Technical 1940 Chrysler Windsor xmsn
Discussion in 'The Hokey Ass Message Board' started by gatz, Oct 29, 2025.
  1. gatz
    gatz
    What the heck would the xmsn be in this 40 Windsor?
    If that's the original layout, there doesn't appear to be a clutch pedal, either.
    On edit, I contacted the seller. he said it's a std shift and there IS a clutch pedal
    I don't recall seeing a quadrant like that.
  2. choptop40
    choptop40
    Cool car,,they had a lot of plastic/bakelite ? could be reproduced with a 3d printer....
  3. gatz
    gatz
    Yes, I have a '40 Royal (avatar) and was seriously considering making those soybean parts on a 3d machine.
    However, I found that a 46-47 dash will fit with a little modification.
    IMO, those look much better than the '40 and with some more work, was able to fit a Kenwood
    CD / radio unit into the big chrome center piece. Kenwood has a stepped front that nearly fits, but the chrome piece had to be opened up on the backside just a little.
  4. gatz
    gatz
    On enlargement, it now looks like a regular 3-speed shift. The way the lever entered the column opening kinda threw me off. Doh
  5. 302GMC
    302GMC
    from Idaho
    Appears you have the overdrive as well.
    6inarow and chryslerfan55 like this.
