What OT crap are you working on
Discussion in 'Off Topic Hot Rods & Customs' started by anthony myrick, May 9, 2024.
  1. willymakeit
    willymakeit
    Ot is my 1950 A50 Mack truck I put on a rec tube frame with 5.3 ls and4l80e, explorer 3.73 ls rear, quarter ellpt. front end. Chopped the top 4' and sectioned orginal grille 7''.
    Started back up on it about a month ago after setting for 3 years while i worked.
    Bought a 27 t coupe also. I must be sick again
    Okie Pete likes this.
  2. TA DAD
    TA DAD
    from NC
    So the trans. is ready to go back in. This truck has a factory external cooler plus running through the radiator. I moved my parts washer over and hooked it up to flush the lines out. The first photo shows pretty clear fluid coming out of the hose, the second photo with all the black in the tub is what I blew out of the lines even though it showed clean fluid. I spent about an hour doing this until I was satisfied it was as clean as I could get it. Just for reference if your replacing a transmission. DSCN2750.JPG DSCN2751.JPG
  3. guthriesmith
    guthriesmith
  4. Let me introduce my new guy, TJ. He's cool as **** and a hard worker. His truck runs 6.50 in the 1/8th. 20251022_105221.jpg 20251023_113244.jpg 20251023_113259.jpg 20251023_124001.jpg 20251023_124008.jpg 20251023_165118.jpg 20251023_165125.jpg 20251023_165136.jpg 20251023_165145.jpg
  5. ^^^^
    I think somebody might know how to paint. :)
  6. Black_Sheep
    Black_Sheep
    Doing some serious detailing before I put the GTX away for the winter. The engine compartment is the most time consuming, so I got that cleaned up first. I also stripped and repainted the air cleaner base and replaced the fossilized Air Grabber seal. To do the whole car from bumper to bumper will probably take about a week. Then I can switch vehicles around, there's a laundry list of things I want to do on the '58 this winter.
    Deuces, enloe, lumpy 63 and 7 others like this.
  7. Okie Pete
    Okie Pete
    IMG_3115.jpeg Replaced hydraulic hoses going from the hydraulic valves to the couplers so I could repair terraces
  8. seh
    seh
    Pulled my wife's Checker out of storage. Needs rust repair in the floors and trunk. Pulling the engine and transmission out as well. They both leak out of every possible place they can. Going to replace the Th400 with a 700R4 and a full gasket kit for the 350. FB_IMG_1585101334179.jpg
    Deuces, 61Cruiser, Uncle Ronn and 5 others like this.
  9. A 57 Chevy is off topic???? Check out them sweet wheels! :cool::p Block and paint basically, not a bad car at all. Owner told me it was painted around 20 years ago. He just bought it. Few bad spots. But far easier that the majority that comes into my shop ;) 20251024_114046.jpg
    Deuces, 61Cruiser, whtbaron and 7 others like this.
  10. lumpy 63
    lumpy 63
    20251025_115139.jpg Metalwork all done on the camaro, it's off to the painters house to do body and paint. Im sending those awesome wheels to Lloyd after the paint is done:D
    61Cruiser, porkshop, TA DAD and 7 others like this.
  11. guthriesmith
    guthriesmith
    I’m sure Lloyd will LOVE those cool wheels! :D:rolleyes:
    porkshop, TA DAD, Okie Pete and 4 others like this.
  12. SS327
    SS327
    Scary part is he would actually find something to put those wheels on. :oops:
    porkshop, Okie Pete, loudbang and 4 others like this.
  13. Dick Stevens
    Dick Stevens
    Hey, I've got a set of wheels like that, not what I wanted but what I could afford at the time. :oops:
  14. Dick Stevens
    Dick Stevens
    Deuces, 61Cruiser, whtbaron and 6 others like this.
  15. YES!!! I can't lose for winning! :rolleyes: :p
  16. Okie Pete
    Okie Pete
    I bought an aluminum radiator for my 57 Fairlane 500 . When I got it running I put a new br*** radiator in the car . 4 years on the road the seam between the tank and core split . I was told by the old radiator shop man that was a weak area due to the length of the tanks . He repaired it and it’s lasted another 4 years. He has retired . I was going to paint the aluminum radiator flat black but instead I decided to embrace the aluminum. I got out the cordless drill , a rubber bumper and cut 3/8” squares out of a scotch bright pad .
