Hot Rods How tall is too tall for a ‘32-‘34 Ford Roadster?
Discussion in 'The Hokey Ass Message Board' started by RoadFarmer, Oct 27, 2025.
  1. I’ve been wanting to look for a roadster…. Preferably a ‘32…. I’m 6’5” 270….. should I move on and quit my dreaming?
    Curious if any other tall guys have roadsters here and what you’ve done to make it drivable. I’ve seen some stretched ones here and there but they’re always really expensive. Thanks for the tips!
  2. Royalshifter
    Royalshifter
    Moderator
    Kleet Norris photographer is 6 foot 6 inch and he runs a chopped model A coupe if that helps.
    alanp561 and RoadFarmer like this.
  3. Jalopy Joker
    Jalopy Joker
    just don't expect to stretch your legs on long drives unless you stop by the side of the road to do it
    alanp561, lothiandon1940 and vtx1800 like this.
  4. Joe Blow
    Joe Blow
    Pat (RIP) was 6'6" and drove a 32. The right seat would be key.
    Great pic of him.
  5. Bandit Billy
    Bandit Billy
    Just don't chop the top. I'm 3" shorter than the OP but similar size, with the top up I ram my head into the crossbow when I hit a good bump at highway speed. Top down, no issue. Not a ton of leg room but for an hour or so it isn't bad. If you lived closer, you could try it on for size. The one in the back fits better.
  6. Marty Strode
    Marty Strode
    He was 6’8” in his prime!
  7. Primered Forever
    Primered Forever
    from Joplin,MO
    I’m 6’7” and had a 32 roadster no problem. Seat is the key.
  8. Ziggster
    Ziggster
    Good to know as I’m 6’-6”, but to be comfortable for a long trip is paramount for me.
    49ratfink and Joe Blow like this.
  9. krylon32
    krylon32
    from Nebraska
    Thin the back down significantly. You don't sit on the back so it doesn't need to be very thick. Just a couple inches of good foam will do it. I've done a number of deuce roadsters over the years so I have to reeducate the trim shop every time. I just sold one with a bomber bench that had a thin back pushed way back, It was very comfortable. Starting another with a Brookville body that has the p***enger compartment slid back 2.25 inches and the doors stretched the same. Saw that done on the Steadfast Instagram pages. It's down a ways but you can see how it's done. Doesn't change the exterior dimensions of the body.
    rod1, Tim and lothiandon1940 like this.
  10. 05snopro440
    05snopro440
    Look at Mekenzie Murphy's pink 32 roadster that Johnson's Hot Rod Shop built and debuted in the 2024 America's Most Beautiful Roadster compe***ion at GNRS. It has the back of the ****pit moved back for more interior space.
    gnichols, alanp561 and lothiandon1940 like this.
  11. mrspeedyt
    mrspeedyt
    I guess I'm a shorty at 6'3. But yeah the seat makes all the difference.
  12. krylon32
    krylon32
    from Nebraska
    I built a steel Dearborn Deuce highboy when they first came out. Lots of room, easy to get in & out. Best of both worlds. As usual someone came along with an offer I couldn't refuse and it's now in Japan.
  13. RockyMtnWay
    RockyMtnWay
    Everyone is already all over having the correct seat aspect of this deal, but there’s slightly more to it. When building the rear bulkhead. Leave room for the seat to go slightly under the rear panel. I’m 5’10” and can just get comfortable (ie 3 hours behind the wheel) with the rear bulkhead right below the front of the rear panel. Being able to move the seat back (and under the rear panel) a few more inches would really help a taller dude. Picking the correct seat to keep your *** as close to the floor will be a must too.
    Next bit that others haven’t mentioned yet is the size of the doors and what that means once the steering column is in. The Mekenzie being referred to above is a very young and skinny waif so her being able to wiggle in around the pulled back steering wheel isn’t an issue. Shes all legs so Johnson’s had to mount her steering wheel as far back as possible.
