a lot of cars that I have not seen. Each year is definitely getting better. There was a pickup from the mainland and a car from Salt Spring Island.
    Thanks for the tip and I haven’t checked it since install. I was more concerned with the pressure buildup and that is no longer an issue.
    The car is running fantastic and since resolving some steering issues, it’s really nice to drive. I need to reroute the exhaust further back as it presently dumps before the diff which is basically behind the seat.
    bchctybob and loudbang like this.
  7. uncle buck
    uncle buck
    Great to hear! Lee and Shannon are great people and really look forward to doing this. My cousin and I drove our cars up from Washington last year but had a conflicting schedule this year. Hopefully a few of us will make it up next year.
    deucepickup32 likes this.
  8. FYI, a Kia Soul cover fits really well on a fender less Vicky and possibly a sedan
    shortypu, Algoma56, dumprat and 2 others like this.
  9. IMG_0684.jpeg IMG_0685.jpeg I have been thinking about relocating the gas tank since I got the car. I am a huge fan of the Rolling Bones cars and it was an inspiration of the previous owner. There is an aluminum storage box behind the seat that housed the battery and miscellaneous stuff. Spent many hours measuring and determined that it would work as a fuel tank. Battery will stay in its original place in a separate box. Gain a couple gallons capacity and the quick change becomes visible. Awaiting filler neck, cap, sender unit adapter, threaded fittings for fuel delivery and vent, then will have the welding completed. The sender unit has not been accurate and will replace it with a float less version
  10. krylon32
    krylon32
    from Nebraska
    Great story and car. Having done countless V8 quick changes I like to locate the vent in the left axle tube about 10-12 inches from the center. Minimum grease loss and vents the rear good. I normally don't need a hose to carry away the grease.
    Ken Smith and pprather like this.
  11. My issue was pressure build up and the valve that was there was not working. No issues now in that regard.
  12. Erwin
    Erwin
    My thought would include raking the A pillars just a tad to dial it in closer to the deuce profile and less that of the model A that snuck in on it when the lid was hammered.
    Beautiful momentum. Lots done in relatively little time.
    Great work.
  13. Awaiting Tanks float less sender unit to arrive so I can clock the adapter for wiring and then off for welding. Also awaiting a pair of straps for an early 70’s Vette which I will need to modify for fit.
  14. Removed the tank for a better look and liking what I see. Decided not to reinstall the spreader bar and will trim the rails close to the cross member as well as relocate the tail lights under the body. I will be able to bring the tail pipes to the rear body edge as well with the additional real estate
  15. Measured, measured and remeasured then cut the rails. Next task is to position the tail lights.
    loudbang and pprather like this.
  16. Took longer then I anticipated and as close as I could get it dimensionally. Lots of room with the tank relocated to terminate the exhaust behind the axle.
    woodz, pprather and loudbang like this.
  17. IMG_0813.jpeg IMG_0795.jpeg IMG_0796.jpeg Not wanting to use a generic license plate holder and light or drill holes into the sheet metal, I spent many hours making something that works. It mounts to original factory nut inserts on the bottom behind the reveal moulding.
    I also didn’t want the plate to obstruct the view of the qc.
    woodz and loudbang like this.
  18. My tank and battery box is back from welding. Now have to modify the mid 70’s Corvette straps to secure and finish making the fuel line. The aluminum channel on the p***enger side is to protect the fuel line and sender unit.
    dumprat and loudbang like this.
  19. Tank is strapped in, fuel line is done, fuel sender is wired, vent is plumbed and working on the next project.
    AHotRod, bobss396 and Algoma56 like this.
  20. I have never been a fan of the hood hold down system on the early Fords. Plan is to utilize dzus fasteners in the future on the sides.
    I did some research on ways to hold the tops from departing the car at speeds above idle. Don’t like the old man suspenders and thought that the bungee cord or screen door springs might work so went a step further. I made up the parts as pictured and utilized the hinge steel rod. Just need to paint so not as noticeable. $10 worth of turnbuckles and parts I had laying around.
    AHotRod likes this.
  21. Removed the hood latch support brackets and filled the holes today as the sides will utilize dzus fasteners eventually.
    AHotRod and bobss396 like this.
  22. RockyMtnWay
    RockyMtnWay
    I had a plate mounted pretty much the same as you’ve done on one of my previous deuces. Thought it worked great until a buddy of mine travelled behind me on a rod run and let me know that the plate vibrated like banshee tweekin out. Took a video to show me. ****! Had to change it up. Mystery highway buzzing sound went away as soon as I changed it too. :eek::eek:
    AHotRod likes this.
  23. RockyMtnWay
    RockyMtnWay
    When you were researching ideas/solutions, did you see these?
    I’m going to copy idea and build these for my current cars. :):)
    IMG_3415.png IMG_3412.png IMG_3388.jpeg IMG_3387.jpeg IMG_3386.jpeg IMG_3385.jpeg
    AHotRod likes this.
  24. RockyMtnWay
    RockyMtnWay
    PS: Love what you’ve done with the car. Love seeing the quick change exposed. Very nice.
    deucepickup32 and Olcars like this.
  25. I have it supported really well but will definitely keep an eye and ear open for that. Thanks
  26. Thanks and hesitant putting the tank behind the seat but in hindsight, I was sitting on it in my 32 pickup. Not being able to see that fancy qc that the previous owner spent big $$$’s was not working for me either.
