Hot Rods How To Fill Motor Oil Down a 1/4 Inch tube
Discussion in 'The Hokey Ass Message Board' started by Janius, Oct 28, 2025.
  1. Janius
    Janius
    from New Jersey
    Okay, I screwed up. After I have ***embled EVERYTHING, I found I did not put together the right pieces of my transmission. The result is that I have to fill the transmission through a 1/4 inch hole in the top cover that is only accessable under the dashboard. So there is very little room. I need to put in 1 1/2 quarts of motor oil. Since this is a VERY creative group, I am open to suggestions (I do not want to take everything apart again!).
  2. Jack E/NJ
    Jack E/NJ
    from NJ
    A funnel, tygon tubing & gravity.
    tractorguy, Tim and HemiDeuce like this.
  3. Cosmo49
    Cosmo49
    What model transmission?
    Johnny Gee likes this.
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    A pump oil can with a rubber hose over the end. What kind of car are you working on???? IMG_6390.jpeg
  5. Bird man
    Bird man
    from Milwaukee
    Warm it up.
    RICH B and ClayMart like this.
  6. swade41
    swade41
    from Buffalo,NY
  7. Doublepumper
    Doublepumper
    from WA-OR, USA
    I used one of those cheap pump sprayers for something similar. Worked better than I thought it would.
    Janius and AccurateMike like this.
  8. bob b.
    bob b.
    from peoria az.
    I use a electric fuel pump
    Janius and alanp561 like this.
  9. Ziggster
    Ziggster
    Agree 100%. Got the Home Depot version and used it to pre-oil my flathead. Cut off the sprayer tip/nozzle and adapt as required.
    VANDENPLAS, Janius, jnaki and 6 others like this.
  10. lake_harley
    lake_harley
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Transmission, 1/4” tube, motor oil. We need more info by golly.
  12. alanp561
    alanp561
    o_OStill waiting to hear what kind of ******?
    Tow Truck Tom and lothiandon1940 like this.
  13. GTS225
    GTS225
    That does sound like a problem. Does this trans have some kind of vent somewhere, or is the 1/4" tube the vent? I ask because as you put fluid in, you're going to have to allow air out.
    This is going to take FOREVER!
    Roger
    warbird1, Janius and Tow Truck Tom like this.
  14. Bandit Billy
    Bandit Billy
    I watched a show last night where they drank a shot of vodka and yak sperm. That has nothing to do with anything but worthy of mention. You need to force it down. Gravity is not your friend. I use a pump much like @Ziggster showed to fill ******s and diffs. Work great and especially in confined spaces. Too bad it is inside the car under the dash but it is what it is. Nostrovia!
  15. Dick Stevens
    Dick Stevens
  16. ALLDONE
    ALLDONE
    get a marine oil change pump... the hose goes down a dip stick tube
  17. akoutlaw
    akoutlaw
    alanp561 and 1952henry like this.
  18. TCTND
    TCTND
    Roll the car over and pour it in the drain hole.
    Janius, RMR&C, bob b. and 7 others like this.
  19. Jalopy Joker
    Jalopy Joker
    Still stuck on part about putting motor oil into a transmission
  20. Budget36
    Budget36
    A transfer case maybe?
  21. lothiandon1940
    lothiandon1940
    .............:eek:
    alanp561 likes this.
  22. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    I would bet it is an off topic foriegn with O/D.
    They croak on gear lube.
    That'd work, but we want pictures:D
  23. mohr hp
    mohr hp
    from Georgia
    Billy, it's time to turn off the TV!
    GuyW, Bandit Billy, alanp561 and 2 others like this.
  24. Happydaze
    Happydaze
    I made an oil pumper from a pump action one gallon hand cleaner container and some narrow bore hose. The pump mechanism screws straight onto oil containers. Works great! Less of a workout than I thought. Great for transmissions and axles. Surprisingly clean too. Previously I always made a terrible mess with squeeze action bottles.
    Chris
    Tow Truck Tom likes this.
  25. NoSurf
    NoSurf
    Would a regular grease gun work?
  26. 37 caddy
    37 caddy
    from PEI Canada
    I would use a undercoating gun,i have one that holds a quart of fluid and is air powered,it has a small end/nozzle the size of brake line tubing,i dont have a picture of it,but should be easy to find one,wasnt expensive.
    Tow Truck Tom and NoSurf like this.
  27. Mac VP
    Mac VP
    Janius……you might get better advice on this question if you can tell us more. You might possibly get bad advice if everyone misunderstands your question. Do yourself (and everyone here trying to help) a favor and come back to the forum with some details. Even if you solved the problem, it might help others who have faced a similar issue. So……
    * specifically which transmission?
    * what model vehicle?
    A photo of the setup would also be very helpful. We often “see” the situation differently and might be offering a solution that doesn’t address your problem correctly.
  28. flatheadpete
    flatheadpete
    from Burton, MI
    Gross! I hate vodka.
  29. Jack E/NJ
    Jack E/NJ
    from NJ
  30. I have used a big-***ed syringe fitted with thin flexible tubing. It holds about 150ml.
