Projects 32 Ford 3 window build finish details
Discussion in 'The Hokey Ass Message Board' started by Chief 64, Sep 29, 2016.
  1. Tim_with_a_T
    Tim_with_a_T
    Looking good. On those spindles, I believe all early Ford spindles were forged, right?
  2. Tim_with_a_T
    Tim_with_a_T
    Alchemy beat me to it.
  3. Chief 64
    Chief 64
    Thanks guys I looked at the spindle and thought how could they have forged the letters in ? But after I posted it I thought no way could these be cast! I had casting on the mind‍♂️ glad you guys straightened me out!
    Alchemy- glad to see you following my project, I know you have my back!
  4. Robdski
    Robdski
    I just read through the entire thread, some great info throughout the years.
    Great build and thanks for taking the time to share all your progress!
  5. Chief 64
    Chief 64
    Robdski - Thanks for the kind words!
    Hi Guys,
    Progress has been a little slow lately. Having fun with our new RV Camper has taken some time away from the 32. Then to make matters worse the 32 has been not been playing well...
    While I waited for the new length tie rod & drag link (which went really well ordering them from Speedway) I installed the fuel pump & fuel filter. Audi my barn cat inspected my work and the installation p***ed inspection, then things started to go off the rails!
    The suspension turned out well with the new tie rod & drag link so I moved unto the brakes & wheels.
    First thing was to paint more parts cast iron gray. The shocks painted great, the wheel hubs painted great and one backing plate painted great. The other backing plate looked like elephant skin on a hot day.
    So I sandblasted & sanded the one backing plate and brushed on some two part epoxy primer.
    Paint was still bad. So I went to the default "fix any bad paint job" by stripping it bare with paint stripper.
    Then another fresh coat of two part epoxy.
    Then another fresh coat of cast iron gray.
    Finally I have both backing plates painted and ready to install.
    A brand new set of shock came with the car when I bought it. I measured the extended & compressed lengths and they seemed perfect. I took off the stickers and painted them spray gray.
    I goofed and didn't try them before I painted them. The dust shield interferes with the upper shock mounting bracket. So I had to "re-size" them by cutting off the dust shield.
    Then some belt sanding to clean up the re-sizing process. I left a little on because I didn't want to affect the weld joint for the top of the shock mounting barrel. Once installed you can hardly see that. Of course now I have to repaint it because some of the paint didn't cover the shock where the dust cover was last time when I painted it.:rolleyes:
    Sometimes its the little things that can really take up your time. My wheel hubs look identical but one has a threaded dust cover and the other has a press fit dust cover but I didn't have the press fit dust cover. Fortunately I love a good treasure hunt and it was a long hunt to find the press in dust cover. I finally found it at Speedway but the P/N is not listed online but the gal on the phone found the p/n for me and it fits perfect. I need to go back & order a spare in case I ever lose it. If someday I ever own a bigger lathe I can machine threads in the one so they both match.
    Now the front suspension is back on its wheel again.
    In other news, my brake master cylinder decided to punish me for taking so long on this project and went on strike and totally seize up. It must of had moisture in it and simply rusted solid. It looked like a early falcon or mustang single cylinder unit. When I got the car it came with a nice new dual master cylinder so I decided to upgrade the system since with the body off this would be the best time to do it. Sadly my friend Rick who I bought the car from had done a very nice job bending all the lines for the single master cylinder unit and I just removed all that nice work. Anyways I installed the new twin cylinder unit, two new residual valves, a new proportioning valve and the surrounding lines. I still have more work to do. I have to paint the master cylinder & bracket for the proportioning valve, attach some new rubber coated clamps for the lines then add fluid and bleed the system. After the exhaust is installed I will need to design some heat shields.
    Thanks for following along. Greg
    BigRRR, lucky ink and Tim_with_a_T like this.
  6. Chief 64
    Chief 64
    Hi Guys,
    Way back on post 95 I designed & built the alternator brackets. These were made so that I could put hood sides on in the future without interfering with the alternator. I always felt that they were just not robust enough and several friends made the same observation. Since the engine is now on a stand, today is the day to stiffen the alternator mounting. Here are the 2 existing brackets, one goes from exhaust manifold to the bottom of the alternator and the second one provides adjustment and attaches to the top of the alternator.
