Hot Rods 40 Deluxe coupe ball joint part number?
Discussion in 'The Hokey Ass Message Board' started by FaFaFaFord, Oct 25, 2025.
  1. FaFaFaFord
    FaFaFaFord
    NUB to board here, looking for replacement ball joints, tie rod ends and one for right side Drag link, Moog Part # would be great, stock front suspension. Appreciate in advance.
  2. Black Panther
    Black Panther
    from SoCal
    No ball joints on a '40 Ford if it has its original front axle.
  3. manyolcars
    manyolcars
    I'm impressed -- he has been here for 6 years....and doesnt know what a ball joint is.
    Andamo and 49ratfink like this.
  4. ***Area-51***
    ***Area-51***
    from Ohio
    Does he have mII ????
    He may not know....
    49ratfink and lothiandon1940 like this.
  5. lothiandon1940
    lothiandon1940
    ...He says stock front suspension but, it does appear that he is a bit confused.
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    lothiandon1940 likes this.
  7. 19Fordy
    19Fordy
    Here's a few more 40 photos. No ball joint (as has already been mentioned.)
  8. Well, in the guy's defense, a tie rod end is a sort of mini ball-joint...
  9. nochop
    nochop
    from norcal
    OP may need to maybe use a different term, don’t scare away the new guy. We are here to help
  10. lothiandon1940
    lothiandon1940
  11. FaFaFaFord
    FaFaFaFord
    I guess I was not clear enough, my apologies, I am calling tie rod ends Ball joints, So I guess I am looking in for TIE ROD and DRAG LINK ends :), I appreciate any help I can get. No MII stock straight axle
    Thank you
    dwollam, LOU WELLS, 40FORDPU and 7 others like this.
  12. Moriarity
    Moriarity
    SUPER MODERATOR
  13. Weedburner 40
    Weedburner 40
    ES416 R/L are the numbers for the tie rod ends. They are available from any parts store and Rock Auto. If you have the stock 40 Ford drag link, that should be available from most early Ford suppliers such as Joe's Antique Auto.
    warbird1, lothiandon1940 and Budget36 like this.
  14. blackbeard40
    blackbeard40
    from Maryland
    I believe you can find the parts you need at Speedway, CCP, or Bob Drake.
    lothiandon1940 and nochop like this.
  15. alchemy
    alchemy
    Don’t cheap out on tie rod ends. Get good Moog ones.
  16. Double check with new Moog ones as some are not made in the USA.
  17. FaFaFaFord
    FaFaFaFord
    Everyone thank you for the help, found genuine moog and have them on order
    nochop, Johnny Gee, LOU WELLS and 5 others like this.
  18. lothiandon1940
    lothiandon1940
    Sweet '40. You can avoid thumbnails by hitting the FULL IMAGE ****on before the REPLY ****on. IMG_20221023_124642278_HDR.jpeg
  19. 19Fordy
    19Fordy
    That's great. So now you are in a "good Moog?.
    Question: Your louvres look really good. How do you prevent water from
    dripping down onto the engine. Just curious.
  20. Mr48chev
    As others said the tie rod ends are Moog ES416L and ES 416R that you can order locally and save waiting and shipping. Or you can order them on Amazon too.
    They are readily availble common parts that fit Fords and others up into the 60's and not "rare parts" so don't pay a rare parts price.
    You can buy one end for the drag link but have to go to a Vintage Ford parts house for the complete drag link. The short Screenshot (1407).png Screenshot (1412).png rod end that screws into the sleeve is another ES416L if the other end isn't worn out.
  21. seb fontana
    seb fontana
    from ct
    Isn't there a ball joint at the rear end of the wishbone [radius rod]?
  22. FaFaFaFord
    FaFaFaFord
    Ya don’t, when I wash it which is rare, I cover cold motor with plastic tarp,try not to drive in rain but I have, ya go fast enough water just rolls off ;)
  23. 34Phil
    34Phil
    I just put a rubber washer under the carb stud wingnut
