Hot Rods Early SBC starter, "S" and "R" terminal question
Discussion in 'The Hokey Ass Message Board' started by OLD REK, Oct 22, 2025.
  1. OLD REK
    OLD REK
    It's probably been answered 100 times, but I can't find it.
    On a modern hotrod, what purpose would the "R" solenoid terminal serve??
    Thanks in advance......
  2. squirrel
    It is used to byp*** the ignition ballast resistor while starting. If the "modern hotrod" has electronic ignition, don't connect it to anything. If it has points, then connect it to the positive side of the ignition coil.
  3. RodStRace
    RodStRace
  4. Joe H
    Joe H
    Its purpose is to supply full battery voltage to the coil while starting, once the solenoid releases, the coil runs off the resistor wire.
    LOU WELLS and chryslerfan55 like this.
  5. OLD REK
    OLD REK
    Understood. Thanks gentlemen.
    LOU WELLS and lothiandon1940 like this.
  6. flamedabone
    flamedabone
    I love those old drawings. No CAD, no fancy animation, just some dude with piece of paper and pencil and here we are still learning from it however many years later.
    -Abone.
  7. BJR
    BJR
    Love the shading on that drawing.
  8. ramblin dan
    ramblin dan
    It reminds me of that book How To Wire Your Street Rod that was around years back.
  9. Mr48chev
    True there and I have a feeling that it wasn't a very old drawing at 6:20 PM yesterday when it was posted if the ink was even dry.
    lothiandon1940 likes this.
  10. squirrel
    oh, it's been around a while
    lothiandon1940 and 427 sleeper like this.
  11. flamedabone
    flamedabone
    It's cool no matter what the age. And, I bet Squirrel can stand it on the back bumper using only the items in that drawing.
    -Abone.
    RodStRace likes this.
  12. patsurf
    patsurf
    :D:D:D:D
    lothiandon1940 and RodStRace like this.
  13. earlymopar
    earlymopar
    The only detail they left off of the illustration are the terminal/post designations on the ignition switch.
  14. RodStRace
    RodStRace
    True. Battery to B, ignition to R (run) and starter to S.
    I don't have a good photo editing program or I'd add them.
    EDIT: Thanks @squirrel !
    Yes, it's I (Ignition), not R.
  15. squirrel
    or you could use Paint, which is a bad photo editing program, but it works, and is free if you paid for Windoze. (I ***umed the switch would have I for Ignition)
  16. Pass The Torch
    Pass The Torch
    Used it to wire my coupe!
    ramblin dan, Algoma56 and RodStRace like this.