    I decided to add a bracket from the front intake bolt to the back of the lower bracket. These heads have no taped holes in the front of them. I rounded up this donor part.
    cut off the ends
    Angle iron would have worked but I am trying hard not to use angle iron any where that it can be seen. So I had to twist the flat piece of steel. I heated it red hot and twisted it 90 degrees.
    Very close but needs a little edge bending.
    I smushed it in the hydraulic press a little.
    Then a little drilling, belt sanding a radius on the ends and it looks good.
    Fits good in place.
    Clears the valve cover nicely
    Alternator in place. This is not the alternator I am using, just a mock up unit.
    Front view. The radiator hose fits fine but it doesn't look like it in this picture.
    Hopefully when these brackets are painted aluminum color or satin black they will blend in and not been seen. It was difficult to place this alternator and still be able to use hood sides. It is really sticking up there. When I tighten down the belt and all the mounting bolts the alternator is solid as a rock, so I think the days work was a success!!
    Thanks for following along! Greg
    BigRRR and Tim_with_a_T like this.
  7. patsurf
    patsurf
    i see the mock-up delco,but are you thinking of using the small denso style alt.?
  8. Chief 64
    Chief 64
    Patsurf- I am planning on using a brand new vintage looking Delco early 1960’s single wire alternator. Later on I might switch to a vintage looking generator. The only concern I have with my set up is that after I put the hood sides on all the air going through my alternator will be hot air after it has come through the radiator. I hope it is not too hot for the alternator. But there must be a million 32 Fords with alternator’s inside the hood with hot air p***ing through them so probably not an issue. Time will tell.
  9. patsurf
    patsurf
    pretty sure that isn't going to be a concern!!
    Chief 64 likes this.
  10. Chief 64
    Chief 64
    Hi Guys,
    I made a little progress on the 32. When I bought the car, it had a cool, brand new Hunt distributor. I have been thinking about the initial start-up and breaking in the new solid lifter flat tappet cam. I need this motor to start up quickly and run good for cam break in. Since I know nothing about the Hunt distributor, I decided to switch the distributor to one that I am familiar with, a good old Delco Remy points and condenser unit. This way if there is any ignition issues at start up I can quickly figure them out before I destroy the cam.
    Here is the Hunt Distributor I took out. I'll save this for later.
    I found this distributor on eBay. It is a 1965 327chevy distributor which I thought was cool since my motor is a 1965 327. It had very little wear on the cam gear but the shaft was stuck.
    I finally got it apart. I think the oil inside of it had fossilized into rock. I practically needed dynamic to get the shaft out. Once I got it apart I spun the shaft in my lathe to check for run out and to polish it a little. The shaft is good.
    After sandblasting the body and cleaning up all the parts and a little painting it was ready to rebuild.
    I ordered a new cam gear, shims, vacuum canister, small parts package, pig tail wire, points plate ground wire and tune up parts.
    I replaced the ground wire for the vacuum advance plate. This wire moves every time the distributor advances and the wire inside can fail and the wire still looks fine on the outside. I soldered the new one in place.
    I sanded off the paint at where the vacuum canister sits since this is the path for the grounding wire.
    Next was a new pig tail with rubber grommet.
    Next I packed the grease reservoir with the thinnest grease I could find since I was not able to find distributor grease. Then I used a socket to slide in the plastic washer.
    Then I soaked the felt with some drops of oil.
    Then slide it into place.
    I installed the vacuum canister and the vacuum advance plate and checked it with a vacuum tester for smooth operation. all is good. (I installed the c clip but have no picture of that)
    Next the shaft is greased and installed.
    Next is shimming the cam gear. I left about .025 gap. I aligned the dimple ( shown in white with the pencil) with the rotor then installed the roll pin.
    After everything is back in place I do one last check with the vacuum tester to check for smooth operation.
    Then a check with the multi meter to make sure the electricity is going where it is supposed to and not where it is not supposed to. All is good.
    The finished distributor.
    and in the motor.
    After the car is broken in I will return to the distributor to fine tune the springs and advance curve for top performance. Now I need to find a port to pull vacuum from. It seems neither my WCFB carbs or manifold have a vacuum port... more on that later.
