Technical ***October 2025 Banger Meet Thread - Happy Hallloween***
Discussion in 'Traditional Hot Rods' started by Jiminy, Oct 1, 2025.
  1. Outback
    Outback
    from NE Vic
    Isn’t it, that looks wild, what make is it?
    Solid advice :eek::D
    Dannerr, PGA STUDIOS and jet996 like this.
  2. Outback
    Outback
    from NE Vic
    Is the Mallory only aftermarket, or was it available on something.?
  3. Those Mallory distributors came from forklifts if I recall
    I have used them also, just pay attention to the advance rate
    I have found side valve motors need less than the overheads
    YMMV John
  4. Rob Firth makes a cool one! 494867861_985990090039619_7781793956966206200_n.jpg
  5. Outback
    Outback
    from NE Vic
    That he does!
    I have a couple of blowers here which would be fun, a Wade & a Czech one from an aircraft, both 50's it'll be a while before they are put into service....
    Dannerr, winduptoy and jet996 like this.
  6. Kevin Pharis
    Kevin Pharis
    from Califunny
    Wicked kool! But curious why the carb mounts on the blower were cast backwards? Prototype…?
    winduptoy likes this.
  7. brjnelson
    brjnelson
    Harry A Miller
    PGA STUDIOS and winduptoy like this.
  8. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
    I believe they were OEM on some (Ford?) 4-cylinder marine motors too, at least that's what the one I bought on eBay was advertised for.
  9. jnaki
    jnaki
    Hello,
    For a little whimsy, here is a photo of Kent Babler’s 4 cylinder FED in a Tommy Ivo teen drama. Ha!
    “The Ghost Of Dragstrip Hollow.” But, here is another film from the same time period that shows the FED as a real race car in action at Lion’s Dragstrip.
    A Crosley 4 cylinder motor power, in a similar ch***is as the original Tommy Ivo single Buick FED.
    This Lion’s Dragstrip image was cannon fodder for any Halloween images with the bright orange tower color and a special surprise if one digs a little in the photo capture.
    Jnaki
    As midnight approaches, darkness sets in…
    The midnight ride of Kent Babler’s 4 Cylinder FED at Lion’s Dragstrip in 1959…
    Spot the unusual capture from the original film taken in 1959…
    (the headless ambulance attendant… sorry Mr. Childers…)
    Savage Coupe, jet996 and Outback like this.
  10. Been a long time, finally checking in. Been busy with raising the family, but did manage to finish this:
    jet996, burl, 5280A2 and 11 others like this.
  11. PINEAPPLE
    PINEAPPLE
    cool!!!!
    Dannerr likes this.
  12. Deutscher
    Deutscher
    from Germany
    Thanks for sharing, it was another great event.
    Greetings Harald
    Dannerr likes this.
  13. Thanks Dannerr!
    That looks like FUN
    J
    Dannerr likes this.
  14. PINEAPPLE
    PINEAPPLE
    @Dannerr , I spotted in your video what looks to be the "little ****ter" 27 roadster with 32 fenders that Tony Thacker found buried in an LA garage a couple years ago. It was in line to race.. Anybody confirm this? Does it live in Europe these days?
    Dannerr, hotrodfil and Outback like this.
  15. A Boner
    A Boner
    Cool!
    Dannerr likes this.
  16. alchemy
    alchemy
    Anyone know if the repro rockers, shaft, blocks, and other valvetrain stuff from the repro Miller heads will bolt right up to an original? I’ve got a line on a bare original head and would like to see what could be done to make it whole.
    Dannerr, Deutscher and Outback like this.
  17. Dan from Oakland
    Dan from Oakland
    Call Steve Serr or e-mail him at millerhispeedheads@gmail.com and ask. If not, Rocker Arm Spe******ts in Anderson Ca, could probably fix you up. Hope you get the head!!
    Dannerr and Outback like this.
  18. Nope. It’s just been on a European holiday. Romo, Santa Pod, and Pendine.
    Savage Coupe, Dannerr, jet996 and 4 others like this.
  19. Outback
    Outback
    from NE Vic
    Dannerr likes this.
  20. PINEAPPLE
    PINEAPPLE
  21. Motordr32
    Motordr32
    Check with Dan Price for valve train parts.
  22. Thank you for all the comments!
    Yes, it is - no, it's just touring. And the only one in the line up of Brit's, who isn't banger powered.
    I used to be mechanic on Old Red (the red coupe), which just became a part of Hot Wheels' $1 line, as Craig Callum is a good friend and now is cheif designer at WH. But he broke the crank friday evening, so that's why, he was behind the wheel of mine in one shot.
    @hotrodfil's Cream T you might know, and last one is Peter Stevens (designer of a**** other things, the McLaren F1), who build the car around the Alexander head.
    ... humbled to be in that company, to say the least!
    Deutscher, Outback, hotrodfil and 4 others like this.
  23. alchemy
    alchemy
    Some ***embly needed.
    If anyone has a line on valve train parts (pretty sure none of mine are Miller), or articles on tricks and tips, send them my way. I had a short call to Dan Price and will be sending him pics of the situation. Emailed Steve Serr but no answer yet.
  24. Dan from Oakland
    Dan from Oakland
    Those valve stems look a lot like 6 cylinder 235 Chevrolet.. Good thing is the long stems and you can cut them off as needed.
  25. alchemy
    alchemy
    I’ve got one extra valve in the bunch that is cut shorter and a groove added.
    Any idea what these rockers are from? They are on a 3/4” shaft.
    Deutscher likes this.
  26. hotrodA
    hotrodA
    FWIW,
    The ones on my Alexander turned out to all be exhaust rockers from 34 Chevy Standard,
    according to the folks at Chevy Parts Obsolete. The thin wall bushings were the same as flathead Ford connecting rod small end.
    jet996, Dannerr and Stovebolt like this.
  27. Stovebolt
    Stovebolt
    I guess the guys who made these ohv heads originally used whatever they could find that was readily available.
    I know that the original Wayne 12 port heads used Buick straight 8 rockers
    Dannerr likes this.
  28. alchemy
    alchemy
    I don’t think the rockers and shaft I own were what the head came with originally. I think they were collected by someone to replace lost parts. The shaft stands are kinda crude homemade jobs.
    jet996, burl and Dannerr like this.
  29. Jiminy
    Jiminy
