38 Ford Coupe Transmission
Discussion in 'The Hokey Ass Message Board' started by 68 Coupe, Oct 28, 2025.
  1. 68 Coupe
    68 Coupe
    I am rebuilding the transmission for a '38 Coupe Model 82A. I believed it has the original 60 HP engine and transmission. However, I have been having some trouble with replacement parts. When I buy an item that is supposed to fit a 37-39 60 HP trans, the parts are generally too small or don't look like what is in the transmission. My most recent issue is that I replaced the clutch cross shaft bushings and reamed them to fit the existing shaft. I would like to replace the shaft since I now believe it is slightly bent. The shaft is about 13 1/2" long (Ford parts book number 73-7510). Every replacement I find is more like 11 to 11 1/2 long. Does anyone know where I can get a replacement shaft that will match the existing one? At this point I'm not sure what to search for. The transmission serial number is stamped *54 401510 above the clutch inspection cover, and the casting number is 78-7006 with the bottom rib.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    Moved to the main forum where more people will see it. The antiquated forum is for NON automotive 1965 and older collectibles
  3. alchemy
    alchemy
    Some 60’s had a transmission that took full size internals. I think only the case was special.
  4. Petejoe
    Petejoe
    from Zoar, Ohio
    rusty valley and Tim like this.
  5. rusty valley
    rusty valley
    Yup, Van pelts sales....Mac is the man. Currently on vacation I believe, but something will happen if you call