    Thanks for following, Greg
  11. Robdski
    Robdski
    Excellent detail photos and rebuild information about the distributor.
    The engine is looking great too.
    Thanks for the update.
  12. Thanks for the write-up and pics of the distributor rebuild. Where did you order all the small parts for the rebuild?
  13. DDDenny
    Check out that Hunt unit before getting too far out of town, my pal bought a car that had one already installed, was out for a drive, started acting up, then just died, no start.
    Internal parts were loose, they have been known to give trouble.
  14. Fogger
    Fogger
    The Delco Remy points distributor is a very reliable unit if maintained as you have shown. My three running cars have single point Delco's and I've never had any issue with reliability. Your project is progressing very well and will be a great driver. Looking forward to more updates. Not many guys know about the dimple on the gear and lining it up to the rotor.
    Algoma56 likes this.
  15. 60 Special
    60 Special
    from Omaha Ne.
    Is the dimple for balance or for alignment for the roll pin? Or what? :rolleyes: 60 Special
  16. patsurf
    patsurf
    is that so a pre-determined #1 on the cap is correct?-never heard of this dimple...
  17. Chief 64
    Chief 64
    Hi Guys,
    Robdski - Thanks for the kind words, glad you are following along.
    Algoma56 - I got the small parts kit at Top Flight Automotive, see below pictures for part numbers.
    DDDenny - I have read here on the Hamb some guys have had their hunt distributor internal coil overheat and cause the car to die. My Hunt Distributor came with the car, it was brand new in September, 2000. Its never been used. I hope there were no issues with a unit from 2000. We will see later. Thanks for the info!
    Fogger - I also run points & condenser in all my cars. 50 years ago I had an Accel BEI (breakerless electronic ignition ) in a Z/28. I think it was Bill Jenkins that ran them so I had to have one. It left me sitting. I sent it in to Accel for repairs. They sent me a brand new one, no charge, its still sitting on the shelf. Been using points & condenser ever since.
    60 Special & patsurf- see my answer below about the dimple.
    Here are the part numbers for the parts from Top flight Automotive. (and the pig tail from Summit )
    Here is the part number for a really handy punch to drive out the roll pin when your hands are old. It has a spherical ball on the end to locate the punch better.
    I have a magic concrete floor in my barn ...it can make any small parts you drop totally disappear, especially little distributor screws. So I bought extras so when I drop a small screw behind the motor or off the bench, I have extras. Here are the part number for extra parts.
    See the dimple in the distributor gear. This is an old used Pontiac gear but the dimples are the same as Chevy.
    The gear can be put on two ways. The correct way is with the dimple lining up with the rotor electrical contact. The dimple is painted white in this photo and see how it lines up with the rotor.
    Still not clear? Maybe this photo will help. See how the dimple lines up with the rotor.
    Don't panic if you never did this, your car will run fine. This is the way I was taught to do it so I always do it this way. I suppose it was done this way at the factory to help ***embly set the distributor in place and have the number one post on the distributor cap line up with the rotor so that the dwell adjustment window is in the perfect spot and have the proper swing clearance for the vacuum diaphragm when setting the timing.
    In other news, I set the motor on the frame rails today and installed the clutch.
    Thanks for following along, Greg
  18. Chief 64
    Chief 64
    Hi Guys,
    Made a little more progress on the 32. Time for the trans and bellhousing. The bellhousing has been moved all over my shop in the last year or two since I took it off. After a good cleaning, I draw filed the mounting surface to make sure it didn't get any dents during storage that would make it sit crooked. Then lubed up the fork and put her on.
    Next was the trans. The best $400 I ever spent on tools was a used gantry crane on Craig's List 15 years ago. When I was young I could throw a Muncie around like a bellhousing, now.. not so much.
    Trans and driveshaft are back in.
    Next on the list was the PCV. The engine is a 1965 327 so it has a road draft tube and not a PCV system. The road draft tube was a nice chrome one but it looks like any oil dribble or oil mist was going right out the tube and onto the p***enger exhaust pipe. This would likely create a bad smell for the Mrs's. Not a good plan. We have a 53 Pontiac Chieftain with a Flathead 8. It has a road draft tube and when you are sitting in traffic you can smell burning oil.
