Projects 1954 mercury sun valley
Discussion in 'Traditional Customs' started by glendale, Jun 23, 2025.
  1. patsurf
    patsurf
    Outback and 54delray like this.
  2. oliver westlund
    oliver westlund
  3. glendale
    glendale
    I do not have the factory sun shield. when the headliner goes in, I will have one made. I have reached out to that company and did not get a response. I have also reached out to many tint shops in my area to have the top tinted with uv blocker. all of them declined saying it had too much crown. now that the top is loose, I plan on taking it into a few to see what they say. I have definent concerns about getting roasted out of the car.
    if I don't find the factory piece that is the next plan.
    thank you.
  4. dwollam
    dwollam
    Many years ago my aunt had a '54 Ford with the the gl*** top. She ended up painting that piece with house paint with a brush because of the heat. :(
    Dave
  5. Well, there's still the industrial-sized AC solution...
    I'm sure by now that the original plastic insert has some serious weather-checking going on. But if the link to those Canadians isn't responding I wouldn't give up just yet. I would try calling their phone number before giving up. As an alternative, check around for an architectural plastics or RV/Boat supplier for someone who could form a new one. A skylight supplier should be able to do this. You've got the old one that you could pull a forming buck off of (some plaster of paris with some cloth mesh/wood reinforcement so it can be handled without breaking), you just need somebody with a big enough oven to heat the plastic then trim it to size. And it may be possible to apply the UV film to the flat piece then form both together. There are still a few guys getting bubble tops for customs made, somebody is doing this.
    Outback and warhorseracing like this.
  6. glendale
    glendale
    I am fairly positive I can polish the insert I currently have and I also think I will be able to find someone to put uv film on it now that it is loose. I have heard the repop is around 1500 and I don't really want to spend that currently.
    Outback and Squablow like this.
  7. warhorseracing
    warhorseracing
    from cameron wv
    This puppy oughta keep it cool! 5000 BTU.:p Just have to find a window that you don't want and pop it in.:rolleyes: Put a generator in the trunk to run it. VIOLA! Problem solved.o_O In reality those were an issue that the technology of the day was not ready for. Beautiful cars and your chop is just subtle enough to make the car.:cool:
    Outback likes this.
  8. Yeah, $1500 is a bit stiff on the price IMO. I still think if you did your own forming buck and t******* of the formed piece you could cut the price down a bunch...
  9. And if you do decide to just repolish you what have, I'll recommend Meguiers Plastic Polish with a lo-speed buffer (under 1K RPM) with a microfiber buff.
    Outback, 54delray and glendale like this.
  10. @glendale There's a Tap Plastic store in Sacramento, they show a 50"x98"x.025" clear sheet (enough to make two inserts) for only $170 and they may even be able to point you in the right direction for actual fabbing of it...
    Putting a UV film over the existing tinted insert will cut the light transmission through it even more, kind of negating the reason for having the gl*** top.
  11. flatout51
    flatout51
    I know it isn't traditional but the vintage air in my cars have save me multiple times.
    Outback likes this.
  12. HOTRODNORSKIE
    HOTRODNORSKIE
    Love the car had the cousin to your car a rare 53 50th anniversary addition Victoria they were painted pink with a white top and pink black and white interior with the 50th badges mine had factory spotlights only selected dealers got the car it got stolen off our farm in the late 80s.
    Outback likes this.
  13. glendale
    glendale
    I am going to start by polishing what I have and uv tinting it.
    this car is for sure getting a/c I retire in a few years and want to drive this car all over the country. i will rewire and install a/c next winter budget is a little exhausted currently.
    54delray, flatout51 and Squablow like this.
  14. flatout51
    flatout51
    I get that totally! You're going to have an amazing car!
    Outback likes this.
  15. glendale
    glendale
    Thank you I am very happy with how its turning out!
  16. glendale
    glendale
    IMG_20251021_134657(1).jpg IMG_20251021_134657 (1)(1).jpg IMG_20251020_164423(1).jpg
    he started on the sail panels yesterday. I think it is turning out better then I could have hoped.
  17. patsurf
    patsurf
    Outback and glendale like this.
  18. redroaddog
    redroaddog
    Think tonneau cover for inside that stores in trunk when you don't need it, maybe use snaps ,something that would fold up and not take up a lot of room
    glendale likes this.
  19. glendale
    glendale
    I will for sure have one made when the headliner goes in.
  20. glendale
    glendale
  21. Chadthesailor
    Chadthesailor
    They polish out nicely. I wet sanded 1000,2000,3000, and 5000 then used 3M 3 step buffing compounds. wool pad of first step, the orange foam pad on the other 2. Still a few small imperfections, but 1000% better than it was.
    bobss396, Okie Pete, Outback and 13 others like this.
  22. glendale
    glendale
  23. glendale
    glendale
    I basically combined both of you guys recommendations I did 100,200,300 followed up with meguiars plastic polish. it turned out way better then what I started with. I am happy for now. the insert is loaded up in my truck and I am going to take it a tint shop to see about uv blocker. it has to go back in the car pretty soon so we will see what happens today.
  24. Chadthesailor
    Chadthesailor
    Nice! Looks good!
    Outback likes this.
  25. glendale
    glendale
    Thanks looks way better then I thought it would. Its not perfect but will definitely do.
    Outback likes this.
  26. Tuumer
    Tuumer
    from Finland
    Is there picture before roof polish? I think my roof is not worth polishing...
      322.1 KB
    Okie Pete likes this.
  27. glendale
    glendale
    mine looks just like that even after polishing you can still see the crazing it just makes it harder to see.
    Tuumer likes this.
  28. glendale
    glendale
    we are getting closer. I am very pleased with how everything is turning out.
  29. glendale
    glendale
  30. Squablow
    Squablow
    I like the shape of the rear window, looks like it's sunken into the trunk some. Is it removable somehow? And does it get glued into the body, is there still a gasket? Curious to know how that'll be accomplished. I tried that with my '53 Ford but it didn't turn out near as nice, and always leaked, although mine was a very amateur job.