    Being a little more chubby, like me, would make access way harder if not impossible if I mounted my wheel in that position. Reason being, when you mount the steering column/wheel far enough back so you can still reach it easily (without feeling like you have to sit up) and the roadster doors being what they are, they are competing for the same space.
    FYI: The last 32 roadster I did, I used a 30” column (non-tilt) and mounted it so wheel was finger depth from dash and getting in with the top on was ‘interesting’. On my current build, I’m gonna make life easier and use a tilt column (32”). This should help me getting my chubby *** in and out, even if I don’t really like the look …. and still easily reach it when the seat is fully back/reclined a bit for comfort. I love road trippin so comfort is key.
    I can round up some pics that may help you visualize if you’d like.
    Hope that helps, and rest ***ured that where there’s a will, there’s a way.
  14. HOTRODPRIMER
    HOTRODPRIMER
    I'm short at 6'4" and I fit fine in my old '32 roadster, the seat makes a big difference.
    My roadster had a chopped windshield.HRP
    RoadFarmer, Just Gary, rod1 and 4 others like this.
  15. HOTRODPRIMER
    HOTRODPRIMER
    You and Randy Nash are about the same hight and weight, he fit fine in his roadster, his roadster did have a stock windshield frame. HRP
    lo c dan, rod1, mrspeedyt and 3 others like this.
  16. HOTRODPRIMER
    HOTRODPRIMER
    Another phot of Pat Ganahl & his roadster, 6'6" and a chopped windshield. HRP
    Just Gary, rod1, mrspeedyt and 4 others like this.
  17. Bandit Billy
    Bandit Billy
    I know a buddy with one for sale at the moment still in bare steel. He sent me pics the other night and he was trying to list in here in the cl***ifieds. Glad to p*** on his contact info.
    ekimneirbo, RoadFarmer and alanp561 like this.
  18. Troublemaker427
    Troublemaker427
  19. lothiandon1940
    lothiandon1940
    I'm a midget at 5'10" compared to you lanky lads but, as mentioned, it's all about seat placement and configuration.:D...Don't think Caddy, think Hot Rod. Westminster bound (1) (1).JPG 378334339_851905992972833_3021948720990430898_n.jpg
    Just Gary, rod1, jnaki and 5 others like this.
  20. alanp561
    alanp561
    Hey, is them your legs or are you riding a chicken?;)
  21. lothiandon1940
    lothiandon1940
    ....You're killin' me Alan.:):D:p:D:p
    Bandit Billy, alanp561 and Joe Blow like this.
  22. pprather
    pprather
    I have a Dearborn Deuce highboy that I'd like to sell. Does that interest any of the tall guys?
  23. krylon32
    krylon32
    from Nebraska
    Phil: Better keep it till next year for a final run to the 60th LARS.
    pprather and lothiandon1940 like this.
  24. pprather
    pprather
    Still proudly displaying the 50th sticker on my DD.
  25. krylon32
    krylon32
    from Nebraska
    Me to, mine is sill on the roadster
    lothiandon1940 likes this.
  26. alanp561
    alanp561
    I can only wish:(
    mrspeedyt and lothiandon1940 like this.
  27. Thanks for all of the recommendations! Hope is not lost!
  28. Hey RoadFarmer, I have a 32 Dearborn Deuce rolling body for sale that I posted here on the H.A.M.B. and it was removed for not being traditional enough for this site. If your interested please DM me and I'll shoot you pictures and info...... your hope is not lost just misguided come let me show you the way! Hahaha....
    alanp561 and Bandit Billy like this.
  29. Squablow
    Squablow
    32-34 roadsters are like a school bus compared to a T roadster so I don't know if it'd be necessary, but I made a little dropped floor pan box in my T, basically my heels drop down between the frame rails a bit just behind the pedals and it makes a big difference. It allows the seat to be low in the car without having to accordion your legs up as much.
  30. A Boner
    A Boner
    It’s surprising how every fraction of an inch, in every direction helps with driver comfort!
    mrspeedyt, Squablow, alanp561 and 2 others like this.