    I found this PCV kit on line for a 1967 Camaro L30 327. Seems like it should work fine.
    My intake manifold is a 56 Chevy dual quad with WCFB carbs. Neither have a vacuum port. So I went on a hunt to see where to pull manifold vacuum. The best place I could find was between the carbs right through the letters GM. The manifold casting is nice and thick right there. Does anyone know if drilling through a GM logo is like breaking a mirror that will bring on 7 years bad luck??? I hope not! I think it is OK since this is going into a Ford? Right?
    So after removing the manifold I sharpened a drill bit and went at it. Then hand tapped it for a 1/8" NPT. I have just enough clearance to swing the fitting in. I power washed the manifold and blew air through it to make sure I got all the aluminum chips out.
    I need this vacuum port for both the PCV & the distributor advance. I added an elbow and another fitting sized for a distributor hose.
    The hoses fit in nicely.
    The final side view of the engine. A little bit more clutter but it was the best I could do.
    I put the PCV in the hose at the back of the motor.
    I have studied several H.A.M.B threads on PCV systems so I think this should work fine. My oil fill tube is a vented cap.
    I am a big fan of using a vacuum gage on my tune ups and checking engine health so I am also happy to have a place to attach my vacuum gage.
    Bcap55, nunattax, Algoma56 and 2 others like this.
  19. Chief 64
    Chief 64
    ekimneirbo - Thanks for the compliment!!! That was kind of you to take the time to write that. This is my first Hot Rod. I have been a muscle car guy for years. I can't wait to finish this car and truly be a "real deal" hot rodder.
    My new dual master cylinder installation was a bust. I installed my exhaust pipes and the exhaust is just to close to the cylinder & lines. So I made a custom die to form very tight bends on the lines coming out of the cylinder. Even with this improvement I was not happy.
    So I searched the NAPA offering and found a dual master cylinder for manual brakes with the lines exiting the cylinder on the opposite side from my exhaust pipe. After bending new lines I think its a lot cleaner routing and will be easier to service it in the future.
    The exhaust is still to close to the master cylinder so I installed a heat warp so I don't cook it sitting in a traffic jam.
    I used a hose clamp to hold one end while I wrapped it.
    Then some wrapping and the bands. I wasn't sure about doing this and I haven't seen it on the H.A.M.B. so I sent a pm to krylon32. He uses it and gave me some advice on wrapping it. I did a 1/2 overlap.
    Next I installed an aluminum shield. This may not have been necessary but I did it anyways. I cut some aluminum sheet and my son gave me some aluminum honeycomb. I used JB Exhaust sealer to bond the honeycomb to the sheet.
    Then added a weight to hold it in place until the JB weld cured.
    Then some t******* with a utility knife. The honey comb is only .003-.004 thick and the knife cuts it like ****er.
    The final ***embly. I don't think much heat will get to my master cylinder now!! Some heat will p*** through the wrap and get to the aluminum shield and then p*** to the honeycomb which should dissipate any heat to the air with the honeycomb acting like cooling fins.
    another view
    and another. Next up is fine tuning a rod for the pedal.
    In other news, I installed the front spreader bar. Do frames shrink when you paint them like clothes in a dryer???? I don't remember any issue when I took it out but re-installing it was a chore. I had to make a fixture for my hydraulic jack and spread the frame a little to get it in.
    All installed with nice chrome fasteners.
    That's all for now!! Thanks for following along! Greg
    Bcap55, lucky ink, hotrodA and 4 others like this.
  20. Happydaze
    Happydaze
    Im liking the heat shield. I'd suggest a simple tab to the crossmember as it looks to me like it would otherwise potentially flap about, maybe make a noise, and ultimately fail. Simple angle, drill and tap the frame and bolt or rivet to the shield.
    Chris
  21. Chief 64
    Chief 64
    Hi Guys,
    Happydaze
    - I agree, I think the heat shield needs a bracket at the outer end. So I cut a piece of aluminum, cut a br*** bushing in half for a die and found the right size socket for an upper die and got busy.
    A little arbor press work with my make shift dies.
    Then a little bending in the arbor press.
    Drill a few holes and its ready to go.
    Install 2 screws and its done.