  17. Okie Pete
    Okie Pete
    IMG_3154.jpeg Here’s the end result
  18. MAD MIKE
    MAD MIKE
    from 94577
    Different neighbor picked up an 04 Monte Carlo Super Sport S/C Intimidator. Did not do a ppi, nor ask for advice about it til after purchase and drug it home.
    Is this some kind of pride thing?
    I'll ask for help after funds transfer.
    N- 'What do you think?'
    M- 'Did you at least barter down $1K for tires?'
    N- 'No.'
    M- '...'
    N- 'It's nice though, right?'
    M- 'Your money...'
    Needs engine mounts(6 of them), trying to trace down a possible oil leak which if it's the VCs it will be hell to get to. PS reservoir location is definitely typical FWD V6 GM. Coolant reservoir was empty, rad was low.
    M-'Did you check the coolant?'
    N-'No, why?'
    M-[​IMG]
    N-'Do I have to run premium?'
    M-'If you like your engine in one piece, yes.'
    N-'What if I just cruise around?'
    M-'If you want regular, then get a regular Monte Carlo.'
    Tires are 12 and 15 years old and bald and it just started raining, trying to get the owner to purchase new shoes has been the hardest battle. Car has TPMS, but the tires are so old the TPMS sensors died, so there's a huge red square with TPMS lighting up the dash.
    N-'How do you turn that off.'
    M-'Buy new tires.'
    N-'Yeah, but how do you turn it off?'
    M-'Buy. New. Tye-ers.'
    There may have been some way to turn off the warning lamp with the stock radio, but that is no longer an option.
    Don't get me wrong I like my neighbor, but I'm trying real hard not to ream him anew.:D
    Looking up Wbody or 3800 series forums for info and they are sorely lacking any with good tech. If anyone knows of a good forum/site on this car I'd appreciate a link.
    enloe, porkshop and guthriesmith like this.
  19. TA DAD
    TA DAD
    from NC
    The Suburban is back on the road with a working trans, spent the day cleaning up my old Pontiac and getting ready to look over and service a few things on my new ride. From a trans. shop to a detail shop in one easy step ! DSCN2757 - Copy.JPG DSCN2756.JPG DSCN2758.JPG
  20. CJ95
    CJ95
    Need to get the interior in this 57 done this year. 10k miles on beach towels haha 20230531_204257.jpg
    Deuces, SS327, TA DAD and 2 others like this.
  21. Wanderlust
    Wanderlust
  22. TA DAD
    TA DAD
    from NC
    Checking my new Tahoe over DSCN2757 - Copy.JPG , first thing is always pull the driveshaft, it needs one u-joint. DSCN2761 - Copy.JPG
    porkshop, loudbang and Okie Pete like this.
  23. HOTRODPRIMER
    HOTRODPRIMER
    Gotta replace the belt on my compressor, the way I built the shed I can't remove the shield so I am going to take the cutting wheel and remove it the red neck way.
    It's not really nessessary, I don't intend on taking the shed down so this weekend I'm gonna go cave man on the cage. HRP
  24. lumpy 63
    lumpy 63
    20251031_140804.jpg picked up a standard bore 400 last week so I stripped it down to go to the machine shop. Its getting one of the steel 350 cranks I scored from the closed up machine shop.
    porkshop, Deuces, SS327 and 3 others like this.
  25. enloe
    enloe
    from east , tn.
  26. I thought i scored a standard 350 crank for my falcon the other day, until I checked the mains and they were 2.650 lol... now I have a 400 crank laying around that i don't need!
  27. Let me introduce my new help. This is TJ, he's a bad***. He's a block sanding, mig welding, buffing fool! He's one of those LS guys lol. But I can't argue with him, his junk runs 10.25 quarter mile p***es and he drives it to work. His drag truck runs 6.30 1/8th mile trips. He's a genius on the LS stuff, not too shabby on the other stuff either. He's a helluva ***et. And he fits in with my personality :cool: 20251031_113806.jpg
    wicarnut, Okie Pete, porkshop and 6 others like this.
  28. This is his daily driver I'm talking about... Screenshot_20251031_214808_TikTok.jpg Screenshot_20251031_214756_TikTok.jpg
  29. lumpy 63
    lumpy 63
    20251101_135139.jpg 20251101_135106.jpg Worked on installing the new Saginaw type steering box on the 40 Willys
  30. I watched a guy run a buffer lol... 20251101_125652.jpg 20251101_125520.jpg
