Projects 1932 Ford 3 Window with 389 Pontiac
Discussion in 'Traditional Hot Rods' started by Ken The Coug, Feb 16, 2018.
  1. catdad49
    catdad49
    Congratulations on moving forward from the “project” stage. I Love how you “fixed” the wonky deck lid (fill it Full of Louvers)!! Sounds like you’re having Fun with Dad’s Deuce, Enjoy.
    Stogy, enloe and 59sedandelivery like this.
  2. NO! LEAVE IT.
    Ben
    cactus1, slayer, Stogy and 1 other person like this.
  3. dirt car
    dirt car
    from nebraska
    Not a big fan of channeled cars but in this case looks great, taillights & license tag I'm unsure of, but since they were already in place might see how it plays out, don't mind me do your own thing & be everyone's envy!
    Ken The Coug likes this.
  4. 6sally6
    6sally6
    Turned out GREAT...if you ask me !
    One question....did you go with the tremac or ???
    6sally6
  5. xhotrodder
    xhotrodder
    Several things you can check on the overheating? starter issue. Like Stuart in Mn. said above you could try a heat shield, you could have your starter rebuilt or buy a heavy duty starter, if your battery is in the trunk your battery cables may be to thin & you may need to upgrade to heavier duty battery cables. Also, check your compression in each cylinder. Just some thoughts. Great car by the way.
  6. Crusty Chevy
    Crusty Chevy
    Sounds like fuel percolation with heat soak. Basically the hot motor causes fuel to evaporate out of carb bowls. Modern fuel is not designed for open top carbs but rather a sealed FI system so you will have issues at each hot stop. Fuel vapor is heavier than air and sinks to bottom of intake where it pools up. You are thus both flooded and having empty carbs making starting difficult. Easiest fix is adding an electric fuel pump to fill carbs, then crank car without touching gas pedal to clear the flooding condition while still cranking slowly depress pedal to the floor and bam it should start. Can also add a phenolic carb separator to slow down the heat sink but I have not bothered with that.
    CaptainComet and Ken The Coug like this.
  7. deathrowdave
    deathrowdave
    from NKy
    I go for the battery cables too small , grounds most be large and complete the circuit also. I kinda have a soft spot for da 3w .
    enloe likes this.
  8. SPEC
    SPEC
    Do not use the Frame for a ground. Run heavy cables directly to the starter and Engine Block.
  9. ***Area-51***
    ***Area-51***
    from Ohio
    Wow! Just read the whole thread....An incredible experience....32 is AWSOME!!!
    Ken The Coug and enloe like this.
  10. As a guy that lives on an island, and travels by ferry everytime I leave or return (often in a hotrod), I feel your pain of being the no-start center of attention holding up a boat full of commuters/travellers!
    Very cool car, good luck in solving the 22 minute heat soak issue.
  11. wvenfield
    wvenfield
    Quick and easy check for the starter I was told to do years ago. If it won't start have a bottle of water and pour it over the starter. If it starts, it's the starter.
  12. Love this car! I'm glad you are enjoying the Coupe, even with the hiccups
    rod1 and Ken The Coug like this.
  13. Wow!! Nice job man!
  14. 6sally6
    6sally6
    HMMMMMMM....don't really agree with this . Short (and big enough) ground wire from battery-to-frame has always worked on my (M-word) .
    Body-to-frame...starter to frame...engine to frame...EACH light-to-body (that's grounded to frame to negative pole on battery).
    6sally6
    porkshop likes this.
  15. Rocky
    Rocky
    Classified Editor
    Ken.....what ever you do, don't throw that starter away. The early Pontiac V/8s used a shorter starter on the manual trans engines and the automatic trans starters are too long. Most of those old Ponchos used an automatic trans so a "stick" starter is hard to find . Hope you get your "bugs" worked out ok.
  16. Ken The Coug
    Ken The Coug
    Super busy summer but did get after a couple issues. Ripped the engine out and fixed the freeze plug issues. I tried the advice from the HAMB and added a spacer for under the carbs to try to help the heat soak non-start issue. I also wrapped the exhaust pipes. I think we got the death wobble fixed, was able to get it up to 90 mph without the radiator shell looking like a gymnast on crack. I was toed out a little so we adjusted. Gonna put the Bias tires back on but I feel confident they were only a small part of the wobble. Replaced the linkage on the tri-power and the new setup is much more snappy. I was invited to go on a Poker Run with the Coffin's and had a great time even in the rain. Ton of really cool rigs. I think my fix on the engine oil pump worked as I had no oil pressure issues and I have a 1000-2000 miles on the engine since I replaced the oil pump, fingers crossed! 2025 9.jpg 2025 10.jpg 2025 12.jpg 2025 11.jpg 2025 1.jpg 2025 3.jpg 2025 2.jpg 2025 13.jpg 2025 14.jpg
    enloe, SimonSez, cactus1 and 12 others like this.
  17. cfmvw
    cfmvw
    Years ago I had a Pontiac 455 with a hot start issue, even with heavy battery cables running to the starter. I added a Ford solenoid and buss bar to the starter, and that fixed it. Bonus is that the starter is a lot easier to R&R, since all the wiring is now at the solenoid (on the firewall in my case), just have to disconnect the battery cable from the solenoid to pull the starter instead of messing with all the extra wiring that normally runs to the Pontiac solenoid.
    deathrowdave, rod1, porkshop and 3 others like this.