    I wrapped some rubber from an old bicycle tube around the cross member tubing and added a clamp. For now I have a worm clamp but I am looking for a better more traditional clamp to be permanent. The honeycomb heat shield is sturdy now at both ends.
    Next was the rear spreader bar. Again, I needed a hydraulic press to spread the frame rails apart to fit the spreader bar.
    The spreader bar had some "storage scratches" on it so I had to wet sand and buff it first.
    Then came the exhaust tail pipes. The holes for the tail pipe hanger brackets were gone. Some idiot named Chief 64 apparently got carried away prior to painting the frame and welded up the extra "unnecessary holes" in the frame not realizing these hole needed to stay.
    A little c-clamping & drilling.
    All recovered. Tail pipe hung!!
    The exhaust is complete. 100% of the credit for this exhaust system goes to my friend Rick who I bought the car from. This exhaust system was designed built and originally installed by Rick before I bought the car. He picked out the 30" Smithy's, the V- Band clamps, the ceramic coating and the polished stainless steel exhaust tips at the back. He even put the tail tail pipe hanger bracket hole in the frame that I welded up by mistake. I am just reinstalling what he did.
    In other news I installed the shift linkage. It had interference with the exhaust pipe. It was fine before I took it all apart. I decided to make a correction so no matter where the engine ends up in its mounts, the shifter linkage will have clearance.
    After marking where to dimple, I removed the exhaust pipe and made a wooden lower die to cradle and hold the pipe so it wouldn't crush when I pressed a dimple in it for shifter linkage clearance.
    Then I used a body shop s**** for an upper die to spread the load and press in a nice smooth rounded dimple. I heated the pipe with a torch first.
    First press, so far so good, so I did a few more presses.
    I was successful! Now the shifter has a fair margin of clearance to the pipe.
    That's it for now! Thanks for your input and following along! Greg
  22. DDDenny
    Your front axle and misc. look great in "cast iron gray" paint, curious, did you use a spray gun or rattle can?
    My plan for the axle for my roadster was that if I find people have had good luck durability wise I planned on using a high quality rattle can paint.
  23. Chief 64
    Chief 64
    DDDenny - I used Eastwood's cast iron gray sprayed with a gun.
    Greg
  24. Chief 64
    Chief 64
    Hi Guys,
    I installed my gas tank, fuel regulator, tank vent and fuel lines. I had pre-fit the tank prior to painting so it went in perfect. I called Tanks Inc and asked about the springs on the mounting bolts. They said I didn't need the springs so for now I left them off. I might install them later. They sorta look traditional.
    There was no way I could work my fingers to get the mounting bolts installed on the tank. So I cheated and ran long bolts up from the bottom. I had to drill a hole in the bottom flange of the frame to do this. I made a drill guide and c-clamped it in the right spot so the drilled hole would line up perpendicular to the frame. Generally I think it is bad engineering practice to to drill two holes directly across from one another on the flanges of a c - channel frame but out back here I think it will be okay since this is a low stress area.
    Then a little careful drilling.
    Now I can simply install the mounting bolts up from the bottom. Tape is holding the bolt in place while I set the tank on.
    Gas tank with pads installed.
    Then I installed a fuel pressure regulator and made up the lines. The fuel pump & fuel filter were already installed when I bought the car. I had to bend a loop in the gas line because I simply could not get a rubber line between the fuel pump and the gas tank without the rubber line kinking. I tried two different brands of rubber hoses but no luck. I guess I could have made the loop smaller. I used a piece of bar stock that I had laying around and a old fashion spring bender to loop the line.
    The gas lines inside the frame rail were already installed. Both a 3/8" gas line & a 5/16" return line. I don't need the return line for the dual quads but plumbed it anyways just because now it was easy to do. My goal was to run the rubber lines as short as possible .
    I made a bracket to support the lines and keep them out of trouble. When possible I like to weld nuts on to the brackets to make ***embly easier. I slotted the gas tank vent bracket so I could adjust it as high as possible when the body is installed.
    The lines are sturdy with the brackets. Later I will switch to the rubber coated clamps. These plastic coated clamps are okay but I like the rubber coated ones better.
    Wherever I attach a metal line to a rubber line I use my flaring tool and put a flare on the end to make sure the hose never slips off. My flare is not as nice as the machined br*** flare on a fitting but it will hold the hose.
