Hot Rods What fuel filters are you running
Discussion in 'The Hokey Ass Message Board' started by panhead_pete, Oct 27, 2025.
  1. panhead_pete
    panhead_pete
    After running out of gas yesterday which lead me down a rabbit hole as the feed line to the pump ended up blocked...... Im going to replace all the lines as there are some minor cracks and the filter needs to be replaced too. Its currently a plastic/steel one like the one in the pic between the pump and carb. What filter I should I install to reduce the risk of fire etc and should be installed prior to the pump. Running 3/8 rubber fuel line.
    Thanks!
  2. George
    George
    Wouldn't run clear plastic except to see if you got the plugged line problem fixed. Metal one for me.
  3. 325w
    325w
    Metal filter only.
  4. RockyMtnWay
    RockyMtnWay
    I’ve used a version of the old gm canister type fuel filter on my last 3 builds. You can find ones that flow left and ones that flow right to help facilitate best location to mount it and which rail you want to run the fuel line up. And I mount as close to the fuel tank as possible.
    First one of these that I used lasted more than ten years and I’m betting the guy that bought the car (years ago now) hasn’t changed out the element yet either. :p:p:p
    GM #s - GF-62P, or GF-62C, or if you want to make your own bracket GF62.
    ***pics don’t want to load just now***
    Chief 64, lostn51 and jet996 like this.
  5. RockyMtnWay
    RockyMtnWay
  6. squirrel
    33033, which is a Wix number, but availability might be iffy, especially in Japan.
    Might find something EFI related that would do the job. I don't know what the application would be that you would find easily in Japan.
    jet996 and Joe Blow like this.
  7. Joe Blow
    Joe Blow
    Along the inner frame rail.
    rod1, -Brent-, das858 and 10 others like this.
  8. deathrowdave
    deathrowdave
    from NKy
    Only issue I have with this style is da can gets seized . But only filter I used for years
  9. Different colors
    Reusable element inside
    down-the-road, jet996 and Joe Blow like this.
  10. lake_harley
    lake_harley
    Stock Model A gl*** settling bowl with a perforated metal disc "filter" at the outlet on my '31 Coupe. Amazing the amount of rust particles it collects out of the stock fuel tank. Easy to see what's been collected, dump out the junk and keep on going.
    Lynn
  11. DDDenny
    I have these on two cars, bought many years ago, so long ago I didn't know they were discontinued.
    I have a System 1 on another car also.
  12. MAD MIKE
    MAD MIKE
    If you can get the metal filter found in 85-95 GM efi cars/trucks.
    Bosch F0119
    Wix 33481
    Mann WK6122
    Fram G3727
    AC Delco GF952
    16x1.5 mm threaded both ends.
    ~60mm diameter by ~110mm length.
    About the size of a rear hub off a BMX.
    Can tuck up inside a frame rail.
    Being it's for efi it also uses a finer media to trap particulates. No more worries of getting 'mud' in your carbs p***ages.
  13. rusty valley
    rusty valley
    In my 34 I used a spin on unit from a mercruser boat app. The whole thing, mount and filter can fits in the frame rail of the Ford. Sorry, no pics or part #'s, look at ebay for an idea of what it is. Bobcat skid loaders have about the same small unit, and probably some kubota stuff too....Bingo... kubota is in your neighborhood
  14. panhead_pete
    panhead_pete
    With those solid WIX filters how do you know if they are dirty etc?
    chiro, klleetrucking and Joe Blow like this.
  15. Beanscoot
    Beanscoot
    Stock ones, except on the old truck I added one of the early gl*** sediment bowls mentioned earlier. I would previously have to swap out the regular filter every tank or two of gas, now it lasts hundreds of miles!
    I like being able to dump out the muck from the gl*** bowl, give it a wipe with a rag and carry on. I also lucked into a small box of the br*** screens that fit the bowl, they seem to corrode away fairly quickly with modern gas.
  16. rusty valley
    rusty valley
    How do you know if they are dirty? you just change them once a year. The spin on can is so much bigger than the little inline things I highly doubt you would ever have one plug up
    loudbang and Joe Blow like this.
  17. Joe Blow
    Joe Blow
    Like Rusty said, I change it once a year......and I have it ahead of a Filt-O-Reg, with a gl*** bowl.
    rod1, -Brent-, bchctybob and 4 others like this.
  18. dalesnyder
    dalesnyder
    A lot of people are not aware of the newer green stripe fuel hose that holds up to ethanol.
    You may want to use that also.
  19. V8 Bob
    V8 Bob
    My choices are aluminum filter housings with reusable SS elements that can be dis***embled and cleaned. They are available in various sizes, colors, configurations, price and micron filtration.
    57chevymadman and Just Gary like this.
  20. bobss396
    bobss396
    I use them too, found on eBay in a 5 pack for a good price. The clear plastic ones give me the horrors.
    mad mikey and Joe Blow like this.
  21. Just Gary
    Just Gary
    I have an Earls 85-micron #2302206 filter between the tank and pump,
    and an Edelbrock 40-micron #8129 between the pump and carb. Both can be dis***embled, cleaned and reused.
    mad mikey, rod1, -Brent- and 8 others like this.
  22. Harv
    Harv
    from Sydney
    If I forget to change the filter (life gets busy), I rely on the "abuse and neglect" maintenance model. I carry a 6" length of fuel hose and some hose clamps. When the motor starts to miss, I limp it home and change the filter. If it is too far from home, I remove the filter and McGyver it with the fuel hose.
    Cheers,
    Harv
    rod1, bchctybob, Joe Blow and 2 others like this.
  23. lostn51
    lostn51
    from Tennessee
    That makes two of us, had no idea that they quit making them. This was always my go to filter mounted on the frame near the tank tucked away from sight.
    Yep the method I use way too often……:oops:
    firstinsteele, Joe Blow and Just Gary like this.
  24. 51504bat
    51504bat
    Not one of these. Don't ask me how I know.
  25. leadsled
    leadsled
    I like the Edelbrock filter. i steer clear of the plastic
  26. vintage6t
    vintage6t
    from CT
    I'm currently using one of these from Amazon. Installed between the fuel pump and carb. 30 micron bronze element. Comes apart for cleaning. Seals with an o-ring which hopefully doesn't turn out to be weak point in terms of leaks. I also have a metal can WIX between the fuel tank and pump.
    mad mikey, Just Gary and Joe Blow like this.
  27. squirrel
    if the tank was full of **** from sitting a long time, you'll know when it gets plugged up because the car stops driving. After you change it once or twice, it will last for years without getting plugged.
    If the tank is clean, then you probably will never drive the car enough to have to change the 33033 filter, but you'll probably want to replace the rubber connecting hose some time, unless you get the type that is specified for fuel injection use.
  28. 57tailgater
    57tailgater
    from Georgia
    I think these are either being discontinued and/or they have stopped making them. Seems like almost everywhere you look for them they are out of stock. I like the design though.
  29. 1971BB427
    1971BB427
    from Oregon
    I have those same Fram 10 micron filters on two of my cars. But I also have the clear plastic the OP showed in his first post, and have used them for decades without issue. I don't mount them where they're near any heat or could get against anything sharp, and don't see why people are uptight about them. I like seeing when they look dirty so I know when I need a new filter.
    klleetrucking likes this.
  30. '29 Gizmo
    '29 Gizmo
    from UK
    I prefer the vintage look. Use vintage tractor suppliers for best prices
    neilswheels, rod1, jimmy six and 5 others like this.
