Technical A shocking problem
Discussion in 'The Hokey Ass Message Board' started by wheeltramp brian, Oct 29, 2025.
  1. wheeltramp brian
    wheeltramp brian
    On my daily driver 1955 Plymouth. The front end was getting a little sloppy. And I could hear a clunk on the left side. Turns out the shock was broken and I had already ordered a set of k Y b gas adjust to swap it out. Swapped out the shocks and what a difference ! a much firmer ride and less body roll. I do have the sway bar upgrade to put in also, but that will be maybe next week. The swaybar is out of a 20251028_165225.jpg 20251029_071020.jpg 20251029_071040.jpg 20251029_071049.jpg 1999 Jeep XJ that can be bought new at the part store for pretty cheap. Note that these shocks are a inch longer , so I made a spacer to go between the a arm and the shock to let it hang a little lower so it doesn't bottom out. I put a zip tie on the shaft to see if it makes contact or not.
    guthriesmith, swade41, hrm2k and 7 others like this.
  2. KevKo
    KevKo
    from Motown
    What diameter is that sway bar? And what is the width eye to eye?
  3. wheeltramp brian
    wheeltramp brian
    This sway bar is an inch. I can get you the specs when I get back to work tomorrow I had to step out for the day. The end mounts on the A arm side need to be fabricated. Here is a picture of the ends on another person's car. DSCN3015.JPG 262793_218964304803192_4178916_n.jpg
    hrm2k, Jalopy Joker and bchctybob like this.
  4. squirrel
    I forgot to measure the diameter, but it's about one inch.
    this is off my 95 xj.
    dwollam, alanp561, RodStRace and 3 others like this.
  5. Is the barrel of the lower shock mount parallel with the lower control arm inner shaft. If not the shock breakage could be caused by that. Shoebox Fords do that if the original mounting holes are used.
  6. 51504bat
    51504bat
    @squirrel I see your wearing AZ safety shoes?:cool:
    dwollam, alanp561 and bchctybob like this.
  7. wheeltramp brian
    wheeltramp brian
    Yup that's the bar
    bchctybob likes this.
  8. squirrel
    yeah, they keep me safe from the razor blades laying around
  9. Mimilan
    Mimilan
    You can use Nissan Patrol/Sentra/Skyline/ Bluebird end uprights [end-links] on these types of swaybars.
    One end is a balljoint and the other end has conventional bushings .
    This cir***vents the need for a bracket on the A-Arm, just drill a hole and use a washer.
    This is an Aussie Holden K-Mac bar [basically F-Body Camaro] on our 57.
    showing the Nissan uprights [end-links]
  10. wheeltramp brian
    wheeltramp brian
    Nice, any year on the Nissan parts?
  11. Mimilan
    Mimilan
    U13 Bluebird [mid 90's]
    N16 Sentra [2000-06] try Delphi TC2882
    GU patrol use the same type but a lot taller
    We used U13 Bluebird because the swaybar was lowered on blocks [red] for front X-member clearance[green]
    This is considered a suspension mod in NZ so it required certification ,therefore the blocks needed to be welded to the frame.
    The holden bar was great, it cleared the tyres on full lock.
    Your car should be different [so happy hunting]
  12. DDDenny
    Those are genius end links!
    My drag car had Spax coilovers on the front when I bought it in the late seventies, they had ball insert weldments on the ends, while doing a "street test" an end broke off, I had my friend TIG weld it back on.......could have been real interesting at the track!
    Mimilan likes this.
  13. wheeltramp brian
    wheeltramp brian
    Got the links cost about 25 bucks. They may be a little short, but we'll see when I get it installed. 20251030_123554.jpg
    Mimilan and RodStRace like this.
  14. jaracer
    jaracer
    Pop tops. (Jimmy Buffet)
  15. seb fontana
    seb fontana
    from ct
    Hope there is more weld....:eek:
    Johnny Gee likes this.
  16. Mimilan
    Mimilan
    Do you get Nissan Silvia's over there.
    Try S13, S14 or S15 End links , they are longer.
    They are about $27 using our "pacific peso"
  17. wheeltramp brian
    wheeltramp brian
    These were for a sentra.
  18. Mimilan
    Mimilan
    They worked OK on a Sentra [so as long as you get the geometry within range ,it should work OK
    Here is an Aussie listing [for others to benefit here as well]
    https://febest.com.au/0223-fe34-feb...DuDqqFroy-8KpU3sOkjqjFiBPxsjMJptVy1p6DyjNmKWY
    scroll down is a list of cars they fit.
    My end links were given to me by a "drifter" who was trying to improve his car with anodized parts
  19. wheeltramp brian
    wheeltramp brian