    My gas tank vent was getting cranky with me when I went to screw it tight on the bracket so I machined wrench flats on it so I could tighten it. Somehow I thought if I use a channel lock pliers I would make a mess of it.
    I think the gas tank vent install was not successful. Its only an inch or two above the gas cap and the hose has a low area where gas could pool. The car is level in this picture and the carpenter's level is level. When the body is on the frame I plan to install a closed line up into the cab that will make a loop and then exit right back out to the vent. I have seen this method with other cars on the H.A.M.B. ( The cover is on the car because I was painting something.)
    Lastly I added a gas line to the carburetors. I plan to add some insulation to it down below the valve cover by the exhaust but I am holding off on that until I decide where I am putting my fuel pressure gage.
    I went with the Moon fuel pressure gauge to match the Moon water temp gauge on the water pump. I am not sure if I will mount the fuel pressure gauge on the fire wall with this Fenton fuel block or mount it inline with a tee near the carbs. I have to wait until the body is on to decide. I have Fenton exhaust manifolds so a Fenton Fuel block would be cool.
    This is the original windshield from my car. Looks like Moon gauges may have been on my car for a long time.
    Thanks for following along! That's all for now! Greg
  25. pprather
    pprather
    Looking good.
    The fuel line clamps near the tank may be hard to service from underneath once the body is installed.
    Just be careful, things change after you install the body.
  26. Chief 64
    Chief 64
    Thanks Phil!
    Good advise!
    I have come to the conclusion that I will need a trap door cut out in my trunk floor the size of Texas so I can access service to all of this plumbing. With all these connections I just know a few will need to be tightened to stop a leak. I did have a practice run with the tank installed to make sure the fuel pump, fuel filter & fuel pressure regulator and all their bolts could come out without removing the tank. I don’t have a lift or I might think about moving some things to the frame rail.
    Thanks again, Greg
  27. DDDenny
    Thank you
  28. RockyMtnWay
    RockyMtnWay
    So…am I seeing the fuel delivery system sequence as electric fuel pump, then fuel filter, then pressure regulator?
    Curious why you wouldn’t put the filter in line before the pump.
    Wouldn’t it be better to (a) clean the fuel before it hits the pump, and (b) also NOT pressurize the filter canister at max pump pressure?
    Fuel leaks, especially under any pressure scare the **** outta me. :eek::eek::eek:
    Not telling anyone how to build their car, just chirpin.
    EDIT: just went back and read your thread from the start and wanted to say sorry if my chirps have sounded negative. I think I’m turning into a curmudgeon. Your work has been awesome to follow along and thank you for taking the time and effort to do***ent it. You have lots to be proud of and as you head down the home stretch I can imagine how exciting it will be to make the first drive. Best of luck and thanks again for bringing us along on a great thread.
  29. nochop
    nochop
    from norcal
    I ran my small block alternator on a gm smog pump bracket IMG_2429.jpeg IMG_2412.jpeg
    Tim, PONTNAK123, loudbang and 2 others like this.
  30. Chief 64
    Chief 64
    RockyMtnWay - No Worries!, I love your posts!! You think out of the box and challenge the norm! When I started this project 9 years ago it seemed like I used to get more suggestions... I think every body has given up on me after 9 years. Please don't stop responding.
    About the gas filter - I think you are correct, a filter should be used before the fuel pump. The instructions for the last few fuel pumps I have bought all say to install a filter prior to the pump. In this case my fuel pump & filter is a old NOS A/C Delco pump like we used 50 years ago. This is the kind that you could pump a dead pig through the pump without issue. I doubt if this pump makes more than 6psi. Plus my gas tank is brand new so I should be okay? right? I am surprised I didn't get some feedback about the gas bowl filter up at he carb. Some guys worry about the gl*** breaking and causing a disaster. I am keeping mine because they look so cool! and they are traditional.
    nochop- I like your alternator solution. Good job repurposing an emission part on a Hot Rod!!. Back when I was mounting the alternator, I did find some commercially available alternator mounts that would clear my hood sides and work with my "no hole" camel hump heads but then they interfered with my oil fill tube. In the end I just made my own mounting, thanks for sharing your set up.
    lucky ink likes this.
